0.6 Doesn't work with Popcorn Hour A100/A210
• Page 3 of 3 • 1, 2, 3
Because you can quickly see recently added, have all your TV shows displayed under one menu when they're spread across multiple folders and drives and you can see last viewed etc.
Re: 0.6 Doesn't work with Popcorn Hour A100/A210
After a lot of messing around I can say that Serviio does work with Popcorn Hour with a small tweak. As long as you do not generate the thumbnails from metadata then everything works fine. If you generate the thumbnails PCH thinks it needs to display a photo and that's where it fails.
JoeDonkor, thank you so much! I can also confirm that this is working..... BUT....it is not transcoding DTS audio
Is this working for you? Typically, almost everything I have is DTS
Ah great! So zip will you be able to fix it while also keeping meta data?!
I still don't seem to be able to get this working. Could someone please describe exactly which setting(s) need to be turned off? Thanks!
RXP wrote:Ah great! So zip will you be able to fix it while also keeping meta data?!
I've reopened the ticket and marked it for 1.1
https://bitbucket.org/xnejp03/serviio/i ... -any-files
Petr
Help translate Serviio
Users browsing this forum: No registered users and 112 guests
