Jet Stream attacking me!!
• Page 1 of 1
Re: Jet Stream attacking me!!
Clearly you like that movie
Check for .jpg files in your folder (may be hidden) and remove. What type of metadata information are you gathering (online, .nfo files) etc?
ps: same issue as viewtopic.php?f=5&t=12680&p=77823&hilit=same+thumbnail#p77823 and viewtopic.php?f=5&t=12152&p=76032&hilit=same+thumbnail#p76032
The difference here is it's not just the thumbnail, it's the title too. So it might be a .nfo file (if you are using XBMC metadata)
Petr
Help translate Serviio
I had the same problem, I found out that all my bluray movies had these small clips in that serviio named Jet stream.
cid6 wrote:I had the same problem, I found out that all my bluray movies had these small clips in that serviio named Jet stream.
how can I scan and find these hidden clips?
thxs
• Page 1 of 1
