netgem netbox
chrismallia
Post Wed Mar 13, 2013 5:23 pm
netgem netbox
I have a Netgem netbox witch only kneeds transcoding for dts audio, in serviio I did not find a profile for it can one be created thanks ?
server running serviio PRO and media browser Intel dual core g2030 3.0Ghz 8gb dd3 ram Microsoft windows server 2012 gigabit network . Devices Sony KDL55W805A, ps3, 2 sony bravia 2011, 5 android devices 2 of them samsung galaxy s3 running bubble upnp and serviigo, netgem netbox , 2 laptops XBMC windows 8
mbarnig
Post Wed Mar 13, 2013 9:52 pm
Re: netgem netbox
Have a look at my post
http://forum.serviio.org/viewtopic.php?f=5&t=9594#p65154
where a profile for the Netgem netbox is presented.
You have to change the transcoding rules for your audio files.
mbarnig
chrismallia
Post Thu Mar 14, 2013 9:18 am
Re: netgem netbox
thanks for your reply. I'm new with serviio, if it is possible would you kindly ex plane to me how to add the profile thanks (xml file)?
Post Thu Mar 14, 2013 11:20 pm
Re: netgem netbox
Did you do any research? check the serviio webpage (http://www.serviio.org/index.php?option ... icle&id=16), wiki and faq. There are also some sticky posts in this forum.
chrismallia
Post Fri Mar 15, 2013 12:52 pm
Re: netgem netbox
zip wrote:Did you do any research? check the serviio webpage (http://www.serviio.org/index.php?option ... icle&id=16), wiki and faq. There are also some sticky posts in this forum.
Thanks for your help again found all I needed
chrismallia
Post Sun Mar 17, 2013 5:19 pm
Re: netgem netbox
Hi I copied this in the profile, but when I did this serviio does not start i get a error
can anyone give me a full profile witch only transcodes dts audio? Thank you for all your help
<Profile id="netbox" name="SetTopBox Netgem" extendsProfileId="1">
<Detection>
<UPnPSearch>
<FriendlyName>netbox</FriendlyName>
</UPnPSearch>
</Detection>
Post Sun Mar 17, 2013 7:55 pm
Re: netgem netbox
Try to use Samsung B series profile, it transcodes DTS to AC3.
chrismallia
Post Sun Mar 17, 2013 11:08 pm
Re: netgem netbox
zip wrote:Try to use Samsung B series profile, it transcodes DTS to AC3.
Thanks it worked great problem solved
Users browsing this forum: No registered users and 80 guests
