SMI Subtitles Question
zepinos
Post Thu Sep 12, 2013 12:59 am
Can't seem to get Serviio to play subtitles on an SMI file. This file encode "euc-kr(or iso-8859-1, MS949, etc...)".
Well as English sentences are displayed. But, the subtitles do not appear when including non-ascii characters. If change the extension to SRT come without problems.
ex) appear : <SYNC Start=5000><P Class=KRCC><font color=violet>TEST
ex) not appear : <SYNC Start=5000><P Class=KRCC><font color=violet>TEST한글
Any help in solving. Thank you in advance...
Post Thu Sep 12, 2013 3:39 pm
Re: SMI Subtitles Question
Is this when burning subtitles in?
Can you attach the subs file?
zepinos
Post Thu Sep 12, 2013 3:53 pm
Not checked "Enable transcoding" option, and only checked "Enable subtitles" at "subtitles" tab.
Back.to.the.Future.1985.DVDRip.XviD.DTS.CD1-WAF.zip
(13.4 KiB) Downloaded 354 times
Post Sun Sep 15, 2013 6:53 pm
So Serviio currently doesn't use the character encoding option for softsubs (when converting .smi to .srt), but I'll add it. You'd then use
cp949
as the character encoding option - you should be able to try it now with burned-in subtitles.
You can use the rename workaround for now before 1.4 is released.
zepinos
Post Mon Sep 16, 2013 1:27 am
Thanks for the help!!! :D
