Random audio list only plays first 2 songs
tangerine2012
Post Mon Aug 13, 2012 10:58 am
Running Servio 1.0.1 / Windows XP / Sony BluRay BDP-S370
Hi - this problem was reported in 2011 at https://bitbucket.org/xnejp03/serviio/i ... -for-music. I'm experiencing the same problem i.e.
Selecting Random in audio returns a randomised list of tracks to the BluRay player. The first track plays and when complete moves on to the second, but after the second track is complete, playback stops and returns to the complete random list of tracks. Expected behaviour: move to next track. The same problem occurs when I manually skip through the tracks i.e. when I try to skip to the third track, playback stops and returns to the track list.
I've had a look in the log file but can't see anything obvious to do with this problem. I've uploaded it anyway
Any thoughts? The Random audio list is a fantastic feature if it would only work...
Thanks, Mike
Serviio log
(86.33 KiB) Downloaded 566 times
Post Mon Aug 13, 2012 6:37 pm
Re: Random audio list only plays first 2 songs
I will need detailed log of you browsing to the category and playing or skipping the 3 songs (see my signature for detailed log info)
tangerine2012
Post Mon Aug 13, 2012 9:56 pm
Thanks Petr. Here's a detailed log file in debug mode.
I navigated to the Random music category twice and each time it only played the first 2 tracks.
If it's any help, the second attempt involved playing the following tracks in the order listed
De Nua - Feat. Ana Moura
Billy 4
All I Have Is Memories
The first 2 played ok and appear in the log file, but the 3rd (All I Have) doesn't appear in the log.
Thanks, Mike
tangerine2012
Post Mon Aug 13, 2012 9:57 pm
sorry - forgot to attach the log ...
Serviio log in debug mode - problem playing Random music
(136.6 KiB) Downloaded 579 times
Post Tue Aug 14, 2012 12:29 pm
How long is the Billy song? I see it started playing around 22:43:22 and then the server stopped 22:44:10 - did it stop by itself or did you initiate server stop?
tangerine2012
Post Wed Aug 15, 2012 9:20 am
After the "Billy" track (the 2nd track) had started, I skipped forward to the next track using the Blu-ray remote control at which point the server stopped playing and returned to the random song list.
If it helps I can attach another log file where each track plays in its entirety (rather than manually skipping to the next track). Let me know if you need this. Thanks, Mike
henry's cat
Post Thu Aug 16, 2012 8:57 am
I just recently downloaded Serviio and am impressed having had problems with Windows Media Player 11.
I can confirm that the random play feature does only play the first two tracks on the list of randomly sorted tracks. It's a shame it doesn't work properly as my Sony SMP-N100 does not have a random play feature, but otherwise Serviio is great! :)
maltmoose
Post Mon Aug 20, 2012 6:34 pm
I get the same bug with ubuntu server 12.04 and Sony BluRay BDP-S370.
This bug was present in version 0.6 and 1.0.1.
I notice will on this forum whos a dev and a beta tester has a bdp s370 in his forum footer, im sure he would check this out :)
Post Mon Aug 20, 2012 6:42 pm
maltmoose wrote:This bug was present in version 0.6 and 1.0.1.
I'm not sure its due to serviio.
I had this behavior with my Sony player, but it happens sporadically with some files only. I have not tested more than that.If it happens again, I would look.
maltmoose
Post Mon Aug 20, 2012 7:31 pm
Entirely possible that its a sony bug not a serviio one but i'd have thought this is less likley if it affects different units. any non sony users get this?
hmm wrong forum i guess to ask that
Post Tue Aug 21, 2012 6:25 pm
maltmoose wrote:hmm wrong forum i guess to ask that
I can move this post temporarily to to be more visible by other users...
tangerine2012
Post Thu Aug 23, 2012 9:57 am
Actually, it would be good if you could move this problem to a more general forum. I posted the original fault - in hindsight, perhaps it wasn't such a good idea to put it in the Sony forum. As others have said, it would help if we know if others have experienced the same on other non-Sony devices. Thanks, Mike
Doruho
Post Sun Mar 17, 2013 3:46 pm
Greetings,
I've recently installed Serviio 1.2 Pro (still in evaluation mode) on a Windows 7 32-bit PC. Has this thread continued somewhere else? Has a solution been found?
I too am seeing the same problem of random play stopping after the first two songs and then having to play each song after that individually on my Sony SMP-N100. Prior to installing Serviio, I was playing Windows 7 Media Player playlists without such a problem.
Thank you.
Post Sun Mar 17, 2013 7:04 pm
It's a design flaw in Serviio with the Sony players, so no solution to this exists atm.
Doruho
Post Mon Mar 18, 2013 4:07 am
Thank you Petr for your response. I am still evaluating Serviio, and may still stay with it. I've had other problems with my Sony player as well. The Sony does not play MP3 files or playlists from Windows 8 Media Player. I have yet to try Serviio on Windows 8. That will be next.
-Don
Ghelderode
Post Wed Jan 08, 2014 8:44 am
Running Servio 1.4 Pro edition / Windows 7 Ultimate 64-bit / Sony BDP-S480 (Firmware version : M07.R.0624)
Hello Petr !
Still no solution regarding this issue?
Post Mon Jan 13, 2014 5:40 am
No. It's quite a lot of work for minority of users, so other things have priority.
Ghelderode
Post Mon Jan 13, 2014 7:11 am
I understand. Thank you for your answer!
martcaster
Post Fri May 23, 2014 10:59 am
Hi! Petr. Posting from UK. I too have problem "Random stops after 2 songs" Any chance of a solution any time soon? I have Sony BDP 370. Alongside Serviio it plays everything perfectly save for this frustrating limitation. Any help gratefully received. Thanks in advance.
Mart.
