New to Serviio and confused
Sparky
Post Sun Apr 12, 2015 8:41 am
Greetings to all.
I have been a long time user of Nero MediaHome 4 Essentials. It was a simple product and did everything I needed but alas it started crashing on me every time I wanted to use it, so it had to go. The crashing started about the time my Samsung UE48H6400 arrived on my LAN. I am replacing it with Serviio, and I'm almost there with the configuration, but I have a few items I can't quite work out. Everything I use that has an Ethernet connection is wired into my PowerLine network.
My first issue was the Sony BDP-S490. When I first tested it Photos and Music were fie, but the Sony described all the video content as M2TS files. Checking and changing the Render profile to ""Sony BDP-Sx90" and waiting a while changed the detection to MP4 which was correct. The files played correctly in either setting and the Video info display showed AAC/AVC correctly. This was a bit of a surprise as I have turned the transcoding option off. All my videos are created in a playable format, as MediaHome didn't transcode. All I want to do is show and stream what is there..... :) Have I missed something in the config options, like a setting to just stream, or is turning off the transcoding setting the same thing?
The second issue was around the Samsung UE48H6400. It sees Serviio fine, but gives the error "Request cannot be completed. You will be returned to the main screen". The rendering profile here defaulted to the A Series TV. Changing it to H series didn't help. I know it works as there are people in the forum using one, so it must be my config. Currently Serviio is set to Present the "Audio", "Video", and "Image" sections with "Display Content Only", and the "-Folders" sub option is also set to "Display Content Only". All the other "Tag items" are "Disable". My family are used to scrolling through the file structure to find a file/folder they want to play and then play it. That's what I am trying to copy with my config. My MP3s are tagged correctly, nothing else is. Any ideas on how I can get the Samsung to show, and play, the files..?
Finally, and less importantly, my daughter has an HTC mobile phone which streamed from MediaHome fine. Again it can see music [via the Music app] and images [via the Gallery]. The problem comes when you try to stream video[via the Gallery]. On such a small screen I'm not sure you would want to - but she does :) I know that the default codec support is quite limited, but the MP4s that I created for the Sony BDP do play on the HTC [I copied one or 2 locally to check long ago] but now nothing is found by the HTC. Thinking it might be similar to the M2TS/MP4 detection issue on the Sony, I moved the HTC from the generic profile to that of the Sony, unsurprisingly not helpful. This makes me think that turning off transcoding is not the same as simply showing what is in Serviio. Is that correct...? What do I need to do to make the videos playable.
As I'm new to this, please feel free to state the obvious. I made things work thus far by guesswork, now I need some knowledgeable help.
Any thoughts gratefully accepted.
Windows 10 Pro 64-bit, Asus Sabertooth P67, Core i7-2600 3.4GHz, 16Gb DDR3-14900, Nvidia GeForce 8800GT 512Mb, HL-DT-ST GH22LS50, System: Intel SSD 520 Series 240Gb, VM: Intel SSD 330 Series 240Gb, Data: Seagate Barracuda ST31500341AS 1500GB 32Mb Cache, DLNA: Hitachi Deskstar P7K500 320GB 16Mb Cache
Samsung UE48H6400, Sony BDP-S490, PlayStation 3, Xbox 360, Xbox One.
Sparky
Post Mon Apr 13, 2015 10:44 am
Re: New to Serviio and confused
I managed to get hold of the HTC phone and went through trying each Render Profile to see what changed. Here's what I discovered;
Partial success was found with the following profiles. They admitted that a video file was present, but the HTC said they were corrupt;
DirecTV, Manta, Philips 2009, Roku, Toshiba Regza, Vizio TV
I got total success with;
All of the Samsung profiles, Toshiba Regza 2012-, Xbox 360
I'll stick with the Regza 2012- profile and use that. I have no Toshiba kit here, but I do have a Samsung H series and Xbox 360.....
As I said, I'm new to this, so I'm not even sure what that actually means. Why would an MP4 file that I know plays on the device not even show up, or show up and then not play..? If Serviio isn't transcoding, once the headers are downloaded the device should recognise the file and play it or not. Or am I dramatically over simplifying things...? Maybe I should try to figure out what all the tech speak behind the DLNA standard means.....
The other thing I found odd was that the video played from the point I paused it, but only on the second attempt. The first time I hit pause and quit the Gallery app it restarted from the beginning. The second time it carried on from where I left off. After changing the Render Profile I expected that would wipe out the capability for resume, it seems not. I tried it on a few other videos and it was consistent. Could that be a bug or am I missing something..?
