Many thanks to SERVIIO
tanhai99
Post Thu Jan 05, 2012 6:50 pm
I am a SERVIIO user in the U.S. I'd like to say many thanks to SERVIIO. I would like to stream pics and music files from my PC to my TV via Sony Blu Ray player S580. I had tried to do that by using Windows Media Player unsuccessfully. Windows Media Play on my Windows Vista does not seem to work with my Sony Blu Ray player at all, even though from information I got, it should have worked. Perhaps, if I had spent 100 dollars to upgrade to Windows 7, Windows Media Player would have "played" better with my Sony Blu Ray S580 but I would not spend 100 dollars simply for that purpose. Then yesterday I discovered SERVIIO on the Internet and SERVIIO 0.6 works like a charm for me. Easy set up/installation. My Sony Blu Ray immediately recognized SERVIIO. Simply move the files I want to stream from my PC to SERVIO Console. I especially like the STATUS tab. It's nice to know what is going on with the media server.
I like SERVIIO 0.6 so much I was not hesitant in making a small donation afterward. :D
Post Thu Jan 05, 2012 7:26 pm
Re: Many thanks to SERVIIO
0.6.1 released in few days/weeks will be even better.
eclp
Post Thu Jan 05, 2012 7:45 pm
Cerberus wrote:...even better.
A little information which everything will be better would be nice.
What will there be new, what can you expect?
Post Thu Jan 05, 2012 7:56 pm
and spoil the supprise. no chance. ;)
goodthanks15
Post Thu Jan 05, 2012 10:25 pm
Just wanted to add to this. I have a sony bluray bdp-s370. I was able to use windows media player in windows 7 without too much trouble. My issues were mainly customisation and speed.
I just wanted 2 folders (TV Shows, Movies), for the life of me I couldnt figure out how to turn off all the extra folders windows threw in there. Also when browsing folders with a moderate amount of files inside it would pause for upwards of 20 seconds when trying to add files to the cached list. With the amount of files I have it would take up to 5 minutes sometimes just to browse the full folder list.
So I searched for a replacement and serviio is the first one I came across. Setting up folders is so simple, just untick the boxes. At most the only pause I get now is about 3 seconds but that hardly ever happens. When I enter a folder I can see the cache is being populated way faster than windows media player used too.
So I just wanted to say thanks for an excellent program. You made my life a little happier :)
Edit: Got desktop streaming to work. Pretty cool although I think you need a PC with a little grunt. I have a decent computer but Playing a video while VLC is streaming the desktop seemed to cause lag on the TV. That being said there is a good chance the settings I used were not ideal. In any case it is a cool feature.
firenice03
Post Fri Jan 06, 2012 12:55 am
1st off I wanna KUDO's to the developers, testers and guru's alike...
Been using 0.6.0.1 for not that long, but had compared it against a couple similar apps (that I wont mention.. they all gotta start somewhere) and WOW, excellent!!! :D
Noticed and downloaded 0.6.1 :) - Cant wait to try it...
Anyone looking to set up, read thru the posts - you WILL find your answer, the app is intuitive and with minimal modifications (XML codes ect.. it will do what you need).
Set up:
Panasonic Viera 50" TCP50x3
Android - Huawai Ascend (MoboPlayer, UPnPlay/HomeDia/Skifta (multiple for tests)
*Running Serviio (.6.0 & .6.1) on 2 XP boxes (ready... both P4 w/ 512mb ram - 1 sys wireless/1 wired (FWIW - no lag from system))
**Next I'll be setting up some feeds in 0.6.1 - then installing on the better system...
Thanks!!!
Stardust
Post Sat Jan 07, 2012 10:00 pm
goodthanks15 wrote:Hi,
Goodthanks,
could you please post the settings you used for desktop streaming?
I have tried a lot of different settings, but my Samsung TV can´t find the stream. What am I doing wrong?
1.) IP address - I used 127.0.0.1 as address.
2.) Transcoding - I enabled/disabled transcoding in VLC and serviio
3.) Video format - I tried H264, MP4, MP2
4.) Source types of stream - tried RTP, HTTP, UDP
Hm....
Thanks for a quick reply in advance!
Stefan
Samsung UE37C5700, Server-PC: Mobile T5500 on Abit iL90MV (945GT chipset)
Post Sat Jan 07, 2012 10:58 pm
Goodthanks,
Hm....
