How do you know when transcoding is used for playback?
glc650
Post Sat Aug 20, 2011 10:21 pm
How do you know when transcoding is being used to playback a file (without disabling transcoding first and playing the file)?
Thanks,
->g.
Post Mon Aug 22, 2011 9:56 am
Re: How do you know when transcoding is used for playback?
you could find in the the (detailed) log
Post Tue Aug 30, 2011 3:43 pm
Zip is there anyway that the console could be modified to show what is being played, on what render and if it is being transcoded.
Post Tue Aug 30, 2011 3:49 pm
not really. And why? Are you watching TV or the console? ;-)
Post Tue Aug 30, 2011 5:52 pm
just thought it might be helpful when working with mutiple devices using serviio at the same time.
Lowlander
Post Mon Sep 05, 2011 11:56 am
I think that Serviio already "knows" which file is going to be transcoded or not as soon as it lists the files to a particular device. At this stage it compares the library entries to the device's capabilities and lists the MIME types accordingly, and IF that is so, Serviio should be able add an informational symbol to the video's title line to inidicate if it is going to be transcoded. This would really help a lot, paritcularly when optimizing device profiles.
My current way of detecting transcoding is looking at the server's cpu usage or watching if an ffmpeg task is spawned. Pretty complicated, but IMHO still simpler and more real-time than browsing the logfile.
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
Post Mon Sep 05, 2011 12:27 pm
Lowlander wrote:Serviio should be able add an informational symbol to the video's title line to indicate if it is going to be transcoded.
Yes, Serviio could for example add an "#" at the end of the file name to indicate it is transcoded.
Post Mon Sep 05, 2011 12:41 pm
details on why it's not right: https://bitbucket.org/xnejp03/serviio/i ... transcoded
Lowlander
Post Mon Sep 05, 2011 2:17 pm
Ok, I see. You win. Again. :roll:
Users browsing this forum: Bing [Bot] and 8 guests