I read that there were lots of profile problems with the Samsung TVs in the Samsung forum, but none seemed to be related to actually connecting, just playback issues, so I guess I'm one step further away than most folks here. Still looking for some help there.
Post Mon Apr 13, 2015 12:44 pm
There does seem to be something about the current H profile that isn't working correctly. I helped build it, and it worked fine for a while, but now for some reason I'm getting some unplayable files that should play. Part of my issue may be that I swapped my HU8550 for a JU7100, and the two may require a different profile. I still have one H Series TV, but it's in the exercise room and I haven't used it in a while. Perhaps I'm telling myself something here :).
I'm going to be tweaking on the H profile, and I'll be testing my tweaks on both the H and JU series. Watch the Samsung sub-forum for updates.
As far as restarting from the stopped position, that seems to be normal behavior for a Samsung. I've never had any other player (TV, Blu-Ray player or Media box) that would consistently resume after switching to another video. In some respects I like it, other times it annoys me. can't please everyone! :lol: I would prefer the option to resume or start from the beginning, but that's controlled by the player. Plex allows it if you are using their app, but I've never seen it available via DLNA until I got my first Samsung set.
Sparky
Post Mon Apr 13, 2015 1:18 pm
Thanks for coming back to me atc98092...
I fear I may have confused you though. I got the HTC to stream video by trying every Render Profile [it would show music and images with them all], but I can't even see anything on the Samsung. Each time I try to open Serviio I get an error "Request cannot be completed. You will be returned to the main screen". I'll try the Samsung on the generic profile anyway to see if that changes the behaviour.
It's the HTC cell phone that showed the resume behaviour, on the Tosh Regza 2012- profile as well as one of the Samsung profiles - the E/F one I think. I didn't test that on all of them. I didn't have that much "spare" time... ;)
Using the term "Render" automatically made me think video, especially with the experience I gained by getting the Sony and HTC to work across all 3 file types. They seemed to work by default with music and images and tweaking the profile only made a difference with video. In the case of the Sony, having it register it correctly as an MP4 file, and with the HTC having it show and play the files at all.
Sparky
Post Mon Apr 13, 2015 4:43 pm
Sparky wrote:I'll try the Samsung on the generic profile anyway to see if that changes the behaviour..
I tried the Generic DLNA profile, and sure enough the Samsung TV started working.
I'm not sure I have the confidence to start hacking about in the profiles, but I'll give it a go and keep the original file as a backup, just in case. I'll keep an eye in the Samsung thread for your posts.
I guess the Samsung must have confused my copy of MediaHome 4 Essentials into crashing, which is presumably the same confusion it's causing in the profiles...
Thanks for pointing me in the right direction...
Post Mon Apr 13, 2015 11:57 pm
This is what I'm using right now. Having an issue with WTV files, but I think everything else is working.
<Profile id="sam_h" name="Samsung TV / player (H-series)" extendsProfileId="1">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
      <Detection>
         <UPnPSearch>
            <FriendlyName>(^\[TV\][A-Z]{2}\d{2}H[A-Z]?\d{3,4}.*)</FriendlyName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- for BD players -->
            <User-Agent>(.*SEC_HHP_BD-H.*)|(.*SEC_HHP_\[(HT|BD)\]H.*)|(\[BD\]H.*)</User-Agent>
         </HttpHeaders>
      </Detection>
      <DeviceDescription>
           <ExtraElements>
              &lt;sec:ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
        </DeviceDescription>
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
            <MediaFormatProfile mime-type="audio/x-flac">FLAC</MediaFormatProfile>
        </MediaFormatProfiles>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
      <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h265" />
                <Matches container="mp4" vCodec="dvvideo" />
         <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
            <Matches container="wtv" vCodec="h264"/>
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="wtv" />
         <!-- transcode wmv2-wmav2, not: wmv3-wmapro it works ok on E series-->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
            <Matches container="asf" vCodec="wmv2" />
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="mp4" />
            <Matches container="ogg" />
            <Matches container="adts" />
            <Matches container="mp2" />
            <Matches container="wavpack" />
            <Matches container="mpc" />
                <Matches container="ape" />
                <Matches container="asf" />
         </Audio>
      <OnlineTranscoding>
            <Matches container="applehttp" vCodec="h264"/>
            <Matches container="asf" /> <!-- mms -->
            <Matches container="flv" /> <!-- transcoding all flv streams, even h264, to avoild premature disconnects, to avoid this, use Samsung C/D profile -->
      </OnlineTranscoding>
      <HardSubsTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192"/>
      </HardSubsTranscoding>
        <Subtitles>
         <SoftSubs mime-type="smi/caption" />
      </Subtitles>
      <AllowChunkedTransfer>false</AllowChunkedTransfer>
Sparky
Post Tue Apr 14, 2015 10:50 am
Thanks Dan,
I replaced the existing section of the profiles.xml file with your code, stopped and started the server, selected the Samsung H series profile and tried it. It gave me the same error - "Request cannot be completed. You will be returned to the main screen" on opening Serviio. I swapped back to the Generic profile and things started working again. What did I do wrong..?
