Serviigo - No content
sam1
Post Sun Nov 08, 2020 10:56 am
OK - I have been using Serviio for a while linked to my Samasung TV - No problems. Have just updated and have a free trial of Pro. Have installed Serviigo on android device, set up user and connectect to PC which acts as server. In audio Serviigo shows a few of the artists in my library, but if I open any of them it returns the message "No Content". If I look at Video both Movies and Series show "no content". In the case of both Video and Audio, 100% of my files are visible on the Samsung TV, just nothing on the android device. Any suggestions wellcome.
papapavle
Post Wed Jul 14, 2021 4:27 pm
Re: Serviigo - No content
sam1 wrote:OK - I have been using Serviio for a while linked to my Samasung TV - No problems. Have just updated and have a free trial of Pro. Have installed Serviigo on android device, set up user and connectect to PC which acts as server. In audio Serviigo shows a few of the artists in my library, but if I open any of them it returns the message "No Content". If I look at Video both Movies and Series show "no content". In the case of both Video and Audio, 100% of my files are visible on the Samsung TV, just nothing on the android device. Any suggestions wellcome.
Hello, Sam,
Did you ever solve this issue? I have the same problem with both MediaBrowser and ServiiGo, even on the local network. Meanwhile, DLNA access to Serviio shows all folders and files normally, so I don't think it's a share privileges issue.
papapavle
Post Wed Jul 14, 2021 4:53 pm
It was pretty simple, in the end - all I had to do was enable access to myself, going to Serviio Console/Library/Shared Folders/Edit.../Users with access. By default this was off for my one and only username.
Post Thu Jul 15, 2021 12:57 am
papapavle wrote:It was pretty simple, in the end - all I had to do was enable access to myself, going to Serviio Console/Library/Shared Folders/Edit.../Users with access. By default this was off for my one and only username.
Yes, that has tripped up a number of users. User accounts were added in version 2.0, and for web based access you must specifically grant access to each user for each library location.
Users browsing this forum: Baidu [Spider] and 32 guests
