Progdvb stream under DLNA
blase
Post Mon Jan 28, 2013 9:47 pm
Hi all
I have a small problem
He had set the option to view DVB emissions from progdbv through the serviio.
Get set and be able to see on my tv, but suddenly stopped working, I changed codecs updated version of ProgDVB and serviio. But I have not got it working again.
I have found that works with VLC streaming so the emission from ProgDVB goes well.Note that the streaming is internal local network is not an Internet source
logs attached
ffmpeg log
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://192.168.2.3:10999/list.m3u"
ffmpeg version N-49352-gc46943e Copyright (c) 2000-2013 the FFmpeg developers
  built on Jan 26 2013 12:12:14 with gcc 4.7.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libg
sm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --e
nable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --e
nable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --en
able-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable
-libxavs --enable-libxvid --enable-zlib
  libavutil      52. 17.100 / 52. 17.100
  libavcodec     54. 91.100 / 54. 91.100
  libavformat    54. 61.104 / 54. 61.104
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 34.101 /  3. 34.101
  libswscale      2.  2.100 /  2.  2.100
  libpostproc    52.  2.100 / 52.  2.100
[mpeg2video @ 000000000221f620] 0x0 is invalid
    Last message repeated 15 times
[mpegts @ 000000000221b4c0] max_analyze_duration 5000000 reached at 5016000 micr
oseconds
[mpegts @ 000000000221b4c0] Estimating duration from bitrate, this may be inaccu
rate
Input #0, mpegts, from 'http://192.168.2.3:10999/list.m3u':
  Duration: N/A, start: 92770.602511, bitrate: 288 kb/s
  Program 1059
  No Program
    Stream #0:0[0x65]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
, 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x67]: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16
p, 192 kb/s
    Stream #0:2[0x68]: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16
p, 96 kb/s
    Stream #0:3[0x66](spa): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Serviio log
2013-01-28 22:31:05,421 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-28 22:31:05,422 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2013-01-28 22:31:05,423 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-28 22:31:05,423 INFO  [MediaServer] http://www.serviio.org
2013-01-28 22:31:05,423 INFO  [MediaServer] Java 1.7.0_11-Oracle Corporation
2013-01-28 22:31:05,423 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-01-28 22:31:05,423 INFO  [MediaServer] File encoding: windows-1252
2013-01-28 22:31:05,426 INFO  [MediaServer] Headless mode enabled: true
2013-01-28 22:31:05,427 INFO  [MediaServer] User home dir: C:\
2013-01-28 22:31:05,427 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-01-28 22:31:05,427 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-28 22:31:05,939 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-28 22:31:05,941 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-28 22:31:06,109 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-28 22:31:06,112 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-28 22:31:06,194 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-28 22:31:10,203 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-28 22:31:10,203 INFO  [MediaServer] License: FREE
2013-01-28 22:31:12,156 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-28 22:31:16,560 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-28 22:31:19,149 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-28 22:31:20,348 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-28 22:31:22,072 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-28 22:31:23,200 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-28 22:31:23,789 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-28 22:31:25,875 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-28 22:31:25,985 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-28 22:31:28,348 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-28 22:31:31,346 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-28 22:31:32,261 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-28 22:31:32,916 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-28 22:31:33,013 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-28 22:31:33,439 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-28 22:31:33,615 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-28 22:31:39,663 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-28 22:31:39,835 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-28 22:31:40,796 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-28 22:31:41,831 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-28 22:31:42,239 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-28 22:31:42,457 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-28 22:31:44,424 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-28 22:31:44,709 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-28 22:31:45,059 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-28 22:31:45,612 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-28 22:31:46,059 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-28 22:31:46,179 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-28 22:31:47,581 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-28 22:31:49,055 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-28 22:31:53,298 INFO  [Device] Created UPnP Device with UUID: 800c3f2c-1ec3-3e02-a28a-300f31dcb035, bound address: 192.168.2.3
2013-01-28 22:31:53,376 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-01-28 22:31:53,409 INFO  [UpdateChecker] Checking if a new version is available
2013-01-28 22:31:53,802 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-28 22:31:54,029 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-28 22:31:54,039 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-28 22:31:54,039 INFO  [RendererSearchSender] Searching for Renderer devices
2013-01-28 22:31:54,110 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-28 22:31:54,111 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-28 22:31:54,112 INFO  [WebServer] WebServer starting on port 8895
2013-01-28 22:31:54,458 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Controladora integrada Broadcom 440x 10/100) and address 192.168.2.3, timeout = 0
2013-01-28 22:31:58,763 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-28 22:32:07,763 INFO  [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy)
2013-01-28 22:32:08,453 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2013-01-28 22:32:08,916 INFO  [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2013-01-28 22:32:13,483 INFO  [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy)
2013-01-28 22:32:28,332 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-28 22:32:28,335 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-01-28 22:32:28,337 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-28 22:32:28,339 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Thanks and forgive me for my English
blase
Post Wed Jan 30, 2013 10:38 am
Re: Progdvb stream under DLNA
Any ideas
Post Wed Jan 30, 2013 10:47 am
What is your TV model ?
