Serviio Not showing
Studentmac
Post Sat Aug 03, 2013 1:30 pm
Serviio Not showing
Serviio isnt showing up on my Samsung D8000 smart tv, been using serviio for quoite some time but today its stopped showing.
Usually stopping and restarting or resetting pc is enough to get it to connect again but its not this time.
under status on serviio i can see my tv showing in green so not sure why its not showing on tv.
Anyone have some ideas?
thanks
Post Sun Aug 04, 2013 12:05 pm
Re: Serviio Not showing
Read the FAQ for tsome tips.
Also post your detailed log.
Studentmac
Post Sun Aug 04, 2013 12:16 pm
Thanks for post,
tried FAQ but its not helped
firewall is set to allow serviio
serviio can see my tv and tv can see pc through windows media player. just that tv cant view serviio
Post Sun Aug 04, 2013 1:52 pm
post the log please
Studentmac
Post Sun Aug 04, 2013 2:34 pm
where do i find the log?
Studentmac
Post Sun Aug 04, 2013 2:45 pm
think i know what you mean, the log text file in program folder but it says "Your message contains 1948102 characters. The maximum number of allowed characters is 60000."
Post Sun Aug 04, 2013 3:27 pm
viewtopic.php?f=5&t=1289
You can zip the log up and attach here
Studentmac
Post Sun Aug 04, 2013 3:53 pm
log attached
serviio.zip
(179.62 KiB) Downloaded 409 times
Post Sun Aug 04, 2013 3:59 pm
Is your PC 192.168.1.64?
I assume all your devices are on the same subnet 192.168.1.x ?
If both yes, it's most likely a firewall on your PC blocking UDP 1900 or TCP 8895. It might be an antivirus software too.
fscussel
Post Thu Aug 08, 2013 9:11 pm
I have exactly the same problem, but it started happening only today, i've updated to 1.3 yesterday night. TV is a samsung E490. Should I open a new topic?
update: after rebooting my router it is back working. Now 2 problems:
1) The access groups are not working
2) It's not showing my mp3 music collection, I've add it's folder.
(354.12 KiB) Downloaded 486 times
Post Thu Aug 08, 2013 10:25 pm
How are they not working? How did you set them up? Do you have a detailed log of browsing a restricted folder?
The same with mp3 - need detailed log.
fscussel
Post Fri Aug 09, 2013 12:48 am
zip wrote:How are they not working? How did you set them up? Do you have a detailed log of browsing a restricted folder?
I've uploaded a log with last post. Is there another log? I set No restriction and Limit access and it appears to don't change anything.
Post Fri Aug 09, 2013 6:27 am
You need to do a detailed log (click on the words "detailed log" and follow the instructions). This wlll give zip more information on what is happening.
Cheers
fscussel
Post Fri Aug 09, 2013 12:33 pm
DenyAll wrote:You need to do a detailed log (click on the words "detailed log" and follow the instructions). This wlll give zip more information on what is happening.
Cheers
Ok thanks, I will let it run for a while to generate a good log and then I will upload.
Post Fri Aug 09, 2013 4:59 pm
Did you assign your renders to the appropriate categories as well as the shared folders?
Shame you didn't raise this during the beta (you being betatester)
fscussel
Post Fri Aug 09, 2013 5:28 pm
I asked to be betatester but you didn't answer the PM. I've attached the detailed log. at around 11:20 the program closed, service closed I don't know how.
(377.96 KiB) Downloaded 474 times
Post Fri Aug 09, 2013 10:12 pm
It is updating your mp3 files. Then it stopped, but I don't see the reason. And then it couldn't find your network card - not sure what happened there.
I read your PM and added you to betatesters group. So you had beta access for some time (your username if purple). I don't normally reply to everyone who I add.
fscussel
Post Sat Aug 10, 2013 12:58 pm
zip wrote:It is updating your mp3 files. Then it stopped, but I don't see the reason. And then it couldn't find your network card - not sure what happened there.
Humm yeah I didn't really know you had add me. I will keep looking into the problem to see if I find anything else.
fscussel
Post Thu Aug 22, 2013 12:02 am
apparently it was related to my router which was not working very stable. now that i've replaced it I will keep looking, but it appears to be ok now.
Users browsing this forum: Baidu [Spider] and 20 guests
