Transcode OGM for Samsung D Series
PJusa
Post Fri May 06, 2011 4:29 pm
great work - I am enjoying the software imensely. But I have some old OGM containers with XVID video and Vorbis Audio - is there any way I can get them to play or transcode. I tried a bit but I am really not too good at that. Here is my try which probably quite off:
<!-- transcode OGM -->
<Matches container="ogm" />
Appreciate any help and pointers!
Post Fri May 06, 2011 4:53 pm
Re: Transcode OGM for Samsung D Series
post ffmpeg -i of the file
PJusa
Post Sat May 07, 2011 1:19 am
i hope this helps:
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[vorbis @ 019028d0] Extradata missing.
[vorbis @ 018d3280] Extradata missing.
Last message repeated 104 times
Last message repeated 124 times
Last message repeated 31 times
Last message repeated 40 times
Last message repeated 30 times
Last message repeated 37 times
Last message repeated 27 times
Last message repeated 52 times
Last message repeated 13 times
[ogg @ 017ecea0] max_analyze_duration reached
Input #0, ogg, from '1.ogm':
Duration: 00:21:34.88, start: 0.000000, bitrate: 1134 kb/s
Chapter #0.0: start 0.000000, end 47.440000
title : Chapter 1
Chapter #0.1: start 47.440000, end 364.040000
title : Chapter 2
Chapter #0.2: start 364.040000, end 792.360000
title : Chapter 3
Chapter #0.3: start 792.360000, end 1258.240000
title : Chapter 4
Chapter #0.4: start 1258.240000, end 1294.880000
title : Chapter 5
Stream #0.0: Video: mpeg4, yuv420p, 512x384, 25 fps, 25 tbr, 25 tbn, 25 tbc
TITLE : Futurama - 101 - Spacepilot 3000
Stream #0.1(English): Audio: vorbis, 48000 Hz, 2 channels, 112 kb/s
LWING_GAIN : 01.00
LANGUAGE : English
Stream #0.2(Director's Comments): Audio: vorbis, 48000 Hz, 2 channels, 72 kb
/s
LWING_GAIN : 01.00
LANGUAGE : Director's Comments
I think I can recode the files to AVI but I am trying to learn how to do the transcoding. I have another format that i am having trouble with. Will post it below.
PJusa
Post Sat May 07, 2011 1:23 am
I just noticed that "High Quality Files" recorded from onlinetvrecorder.com dont play either. here are the details:
686-mingw32-
[avi @ 017ecea0] max_analyze_duration reached
Input #0, avi, from '1.avi':
encoder : Lavf52.102.0
Duration: 01:15:58.99, start: 0.000000, bitrate: 2394 kb/s
Stream #0.0: Video: h264, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 25 fps, 25
tbr, 25 tbn, 50 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 192 kb/s
Codec Details:
Codec: H264 - MPEG- AVC (part10) (H264)
Resolution: 720x576
Refreshrate: 25
Stream 1
Codec: MPEG Audio layer 1/2/3 (mpga)
Stereo
48000 Hz
Bitrate: 192 kb/s
I will run it in allshare to see if it works there.
Forgot: TV in question is a Samsung UA40D5000PR (2011 modell).
Installed Samsung AllShare 2.0 and had no problems running the file. Can anyone help me how to get it to run with serviio?
I changed serviio to generic profile and could run the file just fine as well. Does it make sense to join the generic profile and the series c/d profile?
Post Sat May 07, 2011 11:49 am
PJusa wrote:i hope this helps:
686-mingw32-
title : Chapter 1
title : Chapter 2
title : Chapter 3
title : Chapter 4
title : Chapter 5
LWING_GAIN : 01.00
LANGUAGE : English
/s
LWING_GAIN : 01.00
OGG container for videos is not supported. I'll create a ticket.
Post Sat May 07, 2011 11:52 am
PJusa wrote:I changed serviio to generic profile and could run the file just fine as well. Does it make sense to join the generic profile and the series c/d profile?
Try to remove this line from the C/D profile:
PJusa
Post Sat May 07, 2011 1:32 pm
thanks for the info on the OGM file - that explains a lot. will probably recode them then since its only around 40 files or so.
removed the line from the provile and applied it. that did the trick apparently. interestingly enough VOB files now also come in multi-languages.
so thanks for the help - this really made my life a lot easier esp. since i can now use the samsung profile :)