Could you enable detailed serviio logging (see signatures links) ?
How do you use this URL "http://192.168.2.3:10999/list.m3u", do you add it on serviio online source as a webressource or live resource ?
blase
Post Wed Jan 30, 2013 11:21 am
Is a media player (Wyplayer) and I've also tried it with the media player AivX-370HDW
Log
2013-01-30 12:16:38,658 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-30 12:16:38,679 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-30 12:16:38,679 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2013-01-30 12:16:38,679 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-30 12:16:38,679 INFO  [MediaServer] http://www.serviio.org
2013-01-30 12:16:38,679 INFO  [MediaServer] Java 1.7.0_11-Oracle Corporation
2013-01-30 12:16:38,679 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-01-30 12:16:38,679 INFO  [MediaServer] File encoding: windows-1252
2013-01-30 12:16:38,680 INFO  [MediaServer] Headless mode enabled: true
2013-01-30 12:16:38,680 INFO  [MediaServer] User home dir: C:\
2013-01-30 12:16:38,680 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-01-30 12:16:38,680 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-30 12:16:38,967 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-30 12:16:38,969 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-30 12:16:39,046 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-30 12:16:39,047 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-30 12:16:39,098 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-30 12:16:39,222 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-01-30 12:16:40,993 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-01-30 12:16:40,994 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-01-30 12:16:40,995 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-01-30 12:16:40,997 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-01-30 12:16:40,998 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-01-30 12:16:40,999 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-01-30 12:16:41,000 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-01-30 12:16:41,002 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-01-30 12:16:41,003 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-01-30 12:16:41,004 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-01-30 12:16:41,005 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-01-30 12:16:41,007 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-01-30 12:16:41,041 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-01-30 12:16:41,431 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-30 12:16:41,431 INFO  [MediaServer] License: FREE
2013-01-30 12:16:42,558 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-30 12:16:42,649 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-01-30 12:16:44,399 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-30 12:16:44,401 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-01-30 12:16:45,500 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-30 12:16:45,502 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-01-30 12:16:46,042 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-30 12:16:46,044 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-01-30 12:16:46,861 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-30 12:16:46,863 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-01-30 12:16:47,281 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-30 12:16:47,283 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-01-30 12:16:47,731 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-30 12:16:47,733 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-01-30 12:16:48,741 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-30 12:16:48,743 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-01-30 12:16:48,804 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-30 12:16:48,807 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-01-30 12:16:50,144 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-30 12:16:50,147 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2013-01-30 12:16:51,686 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-30 12:16:51,690 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-01-30 12:16:52,366 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-30 12:16:52,369 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-01-30 12:16:52,753 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-30 12:16:52,756 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-01-30 12:16:52,816 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-30 12:16:52,820 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-01-30 12:16:53,086 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-30 12:16:53,089 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-01-30 12:16:53,194 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-30 12:16:53,197 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-01-30 12:16:53,696 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-30 12:16:53,699 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-01-30 