"Filetype not recognized" on Samsung plasma
Xabre
Post Mon Sep 12, 2011 6:45 pm
Re: "Filetype not recognized" on Samsung plasma
Media info for AVCHD file from Panasonic video cam:
Complete name                    : C:\Users\Hibiscus\Videos\Serviio test\Videokamera 044.MTS
Format                           : BDAV
Format/Info                      : Blu-ray Video
File size                        : 93.2 MiB
Duration                         : 29s 732ms
Overall bit rate                 : 26.3 Mbps
Maximum Overall bit rate         : 28.0 Mbps
Menu ID                          : 1 (0x1)
Format profile                   : High@L4.2
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Format settings, GOP             : M=3, N=24
Codec ID                         : 27
Duration                         : 29s 720ms
Bit rate mode                    : Variable
Bit rate                         : 24.9 Mbps
Maximum bit rate                 : 26.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Frame rate                       : 50.000 fps
Bits/(Pixel*Frame)               : 0.240
Stream size                      : 88.1 MiB (94%)
Menu ID                          : 1 (0x1)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : 129
Duration                         : 29s 792ms
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Delay relative to video          : -40ms
Stream size                      : 1.36 MiB (1%)
Text
Menu ID                          : 1 (0x1)
Format                           : PGS
Codec ID                         : 144
Duration                         : 29s 216ms
ffmpeg.exe info
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "C:\Videokamera 044.MTS"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Input #0, mpegts, from 'C:\Videokamera 044.MTS':
  Duration: 00:00:29.77, start: 0.356011, bitrate: 26261 kb/s
  Program 1
    Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 50fps, 50 tbr, 90k tbn, 100 tbc
    Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
    Stream #0.2[0x1200]: Subtitle: pgssub
Post Mon Sep 12, 2011 7:15 pm
Thanks, Samsung device may support this AVCHD format.
Or this is probably due to high AVC profile level > 4.1 ?
Xabre
Post Mon Sep 12, 2011 7:28 pm
I have no idea. I'm just an average user trying to get this to work. If I read that Tversity, Twonky or Serviio claim that they support these different video formats over DLNA, I assume that it should work without me having to code COBOLT ;-) It seems these different media servers do not fully support the listed types but rather very special subsets. Sorry if I sound disappointed but so far I haven't been able to get DivX, Xvid, MKV, MTS, AVCHD or MPeg-4 to work or get transcoded by any DLNA PC solution and the Samsung 8-series is supposed to be in the frontline of these things.
Xabre
Post Mon Sep 12, 2011 10:01 pm
Strange, but at least I've managed to get some file types to work now.
Findings:
- Video converter from Xilisoft produces files not suitable for DLNA except for "WMV"
- Video converter from AVS produces files not suitable for DLNA (and looks like s**)
- Video converter from Bigasoft produces some files (DivX, Xvid, Mpeg, MP4, Mov etc) that work with DLNA, except for .mkv and WMV...
- Random downloaded .avi and .mkv files works, but not all
Conclusion; DLNA is an immature and spoiled standard which requires the users to know exactly what each device wants to eat in terms of file extension, video codec, audio codec and resolution.
Post Sat Sep 17, 2011 7:07 am
Xabre wrote:Strange, but at least I've managed to get some file types to work now.
Findings:
no that why you use transcoding so you DONT have to worry about that.
Post Sat Sep 17, 2011 7:09 am
DM613 wrote:I clicked stop and start ... But now I started again to all the machines and ran new tests (still not working). You can find the latest log file. I had to cut the first part, as if more and more of 256K.
ok that make no sence, what log file ??? and further more please REMOVE the advertisement links from your signiture.
Previous
