netgem netbox
• Page 1 of 1
I have a Netgem netbox witch only kneeds transcoding for dts audio, in serviio I did not find a profile for it can one be created thanks ?
server running serviio PRO and media browser Intel dual core g2030 3.0Ghz 8gb dd3 ram Microsoft windows server 2012 gigabit network . Devices Sony KDL55W805A, ps3, 2 sony bravia 2011, 5 android devices 2 of them samsung galaxy s3 running bubble upnp and serviigo, netgem netbox , 2 laptops XBMC windows 8
Re: netgem netbox
Have a look at my post
http://forum.serviio.org/viewtopic.php?f=5&t=9594#p65154
where a profile for the Netgem netbox is presented.
You have to change the transcoding rules for your audio files.
mbarnig
mbarnig
Re: netgem netbox
thanks for your reply. I'm new with serviio, if it is possible would you kindly ex plane to me how to add the profile thanks (xml file)?
Re: netgem netbox
Did you do any research? check the serviio webpage (http://www.serviio.org/index.php?option ... icle&id=16), wiki and faq. There are also some sticky posts in this forum.
Petr
Help translate Serviio
Re: netgem netbox
zip wrote:Did you do any research? check the serviio webpage (http://www.serviio.org/index.php?option ... icle&id=16), wiki and faq. There are also some sticky posts in this forum.
Thanks for your help again found all I needed
Re: netgem netbox
Hi I copied this in the profile, but when I did this serviio does not start i get a error
can anyone give me a full profile witch only transcodes dts audio? Thank you for all your help
<Profile id="netbox" name="SetTopBox Netgem" extendsProfileId="1">
<Detection>
<UPnPSearch>
<FriendlyName>netbox</FriendlyName>
</UPnPSearch>
</Detection>
<Detection>
<UPnPSearch>
</UPnPSearch>
</Detection>
Re: netgem netbox
Try to use Samsung B series profile, it transcodes DTS to AC3.
Petr
Re: netgem netbox
zip wrote:Try to use Samsung B series profile, it transcodes DTS to AC3.
Thanks it worked great problem solved
• Page 1 of 1
Users browsing this forum: Google [Bot] and 22 guests