12:16:53,793 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-30 12:16:53,796 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-01-30 12:16:54,299 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-30 12:16:54,302 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-01-30 12:16:54,858 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-30 12:16:54,862 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-01-30 12:16:55,087 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-30 12:16:55,091 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-01-30 12:16:55,198 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-30 12:16:55,201 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-01-30 12:16:56,235 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-30 12:16:56,238 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-01-30 12:16:56,389 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-30 12:16:56,393 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-01-30 12:16:56,536 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-30 12:16:56,539 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-01-30 12:16:56,739 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-30 12:16:56,743 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-01-30 12:16:56,951 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-30 12:16:57,018 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-30 12:16:57,026 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-01-30 12:16:57,908 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-30 12:16:57,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-01-30 12:16:58,606 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-30 12:17:00,423 INFO  [Device] Created UPnP Device with UUID: 800c3f2c-1ec3-3e02-a28a-300f31dcb035, bound address: 192.168.2.3
2013-01-30 12:17:00,506 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-01-30 12:17:00,518 INFO  [UpdateChecker] Checking if a new version is available
2013-01-30 12:17:00,523 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-01-30 12:17:00,528 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-01-30 12:17:00,528 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-30 12:17:00,530 DEBUG [PluginCompilerThread] Starting plugin HaHaSport.groovy compilation
2013-01-30 12:17:00,915 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-30 12:17:01,026 INFO  [WebServer] WebServer starting on port 8895
2013-01-30 12:17:01,067 DEBUG [DiscoveryManager] UPNP device 800c3f2c-1ec3-3e02-a28a-300f31dcb035 (192.168.2.3) is available
2013-01-30 12:17:01,136 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Controladora integrada Broadcom 440x 10/100) and address 192.168.2.3, timeout = 0
2013-01-30 12:17:01,137 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-30 12:17:01,146 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-30 12:17:01,147 INFO  [RendererSearchSender] Searching for Renderer devices
2013-01-30 12:17:01,164 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-30 12:17:01,164 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-30 12:17:02,635 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Controladora integrada Broadcom 440x 10/100) and address 192.168.2.3, timeout = 0
2013-01-30 12:17:02,663 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 800c3f2c-1ec3-3e02-a28a-300f31dcb035
2013-01-30 12:17:02,763 DEBUG [WebServer] Incoming connection from /192.168.2.5:46858
2013-01-30 12:17:02,769 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2013-01-30 12:17:02,889 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 800c3f2c-1ec3-3e02-a28a-300f31dcb035 from 192.168.2.5 (headers = [User-Agent: Wybox/0.95 UPnP/1.0 DLNADOC/1.50 Portable SDK for UPnP devices/1.4.6,Host: 192.168.2.3:8895,Accept: */*])
2013-01-30 12:17:02,889 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2013-01-30 12:17:02,891 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Wybox/0.95 UPnP/1.0 DLNADOC/1.50 Portable SDK for UPnP devices/1.4.6,Host: 192.168.2.3:8895,Accept: */*]
2013-01-30 12:17:02,894 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2013-01-30 12:17:03,685 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-01-30 12:17:03,727 DEBUG [WebServer] Incoming connection from /192.168.2.5:46859
2013-01-30 12:17:03,728 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2013-01-30 12:17:03,729 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2013-01-30 12:17:03,741 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-01-30 12:17:03,780 DEBUG [WebServer] Incoming connection from /192.168.2.5:46860
2013-01-30 12:17:03,781 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2013-01-30 12:17:03,782 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2013-01-30 12:17:03,865 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-01-30 12:17:03,904 DEBUG [WebServer] Incoming connection from /192.168.2.5:46861
