Failed to connect (Profile x264 ServiiGo)
ilicitano
Post Mon Nov 24, 2014 4:36 pm
I'm using ServiiGo (android) to connect to my serviio server and everything works fine if I use the Profile "mpeg2" in Settings, but if I choose "x264" cannot reproduce any video. I always get "failed to connect".
I tried with several video players (including internal) with no success.
Coud anyone tell me how to solve this?
Thank you,
Post Tue Nov 25, 2014 7:53 am
Re: Failed to connect (Profile x264 ServiiGo)
Is your server running Linux, it may be an incompatible ffmpeg version. Are there any errors in the Serviio log?
ilicitano
Post Tue Nov 25, 2014 8:59 am
I'm running my server under Windows 7 SP1 x64.
The log file say:
WARN [ServiioStatusService] AuthenticationException occured. Returning error code 401 to the REST layer. Message: No authentication token has been provided for a restricted resource.
Any idea? :cry:
Post Tue Nov 25, 2014 9:08 am
Have you changed the version of ffmpeg?
ilicitano
Post Tue Nov 25, 2014 9:12 am
Yes, I downloaded the last version of ffmpeg from http://ffmpeg.zeranoe.com/builds/
ilicitano
Post Tue Nov 25, 2014 9:37 am
I tried with the ffmpeg version included in serviio installer but I have the same issue.
ilicitano
Post Wed Nov 26, 2014 7:17 am
So is this only happening to me? any solution?
Post Wed Nov 26, 2014 7:55 am
Did you restart Serviio after switching back to the version of ffmpeg that came with it (to make sure it cleaned out any temporary transcoding files)? Can you also turn on detailed logging, try again and then post the log (with ip/dns name redacted).
ilicitano
Post Wed Nov 26, 2014 8:17 am
Hey Will I had to restart the server. Now it's working using the ffmpeg version included with Serviio installer.
Thank you!
Post Wed Nov 26, 2014 8:48 am
ilicitano wrote:Hey Will I had to restart the server. Now it's working using the ffmpeg version included with Serviio installer.
Thank you!
Great, Serviio would have already transcoded the file (with the missing authentication info in the playlist), so wouldn't have known to try again with the new ffmpeg version.
Users browsing this forum: Google [Bot] and 34 guests
