How do you know when transcoding is used for playback?
How do you know when transcoding is being used to playback a file (without disabling transcoding first and playing the file)?
Thanks,
->g.
Lowlander wrote:Serviio should be able add an informational symbol to the video's title line to indicate if it is going to be transcoded.
Illico wrote:Lowlander wrote:Serviio should be able add an informational symbol to the video's title line to indicate if it is going to be transcoded.
Yes, Serviio could for example add an "#" at the end of the file name to indicate it is transcoded.