2013-01-30 12:17:03,905 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2013-01-30 12:17:03,907 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-01-30 12:17:03,951 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-01-30 12:17:04,523 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2013-01-30 12:17:04,834 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Controladora integrada Broadcom 440x 10/100) and address 192.168.2.3, timeout = 0
2013-01-30 12:17:04,835 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-01-30 12:17:04,836 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.3:57975
2013-01-30 12:17:04,836 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-01-30 12:17:04,841 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.3:57975
2013-01-30 12:17:04,841 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-01-30 12:17:04,843 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.3:57975
2013-01-30 12:17:04,843 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-01-30 12:17:07,787 INFO  [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy)
2013-01-30 12:17:07,787 DEBUG [PluginCompilerThread] Starting plugin LiveFeeds.groovy compilation
2013-01-30 12:17:08,079 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2013-01-30 12:17:08,079 DEBUG [PluginCompilerThread] Starting plugin Shoutcast.groovy compilation
2013-01-30 12:17:08,296 INFO  [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2013-01-30 12:17:08,297 DEBUG [PluginCompilerThread] Starting plugin USTREAM.groovy compilation
2013-01-30 12:17:09,134 INFO  [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy)
2013-01-30 12:17:10,845 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-01-30 12:17:15,936 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Controladora integrada Broadcom 440x 10/100) and address 192.168.2.3, timeout = 0
2013-01-30 12:17:15,937 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 800c3f2c-1ec3-3e02-a28a-300f31dcb035
2013-01-30 12:17:17,746 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2013-01-30 12:17:29,120 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Controladora integrada Broadcom 440x 10/100) and address 192.168.2.3, timeout = 0
2013-01-30 12:17:29,121 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 800c3f2c-1ec3-3e02-a28a-300f31dcb035
2013-01-30 12:17:30,878 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-01-30 12:17:30,878 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-30 12:17:30,884 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-30 12:17:30,887 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-30 12:17:30,887 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-30 12:17:30,888 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-30 12:17:30,922 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:59
2013-01-30 12:17:30,932 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-01-30 12:17:30,963 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-30 12:17:30,999 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-30 12:17:31,067 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-01-30 12:17:31,112 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://192.168.2.3:10999/list.m3u' in the cache (online_feeds), returning it
Always been as live source
if you need any further information requests
thanks
Post Wed Jan 30, 2013 1:52 pm
Ok for your logging, but whats happen after ?...could you try to play the media and post log.
blase
Post Wed Jan 30, 2013 2:16 pm
Log
2013-01-30 15:14:22,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.57
2013-01-30 15:14:22,701 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.57, Profile=Generic DLNA profile'
2013-01-30 15:14:22,702 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000010001 and type 'MEDIA_ITEM' received
2013-01-30 15:14:22,702 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000010001 (online)
2013-01-30 15:14:22,702 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-01-30 15:14:22,703 DEBUG [VideoDeliveryEngine] Delivering item '1000000000010001' for client 'IPAddress=/192.168.2.57, Profile=Generic DLNA profile'
2013-01-30 15:14:22,703 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.2.3:10999/list.m3u' in native format
2013-01-30 15:14:22,704 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2013-01-30 15:14:22,704 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-30 15:14:22,704 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 30 Jan 2013 14:14:22 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2013-01-30 15:14:22,704 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2013-01-30 15:14:22,781 DEBUG [OnlineInputStream] Byte range not supported for http://192.168.2.3:10999/list.m3u, returning the whole stream
2013-01-30 15:14:22,781 DEBUG [OnlineInputStream] Trying basic stream handler
2013-01-30 15:14:22,785 DEBUG [OnlineInputStream] Trying ShoutCast stream handler
2013-01-30 15:14:22,796 DEBUG [WebServer] I/O error: SHOUTCast invalid response: Ùô¥9OÛ8?³)ÇGÝ´]:´iSn????Jv!øW? ?ß§HçÝ)2çµ}8ÐEÔ«å#L¦yKÈ?ùÒ?) å#Êkª?Iò?îÛ?)?e3l¤9HZ   *í   zr×
2013-01-30 15:14:22,797 DEBUG [OnlineInputStream] Closing stream
From my little understanding seems the shoutcast plugin is trying to decode the stream.
