Problem with putting subtitles! help please
i123b456
Post Fri Jul 05, 2013 5:58 pm
i have PS3(Sony playstaion 3) and recently i started using serviio to stream movies and series to the PS3 ,with out subtitles so far.
yesterday i tried to put subtitles , at the options i put on :
-enable substitles
-enable exctraction
-enable burned in subtitles when required
but when i played the video on my screen through the ps3 , the video did even work ! there was kind of a problem , it didnt even start playing.
the subtitles work on my pc i can a sure that.
How do i put subtitles and make the video working !?!
i123b456
Post Sat Jul 06, 2013 12:40 pm
Re: Problem with putting subtitles! help please
bump
Post Sat Jul 06, 2013 9:41 pm
http://www.serviio.org/index.php?option ... icle&id=33
Also post our log to see what failed.
i123b456
Post Fri Jul 26, 2013 12:53 pm
zip wrote:http://www.serviio.org/index.php?option=com_content&view=article&id=33
What should i post? i am sorry i am not good at this things
Post Fri Jul 26, 2013 1:19 pm
Enable detailed logging and post serviio log file here.
i123b456
Post Fri Jul 26, 2013 3:32 pm
Illico wrote:Enable detailed logging and post serviio log file here.
i dont quite understand, do u have maybe skype or something ?that we can send massgese more quickly
i123b456
Post Sun Jul 28, 2013 5:50 pm
Post Mon Jul 29, 2013 1:38 am
I think you need to let people know what part you don't understand. Click on the words "detailed logging" and follow the instructions there - this will involve:
  • editing the log4j.xml file in your serviio\config folder as detailed in that post.
  • Restarting your PC to enable detailed logging
  • Play/attempt to a few of your files with subtitles from your TV
  • Post a copy of the serviio.log file located in your serviio\log folder back into this topic.
  • Once finished re-edit the log4j.xml file to set it back to "INFO" and then restart your PC. This will turn detailed logging off.
i123b456
Post Thu Aug 08, 2013 9:54 am
DenyAll wrote:I think you need to let people know what part you don't understand. Click on the words "detailed logging" and follow the instructions there - this will involve:
ok now i got it sir, thank you and i will do it soon
