Serviigo - No content
sam1
Post Sun Nov 08, 2020 10:56 am
OK - I have been using Serviio for a while linked to my Samasung TV - No problems. Have just updated and have a free trial of Pro. Have installed Serviigo on android device, set up user and connectect to PC which acts as server. In audio Serviigo shows a few of the artists in my library, but if I open any of them it returns the message "No Content". If I look at Video both Movies and Series show "no content". In the case of both Video and Audio, 100% of my files are visible on the Samsung TV, just nothing on the android device. Any suggestions wellcome.
papapavle
Post Wed Jul 14, 2021 4:27 pm
Re: Serviigo - No content
sam1 wrote:OK - I have been using Serviio for a while linked to my Samasung TV - No problems. Have just updated and have a free trial of Pro. Have installed Serviigo on android device, set up user and connectect to PC which acts as server. In audio Serviigo shows a few of the artists in my library, but if I open any of them it returns the message "No Content". If I look at Video both Movies and Series show "no content". In the case of both Video and Audio, 100% of my files are visible on the Samsung TV, just nothing on the android device. Any suggestions wellcome.
Hello, Sam,
Did you ever solve this issue? I have the same problem with both MediaBrowser and ServiiGo, even on the local network. Meanwhile, DLNA access to Serviio shows all folders and files normally, so I don't think it's a share privileges issue.
papapavle
Post Wed Jul 14, 2021 4:53 pm
It was pretty simple, in the end - all I had to do was enable access to myself, going to Serviio Console/Library/Shared Folders/Edit.../Users with access. By default this was off for my one and only username.
Post Thu Jul 15, 2021 12:57 am
papapavle wrote:It was pretty simple, in the end - all I had to do was enable access to myself, going to Serviio Console/Library/Shared Folders/Edit.../Users with access. By default this was off for my one and only username.
Yes, that has tripped up a number of users. User accounts were added in version 2.0, and for web based access you must specifically grant access to each user for each library location.
