Many thanks to SERVIIO
I like SERVIIO 0.6 so much I was not hesitant in making a small donation afterward.
Cerberus wrote:...even better.
eclp wrote:Cerberus wrote:...even better.
A little information which everything will be better would be nice.
What will there be new, what can you expect?
goodthanks15 wrote:Hi,
Just wanted to add to this. I have a sony bluray bdp-s370. I was able to use windows media player in windows 7 without too much trouble. My issues were mainly customisation and speed.
I just wanted 2 folders (TV Shows, Movies), for the life of me I couldnt figure out how to turn off all the extra folders windows threw in there. Also when browsing folders with a moderate amount of files inside it would pause for upwards of 20 seconds when trying to add files to the cached list. With the amount of files I have it would take up to 5 minutes sometimes just to browse the full folder list.
So I searched for a replacement and serviio is the first one I came across. Setting up folders is so simple, just untick the boxes. At most the only pause I get now is about 3 seconds but that hardly ever happens. When I enter a folder I can see the cache is being populated way faster than windows media player used too.
So I just wanted to say thanks for an excellent program. You made my life a little happier
Edit: Got desktop streaming to work. Pretty cool although I think you need a PC with a little grunt. I have a decent computer but Playing a video while VLC is streaming the desktop seemed to cause lag on the TV. That being said there is a good chance the settings I used were not ideal. In any case it is a cool feature.
Stardust wrote:goodthanks15 wrote:Hi,
Goodthanks,
could you please post the settings you used for desktop streaming?
I have tried a lot of different settings, but my Samsung TV can´t find the stream. What am I doing wrong?
1.) IP address - I used 127.0.0.1 as address.
2.) Transcoding - I enabled/disabled transcoding in VLC and serviio
3.) Video format - I tried H264, MP4, MP2
4.) Source types of stream - tried RTP, HTTP, UDP
Hm....
Thanks for a quick reply in advance!
Stefan
Cerberus wrote:Stardust wrote:goodthanks15 wrote:Hi,
Goodthanks,
Hm....
Stefan
did you try looking on serviio wiki site ? wiki.serviio.org
C:\Users\John>ffmpeg -i http://192.168.1.10:8081/
ffmpeg version N-33591-gf884ef0, Copyright (c) 2000-2011 the FFmpeg developers
built on Oct 13 2011 02:23:02 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 21. 0 / 51. 21. 0
libavcodec 53. 20. 1 / 53. 20. 1
libavformat 53. 15. 0 / 53. 15. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 6 / 2. 43. 6
libswscale 2. 1. 0 / 2. 1. 0
[mpeg2video @ 03AE05A0] mpeg_decode_postinit() failure
[mpegts @ 003E84E0] PES packet size mismatch
Last message repeated 1 times
[mpegts @ 003E84E0] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 48.00 (48/1)
-> 24.00 (48/2)
Input #0, mpegts, from 'http://192.168.1.10:8081/':
Duration: N/A, start: 46244.137844, bitrate: 10192 kb/s
Program 1
Stream #0:0[0x44]: Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16
, 192 kb/s
Stream #0:1[0x45]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
, 1280x768 [SAR 4:5 DAR 4:3], 10000 kb/s, 24 fps, 24 tbr, 90k tbn, 48 tbc
At least one output file must be specifiedjhb50 wrote:..., similarly you can only add the stream link to Serviio if the streaming has been started. This is now in the Wiki. [b]Stream Anything to Your TV that your PC can Play [/b] http://wiki.serviio.org/doku.php?id=stream_pc
c:\Program Files\Serviio\lib>ffmpeg -i http://192.168.0.194:8081/
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtim
udetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavfilter 2. 53. 0 / 2. 53. 0
[mpeg2video @ 02241020] mpeg_decode_postinit() failure
Last message repeated 8 times
[mpegts @ 01617f40] max_analyze_duration 5000000 reached at 5015467
[mpegts @ 01617f40] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 48.00 (48/1) -> 24.92 (299/12)
Input #0, mpegts, from 'http://192.168.0.194:8081/':
Duration: N/A, start: 8788.108467, bitrate: 10192 kb/s
Program 1
Stream #0:0[0x44]: Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16, 192 kb/s
Stream #0:1[0x45]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 1280x720 [SAR 3:4 DAR 4:3], 10000 kb/s, 26.95 fps, 24.92 tbr, 90k tbn, 48 tbc
