ONline plugins wont delete with new install ?
crackedtooth
Post Sat Aug 24, 2013 2:21 pm
Had issues... needed to reinstall all.
Deleted serviio... dir was completely gone...
Reinstalled.... all empty..
BUT there are still some 4 version1 online plugins... that I did NOT install...
Where can I find those to delete them ?
crackedtooth
Post Sat Aug 24, 2013 4:15 pm
Re: ONline plugins wont delete with new install ?
.. are they stored in separate location ?
Post Sat Aug 24, 2013 4:22 pm
The console and server version must be the same (in your case 1.2.1 because 1.3 is not available for the Synology NAS yet). ServiiDroid works because I designed it to work with any version as I didn't want to have to publish a seperate version of Google Play for every version of Serviio.
Plugins will be in serviio/plugins on your NAS (not your Windows PC), check the details of the installer you used to get it onto your NAS, it should say exactly where.
crackedtooth
Post Sat Aug 24, 2013 4:40 pm
will wrote:The console and server version must be the same (in your case 1.2.1 because 1.3 is not available for the Synology NAS yet). ServiiDroid works because I designed it to work with any version as I didn't want to have to publish a seperate version of Google Play for every version of Serviio.
dumb issues with plugins is
They were in /volume1/public/serviio/plugins and NOT in the newly created /volume1/@appstore/Serviio/plugins dir. So old and new directory....... so some confusion over that.
So for console just go back to 1.2.1 and ti should be fine?
Synology Serviio 1.2.1 package for Synology NAS there is no more recent server.
So where to download the old 1.2.1 console version ? just google to find one? official downloads not there it seems?
Post Sat Aug 24, 2013 4:44 pm
crackedtooth wrote:dumb issues with plugins is
Yes I belive they are there instead to make it easy to add them as that location is shared by default.
Yes, you need to use 1.2.1 with a 1.2.1 server.
crackedtooth
Post Sat Aug 24, 2013 4:48 pm
1.2.1. still somewhere on official download server ? (never like alternative sources)
since Synlology package only has 1.2.1 .. I need windows 1.2.1 for the console than
Post Sat Aug 24, 2013 5:05 pm
Just change the version to get the link you want e.g. http://download.serviio.org/releases/se ... -setup.exe
crackedtooth
Post Sat Aug 24, 2013 5:09 pm
will wrote:Just change the version to get the link you want e.g. http://download.serviio.org/releases/se ... -setup.exe
That solved it.
I think you will get more questions about this.. Why?
Synology package is 1.2.1 and nothing newer
and windows versio 1.2.1 automatically advises to update to 1.3.1... so you do that automatically since programs suggests it