Stefan
did you try looking on serviio wiki site ? wiki.serviio.org :roll:
Stardust
Post Sun Jan 08, 2012 10:04 pm
Goodthanks,
Hm....
Stefan
Oops. No. Shame on me. :|
Just found it in the Wiki... Plugins -> "Stream Anything Your PC Can Play (Serviio 0.6.1+)" http://wiki.serviio.org/doku.php?id=stream_pc
I´ll try that tomorrow. Thanks :)
Stardust
Post Sun Jan 08, 2012 11:41 pm
Just tried it for an hour or so.... This time I used dshow instead of screen, exactly as described in the wiki. Even reinstalled serviio....
But still the problem remains. I should have said that
- VLC produces a stream.
- And this stream can be played by another VLC, if I enter http://192.168.0.194:8081 (my PC) as source.
But if I add this address to serviio, on my TV it simply won´t show up under videos->online.
If I add RSS feeds, it works. But not with this bloody livestream :evil:
Post Sun Jan 08, 2012 11:47 pm
does this return a value (when run on the serviio box):
ffmpeg -i http://192.168.0.194:8081/
Post Mon Jan 09, 2012 3:47 am
You will only get a response if the streaming has been started, similarly you can only add the stream link to Serviio if the streaming has been started. This is now in the Wiki. [b]Stream Anything to Your TV that your PC can Play [/b] http://wiki.serviio.org/doku.php?id=stream_pc
Please post future comments regarding the use of desktop streaming in this other thread so I can update the wiki as appropriate.
streaming desk top to tv http://forum.serviio.org/viewtopic.php?f=4&t=4660&p=32269
Here is the ffmpeg for the stream produced by StreamDesktop.bat
C:\Users\John>ffmpeg -i http://192.168.1.10:8081/
ffmpeg version N-33591-gf884ef0, Copyright (c) 2000-2011 the FFmpeg developers
  built on Oct 13 2011 02:23:02 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 21. 0 / 51. 21. 0
  libavcodec   53. 20. 1 / 53. 20. 1
  libavformat  53. 15. 0 / 53. 15. 0
  libavfilter   2. 43. 6 /  2. 43. 6
  libpostproc  51.  2. 0 / 51.  2. 0
[mpeg2video @ 03AE05A0] mpeg_decode_postinit() failure
[mpegts @ 003E84E0] PES packet size mismatch
    Last message repeated 1 times
[mpegts @ 003E84E0] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 48.00 (48/1)
-> 24.00 (48/2)
Input #0, mpegts, from 'http://192.168.1.10:8081/':
  Duration: N/A, start: 46244.137844, bitrate: 10192 kb/s
  Program 1
    Stream #0:0[0x44]: Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16
, 192 kb/s
    Stream #0:1[0x45]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
, 1280x768 [SAR 4:5 DAR 4:3], 10000 kb/s, 24 fps, 24 tbr, 90k tbn, 48 tbc
Stardust
Post Mon Jan 09, 2012 1:00 pm
jhb50 wrote:..., similarly you can only add the stream link to Serviio if the streaming has been started. This is now in the Wiki. [b]Stream Anything to Your TV that your PC can Play [/b] http://wiki.serviio.org/doku.php?id=stream_pc
Thanks guys! It works!!!
I removed the stream from serviio, restarted my PC, ran desktop.bat, then re-added the stream to serviio. I connected a mouse keyboard to my Silex SX1000 USB device server next to the tv and voila: now I am able to control the downloads on my Server via LAN. ABSOLUTELY phantastic!!!! A new dimension of serviio!
P.S.: Just FYI - my output with working desktopstream:
c:\Program Files\Serviio\lib>ffmpeg -i http://192.168.0.194:8081/
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtim
udetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[mpeg2video @ 02241020] mpeg_decode_postinit() failure
    Last message repeated 8 times
[mpegts @ 01617f40] max_analyze_duration 5000000 reached at 5015467
[mpegts @ 01617f40] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 48.00 (48/1) -> 24.92 (299/12)
Input #0, mpegts, from 'http://192.168.0.194:8081/':
  Duration: N/A, start: 8788.108467, bitrate: 10192 kb/s
  Program 1
    Stream #0:0[0x44]: Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16, 192 kb/s
    Stream #0:1[0x45]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 1280x720 [SAR 3:4 DAR 4:3], 10000 kb/s, 26.95 fps, 24.92 tbr, 90k tbn, 48 tbc
Return to User experiences
