problem when my mac mini 2012 turned off
bondnaruto
Post Mon Mar 11, 2013 10:26 am
I have some problem!
When My mac mini turned off, Serviio does not turn off my mac... is there a solution to the problem?
slyguy42o
Post Mon Mar 11, 2013 10:48 pm
Re: problem when my mac mini 2012 turned off
your going to have to elaborate a bit.. your mac wont shutdown while serviio is running?
bondnaruto
Post Tue Mar 12, 2013 10:07 am
slyguy42o wrote:your going to have to elaborate a bit.. your mac wont shutdown while serviio is running?
I Whant ShutDown my mac, and he don't do that. He say (mac) - program Serviio does not give shutdown mac... And I forced close program, and only then shutdown my mac, it not comfortable...
Please Help!:)
Post Tue Mar 12, 2013 2:07 pm
Some users have this problem, I don't. You will have to live with it or shut down Serviio via the console (right-click on the icon in the system tray area)
bondnaruto
Post Tue Mar 12, 2013 2:52 pm
zip wrote:Some users have this problem, I don't. You will have to live with it or shut down Serviio via the console (right-click on the icon in the system tray area)
What I'm and doing... But maybe exist solution?
grolschie
Post Tue Mar 12, 2013 6:25 pm
Does the console need to be running all the time? I'm not familiar with Serviio on the mac, but can the Serviio console be removed from the auto-startup items so that it doesn't automatically load each time you login?
slyguy42o
Post Tue Mar 12, 2013 9:03 pm
no, the console is not required just the serviio service.