On a related note - and not strictly relevant to the profile discussion - can I make Serviio "stick" to the SmartHub screen..? All I can find instructions for is adding a PC running the Samsung software. My kids Windows media services appear in the list alongside Serviio and I have to select the list and then find Serviio, would be much easier to just stick Serviio to the list...
Post Tue Apr 14, 2015 12:31 pm
Sparky wrote:Thanks Dan,
I don't think you did anything wrong. Just something that your set doesn't care for in that profile. If you copied it wrong, Serviio wouldn't load.
I haven't seen a way to make Serviio show up in the SmartHub over other servers. With the JU series, it's even more maddening, as it begins loading the server as soon as the name is highlighted, rather than waiting for it to be selected. Every computer on my network shows up, even if there's no media being shared, so I have to scroll though them all. :x
I copied that profile from my test server. I thought I had changed it from the 1.5.2 default profile, but maybe I didn't. I'll try to remember to test it on my H series set this evening to be sure. Hope I didn't give you a bad version! :oops:
Sparky
Post Tue Apr 14, 2015 12:55 pm
atc98092 wrote: Hope I didn't give you a bad version! :oops:
You know what you're talking about here, I don't. I'm happy to believe the mistakes are all mine.
Sparky
Post Thu Apr 16, 2015 3:54 pm
hi Dan,
It occurred to me that your comment about Serviio not loading if I'd copy the profile wrong probably meant that I was starting and stopping the server incorrectly. I was doing the start/stop in the console, rather than via services.msc.
In case the console wasn't doing that I tried the start/stop via services.msc and the TV still didn't like your provided profile.
Post Thu Apr 16, 2015 11:55 pm
Yes, the stop/start on the console does not change the actual service. All it does it stop and start the DLNA server. For the Service to reload you have to do what you did in the Services console or reboot the computer.
If that profile didn't load, then (sorry to say) you must have done something it didn't like. Your log would explain why it wouldn't load.
Sparky
Post Fri Apr 17, 2015 6:45 am
Serviio loaded fine, but the TV was still generating the error. So the TV doesn't like your profile, as you suspected. I've gone back t the Generic DLNA profile for it.
I did try generating a profile for my daughters HTC to get transcoding to work, that failed wonderfully and I posted about that in another thread. I think my somewhat simplistic approach failed miserably. I'll keep plodding on to see what I learn along the way, and hope that someone will shorten the process by answering the other thread with something sensible :)
Post Sun Apr 19, 2015 11:48 pm
Well, I got around to testing the profile I posted above on my one H Series set. Everything played fine, regardless of if it was being transcoded or playing native. I have no answer why yours won't. The next stage is enabling detailed logging and trying again. With a detailed log, someone here can see what the issue might be.
Sparky
Post Mon Apr 20, 2015 8:47 am
Here's the detailed serviiolog with Library updates filtered out. The first time I tried I got a 9Mb file which appeared to have library updates in it....
The TV is: 192.168.24.137
Server is: 192.168.24.110
Details on both devices are in the signature.