I will remove the shoutcast plugin and see what happens
Without the shoutcast plugin this is the result
2013-01-30 15:22:17,258 DEBUG [WebServer] Incoming connection from /192.168.2.57:58920
2013-01-30 15:22:17,262 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.57
2013-01-30 15:22:17,267 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000010001/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.2.3:8895,User-Agent: NSPlayer/4.1.0.3856,Pragma: no-cache,rate=1.000000,request-context=2,Pragma: xPlayStrm=1,Pragma: xClientGUID={babac001-66da-81f8-a2-1b-a6-78-1b-ea-67-e6},Accept: */*,Connection: Close]]
2013-01-30 15:22:17,268 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.57
2013-01-30 15:22:17,275 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.57, Profile=Generic DLNA profile'
2013-01-30 15:22:17,277 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000010001 and type 'MEDIA_ITEM' received
2013-01-30 15:22:17,277 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000010001 (online)
2013-01-30 15:22:17,277 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-01-30 15:22:17,278 DEBUG [VideoDeliveryEngine] Delivering item '1000000000010001' for client 'IPAddress=/192.168.2.57, Profile=Generic DLNA profile'
2013-01-30 15:22:17,278 DEBUG [VideoDeliveryEngine] Delivering file 'http://192.168.2.3:10999/list.m3u' in native format
2013-01-30 15:22:17,279 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2013-01-30 15:22:17,279 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-30 15:22:17,279 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 30 Jan 2013 14:22:17 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2013-01-30 15:22:17,280 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2013-01-30 15:22:17,369 DEBUG [OnlineInputStream] Byte range not supported for http://192.168.2.3:10999/list.m3u, returning the whole stream
2013-01-30 15:22:17,369 DEBUG [OnlineInputStream] Trying basic stream handler
2013-01-30 15:22:17,373 DEBUG [OnlineInputStream] Trying ShoutCast stream handler
2013-01-30 15:22:17,403 DEBUG [WebServer] I/O error: SHOUTCast invalid response: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
2013-01-30 15:22:17,404 DEBUG [OnlineInputStream] Closing stream
I will install the latest version and leave only the pluging of livefeeds and see what happens.
Post Wed Jan 30, 2013 3:33 pm
What is the format of your .m3u ?
blase
Post Wed Jan 30, 2013 3:37 pm
ffmpeg log
oseconds
rate
  Program 1059
  No Program
p, 192 kb/s
p, 96 kb/s
Post Wed Jan 30, 2013 3:39 pm
No, I mean the content of your "http://192.168.2.3:10999/list.m3u" (edit with notepad++)
blase
Post Wed Jan 30, 2013 3:47 pm
OK the content is
http://192.168.2.3:10999/laSexta3
Post Wed Jan 30, 2013 3:57 pm
This is not a valid M3U format : http://en.wikipedia.org/wiki/M3U
If a m3u file is edited with a text editor, must be saved in the Windows-1252 format
blase
Post Wed Jan 30, 2013 4:49 pm
I upload the file .m3u renamed .txt
With that link has been running, until stopped working
list.txt
rename to .m3u
(35 Bytes) Downloaded 790 times
Post Wed Jan 30, 2013 5:31 pm
There were a problem with your Progdvb server that did not return a good content type when serviio try to connect to your URL.
http://download.java.net/jdk8/docs/api/ ... .String%29
What is this server?
blase
Post Thu Jan 31, 2013 9:30 am
ProgDVB is a program to watch TV/SAT on the PC (having a TV/SAT tuner installed).
Has an option called Prog Media Server, and is free with the program is what makes the broadcast TV.
blase
Post Mon Feb 18, 2013 5:17 pm
Any idea where is the problem, I have reinstalled from scratch and still the same
Users browsing this forum: No registered users and 114 guests
