0.6 Doesn't work with Popcorn Hour A100/A210
RXP
Post Wed Apr 18, 2012 1:58 pm
Re: 0.6 Doesn't work with Popcorn Hour A100/A210
Because you can quickly see recently added, have all your TV shows displayed under one menu when they're spread across multiple folders and drives and you can see last viewed etc.
JoeDonkor
Post Sat Jun 02, 2012 4:57 am
After a lot of messing around I can say that Serviio does work with Popcorn Hour with a small tweak. As long as you do not generate the thumbnails from metadata then everything works fine. If you generate the thumbnails PCH thinks it needs to display a photo and that's where it fails.
10one10
Post Sat Jun 02, 2012 6:13 pm
JoeDonkor, thank you so much! I can also confirm that this is working..... BUT....it is not transcoding DTS audio :( Is this working for you? Typically, almost everything I have is DTS :cry:
RXP
Post Sun Jun 03, 2012 4:35 pm
Ah great! So zip will you be able to fix it while also keeping meta data?!
elziko
Post Sun Jun 03, 2012 5:54 pm
I still don't seem to be able to get this working. Could someone please describe exactly which setting(s) need to be turned off? Thanks!
Post Tue Jun 05, 2012 9:09 am
RXP wrote:Ah great! So zip will you be able to fix it while also keeping meta data?!
I've reopened the ticket and marked it for 1.1
https://bitbucket.org/xnejp03/serviio/i ... -any-files
RXP
Post Tue Jun 05, 2012 9:14 am
Thanks zip :D
Previous
