Jet Stream attacking me!!
sleky
Post Mon Sep 16, 2013 6:27 pm
Has anyone seen this? I'm sure its picking up a file someplace, but ugh. Turning up logging, but its going to fill rather quickly, an easy grep I can use or specific logging I can enable to hunt this issue down would be appreciated. Hehe!
Post Mon Sep 16, 2013 11:23 pm
Re: Jet Stream attacking me!!
Clearly you like that movie :)
Check for .jpg files in your folder (may be hidden) and remove. What type of metadata information are you gathering (online, .nfo files) etc?
ps: same issue as viewtopic.php?f=5&t=12680&p=77823&hilit=same+thumbnail#p77823 and viewtopic.php?f=5&t=12152&p=76032&hilit=same+thumbnail#p76032
Post Tue Sep 17, 2013 12:30 pm
The difference here is it's not just the thumbnail, it's the title too. So it might be a .nfo file (if you are using XBMC metadata)
cid6
Post Fri Jan 17, 2014 2:08 pm
I had the same problem, I found out that all my bluray movies had these small clips in that serviio named Jet stream.
Cylac
Post Thu Jan 23, 2014 2:06 am
cid6 wrote:I had the same problem, I found out that all my bluray movies had these small clips in that serviio named Jet stream.
how can I scan and find these hidden clips?
thxs
Users browsing this forum: No registered users and 49 guests
