black band round movies
glda19
Post Sun Nov 29, 2020 11:21 am
hi
i play the movies on a dnla server.
Some movies i can set by the remote control to 16:9 format and see the subtitels.
But by other when i do the same the subitels are not visible or the sise is wrong.
Post Sun Nov 29, 2020 10:32 pm
Re: black band round movies
The DLNA server is streaming your media. It's not where you would normally watch the media. So exactly what are you using as your player? A Smart TV? Blu Ray player? Streaming media player (Roku, Fire TV, Shield)?
In general you shouldn't need to mess with the screen aspect ratio for your videos. If the media is widescreen, it should fill the screen left and right, while the top/bottom may have bars depending on the aspect ratio of the media itself. But if you're using the TV's aspect button to zoom in a 4:3 image, you're going to cut the top and bottom off the image, which could remove the visible captions. Also, if you're zooming in a 2:35:1 image to fill the 16:9 TV display, again you're cutting off the bottom of the image, and that's where the media producers have placed the captions.
I believe you are using the TC aspect button incorrectly. You should be using it rarely, if at all. I have a few 16:9 DVDs that were authored incorrectly (it wasn't created as an anamorphic image), and I end up with bars around all four sides. If I zoom in to fit the sides, yes the captions disappeared off the bottom. My solution was to replace the DVD version with a Blu ray version, which was authored correctly.
glda19
Post Mon Nov 30, 2020 5:26 am
The name of the movie us a hidden life
I've diwnload two versions and always black borders
Post Mon Nov 30, 2020 2:42 pm
I would have to see the media information. The title means nothing, as it could be modified by someone before it was posted. See the link in my sig line for how to get the media content information.
glda19
Post Tue Dec 01, 2020 5:44 am
What must i've vive You out the link how to get media content ?
Can You specify What You need
Post Tue Dec 01, 2020 3:14 pm
This link in my sig line: HOWTO: Identify media file contents
It explains how to gather the information about your media files that I asked for.
glda19
Post Sun Dec 06, 2020 10:18 am
Here is the output of the ffmpeg
output.txt
(2.61 KiB) Downloaded 613 times
Post Sun Dec 06, 2020 6:28 pm
I can see nothing in the media contents that would indicate it isn't a normal 16:9 video. The info matches what I see when I look at some of my media.
glda19
Post Sun Dec 06, 2020 9:58 pm
But not my setobox or tv get it in 16:9
Post Sun Dec 06, 2020 10:35 pm
I have no answer for you. For whatever reason your TV is displaying blank space around the image. According to the media information, your media is 16:9, so should fill the screen. However, I have also seen older DVDs that were not authored correctly for 16:9 TVs, and had black bars around all four sides. One example is the Mel Brooks movie Young Frankenstein. My solution was to buy a Blu Ray version, which was correctly authored for 16:9 TVs. Unfortunately, I don't think there's anything that can be done from the Serviio side to resolve this issue. It is streaming the media in the format it is authored in, and the only thing you can do is either accept it or use the TV's zoom control to expand the image.
glda19
Post Mon Dec 07, 2020 4:32 pm
i've donwload a other version and now when i set the tv on 16:9 its ok
and that is the output bye ffmepeg for the new film
output2.txt
(2.44 KiB) Downloaded 626 times
Post Mon Dec 07, 2020 6:30 pm
That one is a completely different format. It uses HEVC (H.265) instead of H.264, it's SD instead of HD resolution, and the SAR/DAR figures are completely different. Not a surprise it looks different on the screen. :D
