ONline plugins wont delete with new install ?
Deleted serviio... dir was completely gone...
Reinstalled.... all empty..
BUT there are still some 4 version1 online plugins... that I did NOT install...
Where can I find those to delete them ?
will wrote:The console and server version must be the same (in your case 1.2.1 because 1.3 is not available for the Synology NAS yet). ServiiDroid works because I designed it to work with any version as I didn't want to have to publish a seperate version of Google Play for every version of Serviio.
Plugins will be in serviio/plugins on your NAS (not your Windows PC), check the details of the installer you used to get it onto your NAS, it should say exactly where.
crackedtooth wrote:dumb issues with plugins is
They were in /volume1/public/serviio/plugins and NOT in the newly created /volume1/@appstore/Serviio/plugins dir. So old and new directory....... so some confusion over that.
So for console just go back to 1.2.1 and ti should be fine?
will wrote:Just change the version to get the link you want e.g. http://download.serviio.org/releases/se ... -setup.exe
