MP4 URL livestream not recognised
techwhizz
Post Sun Jun 25, 2017 2:40 pm
I have recently been trying to see if I can get any mp4 videos to play on Serviio, I am not sure about it but I do believe the older versions of Serviio had no issue in playing mp4 video file links from the internet. I recently tried to test to see if this link:
https://s54.escdn.co/jg6ns2rjibtu7m7cyy ... ccta/v.mp4
would play in Serviio but adding it as a livestream link made Serviio respond by saying that there is no stream present or the link was invalid.
I am not sure what the issue is here, I would appreciate some help.
Thank you very much!
techwhizz
Post Sun Jun 25, 2017 2:47 pm
Re: MP4 URL livestream not recognised
I have seen that if the request is sent with a referrer the link doesn't work. But running it in ffmpeg works, does Serviio somehow state a referrer in the links when it get the video?
I just had a look at this topic: viewtopic.php?t=22426, is it possible for us to specify having no referrer when retrieving the link if it was made in a plugin, it seems that Serviio when adding the link as a livestream requests something differently.
Serviio seems to send a referer when checking the livestream link e.g. Referer: http://localhost:23423/console/, I think this could be the issue, can this be changed or is it possible to change in a WebResource plugin?
Post Tue Jun 27, 2017 7:43 pm
I can't test this video, wrong IP.
But Serviio doesn't pass any referer to ffmpeg (but it may be that ffmpeg uses a built-in ffmpeg referer)
techwhizz
Post Wed Jun 28, 2017 12:53 am
zip wrote:I can't test this video, wrong IP.
Sorry, I didn't explain it very well. I was just saying that the Serviio Console puts the referrer in the request header when it checks if a livestream is valid or not. Since some websites do not want a referrer from another website, they block the request, if we were to remove the referrer from the Serviio header when checking a livestream, it may still work.
Thank you!
Post Wed Jun 28, 2017 10:19 pm
The console doesn't make the request, the server does.
techwhizz
Post Wed Jun 28, 2017 11:01 pm
zip wrote:The console doesn't make the request, the server does.
Sorry Mr. Nejedly, I am getting confused now. So when I enter a livestream URL to check if it is valid or not in the serviio console, does that then get passed onto the server? I was just saying if there was a way to avoid sending the referer header option in request headers from Serviio, it seems to give invalid results for links which should work.
Post Thu Jun 29, 2017 8:05 am
yes, the console just asks the server to run the check (which just executes ffmpeg -i "url") and sends the result back to the console. There is no referal used in the ffmpeg command (unless they use a built-in one in ffmpeg)
aaliyahsullivan
Post Wed Jul 26, 2017 9:47 am
This is interesting case here
Return to User experiences
