Can't play some movies
alis5
Post Mon Jan 13, 2014 7:38 pm
I have some problems playing some movies on my new TV. It's a Philips 32PFL4508T.
Some movies work and some don't.
The server I use (with serviio on) is a Ubuntu-server 12.04.
If I use my Phone (S3) and your ServiiGo, I can play all movies.
But with UPnPlay, I can't play most of the movies. I tested with an old avi, then it asked me what renderer to choose, Android or a laptop that was on, in the network (not the server with serviio installed).
I must confess, I don't 100% sure I understand DLNA correct, does the server (Serviio) do all the decoding and only sends out a "copy" of the "screen"? Or does the TV/phone or whatever do some decoding of the movie as well? :?:
If I type: ffmpeg -i <your_file_location> For a movie that don't work on the TV or UPnPlay (but works with ServiiGo on my S3) I get this:
ffmpeg version 0.8.9-4:0.8.9-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
built on Nov 9 2013 19:12:07 with gcc 4.6.3
This program is only provided for compatibility and will be removed in a future release. Please use avconv inst ead.
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/125) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Movie/Riddick/Riddick_x264.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
creation_time : 2014-01-01 04:06:39
Duration: 02:06:47.64, start: 0.000000, bitrate: 1018 kb/s
Stream #0.0(und): Video: h264 (High), yuv420p, 1280x536, 921 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 93 kb/s
creation_time : 2014-01-01 04:06:45
I also have one more problem, I can't get the subtitles to work. :(
Tried the most of the settings (beloning to this), but still no subs, nomatter what devise I use.
accelleratii
Post Thu Jan 16, 2014 12:00 pm
Re: Can't play some movies
do you have profile enabled (chosen) for your tv in serviio console, do you gave Transcoding on?
as for dlna question, yes pc does all the work, and send rendered stream to your device, most devices are ok with GENERAL profile, and some need specific transcoding profile to be chosen.
as for subs, have no idea, could never make them work myself, but i never cared of them too.
alis5
Post Thu Jan 16, 2014 9:55 pm
Thanks for your help, accelleratii.
But I must cunfess that I don't fully understand you.
"do you have profile enabled (chosen) for your tv in serviio console, do you gave Transcoding on?"
Where do I see this? In the consol (Status tab) I can see the TVs IP, and it's green. But it can't understand the TVs name (which windows media player can). Is it here you mean that I should "give it Transcoding on"? How do I do that? And how do I enable the TV here, I can only have "Device allowed"?
I have transcoding on in tab "Delivery". Is it that you mean?
You also say that I can change transcoding profile, how do I do that?
Is it the Transcoded files location? I thought that was only a temp-folder during transcoding.
Thanks again for the help.
accelleratii
Post Fri Jan 17, 2014 11:56 am
alis5 wrote:I have transcoding on in tab "Delivery". Is it that you mean?
yes, just keep it enabled
and here are the profiles:
when you choose correct profile (your TV model)
and have the Transcoding enabled, it should play the files on your tv