2015-04-20 09:37:04,969 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2015-04-20 09:37:04,984 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-20 09:37:04,984 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-20 09:37:04,984 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-20 09:37:04,984 INFO [MediaServer] http://www.serviio.org
2015-04-20 09:37:04,984 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86
2015-04-20 09:37:04,984 INFO [MediaServer] OS Windows 7 6.1
2015-04-20 09:37:04,984 INFO [MediaServer] File encoding: windows-1252
2015-04-20 09:37:04,984 INFO [MediaServer] Headless mode enabled: true
2015-04-20 09:37:04,984 INFO [MediaServer] User: PHOENIX-III$
2015-04-20 09:37:04,984 INFO [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2015-04-20 09:37:04,984 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2015-04-20 09:37:04,984 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\Windows\TEMP\e4j15B7.tmp_dir1429519024, -Dexe4j.unextractedPosition=327425, -Djava.library.path=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Seagate\SnapAPI\;C:\Program Files (x86)\Common Files\Acronis\SnapAPI\;;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xrs, -Xmx512m
2015-04-20 09:37:05,062 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-20 09:37:05,062 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-20 09:37:05,156 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-20 09:37:05,156 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-20 09:37:05,171 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-20 09:37:05,187 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2015-04-20 09:37:05,187 INFO [DatabaseManager] Using DERBY database language
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2015-04-20 09:37:05,624 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2015-04-20 09:37:05,639 DEBUG [LicensingManager] Updating license
2015-04-20 09:37:05,639 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2015-04-20 09:37:05,639 DEBUG [LicenseValidator] Validating license file (350 bytes)
2015-04-20 09:37:05,702 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-20 09:37:05,702 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-04-20 09:37:05,702 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth3-0
2015-04-20 09:37:05,780 INFO [Device] Created UPnP Device with UUID: 0072ceea-670e-3d8a-b9d2-273003fc0d3e, bound address: 192.168.24.110
2015-04-20 09:37:06,076 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-04-20 09:37:06,076 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2015-04-20 09:37:06,123 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-04-20 09:37:06,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-04-20 09:37:06,139 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2015-04-20 09:37:06,139 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-04-20 09:37:06,154 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2015-04-20 09:37:06,154 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-04-20 09:37:06,185 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-04-20 09:37:06,185 INFO [PluginCompilerThread] Started looking for plugins
2015-04-20 09:37:06,185 INFO [UpdateChecker] Checking if a new version is available
2015-04-20 09:37:06,185 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2015-04-20 09:37:06,185 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2015-04-20 09:37:06,419 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-04-20 09:37:06,419 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\dcraw.exe
2015-04-20 09:37:06,419 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\dcraw.exe
2015-04-20 09:37:06,513 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-04-20 09:37:06,529 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth3-0
2015-04-20 09:37:06,529 INFO [WebServer] WebServer starting on port 8895
2015-04-20 09:37:06,575 INFO [Device] Updated bound IP address of Device with UUID: 0072ceea-670e-3d8a-b9d2-273003fc0d3e, bound address: 192.168.24.110
2015-04-20 09:37:06,575 DEBUG [DiscoveryManager] UPNP device 0072ceea-670e-3d8a-b9d2-273003fc0d3e (192.168.24.110) is available
2015-04-20 09:37:06,575 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-04-20 09:37:06,575 INFO [EventDispatcher] Starting EventDispatcher
2015-04-20 09:37:06,575 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-04-20 09:37:06,591 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-04-20 09:37:06,635 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:37:06,640 INFO [RendererSearchSender] Searching for Renderer devices
2015-04-20 09:37:06,641 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:37:06,641 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-04-20 09:37:06,656 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.24.110:57839s
2015-04-20 09:37:06,656 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.137:7676/smp_15_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:37:06,656 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 1017df81-000e-1000-898e-bc1485147d5f from address 192.168.24.137
2015-04-20 09:37:06,672 DEBUG [RendererManager] Adding renderer Renderer [uuid=1017df81-000e-1000-898e-bc1485147d5f, ipAddress=192.168.24.137, name=UE48H6400, profileId=sam_h, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2015-04-20 09:37:06,672 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.137:7676/smp_15_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:37:06,672 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 1017df81-000e-1000-898e-bc1485147d5f from address 192.168.24.137
2015-04-20 09:37:06,672 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:37:06,672 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0072ceea-670e-3d8a-b9d2-273003fc0d3e
2015-04-20 09:37:06,687 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.137:7676/smp_15_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:37:06,687 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 1017df81-000e-1000-898e-bc1485147d5f from address 192.168.24.137
2015-04-20 09:37:07,374 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33662: GET /deviceDescription/0072ceea-670e-3d8a-b9d2-273003fc0d3e HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:37:07,374 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,374 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0072ceea-670e-3d8a-b9d2-273003fc0d3e from 192.168.24.137 (headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50])
2015-04-20 09:37:07,374 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]
2015-04-20 09:37:07,499 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (H-series)'
2015-04-20 09:37:07,577 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33663: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:37:07,577 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,577 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2015-04-20 09:37:07,577 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-04-20 09:37:07,686 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33664: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:37:07,686 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,686 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2015-04-20 09:37:07,686 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-04-20 09:37:07,795 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33665: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:37:07,795 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,795 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2015-04-20 09:37:07,795 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-04-20 09:37:07,873 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33668: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.24.110:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-04-20 09:37:07,873 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,873 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:37:07,904 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33669: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.24.110:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-04-20 09:37:07,904 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,904 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:37:08,138 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.114:2869/upnphost/udh ... 4c3bdf4aa6, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:37:08,138 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 6d0c770c-830e-45d2-b375-e24c3bdf4aa6 from address 192.168.24.114
2015-04-20 09:37:08,154 DEBUG [RendererManager] Adding renderer Renderer [uuid=6d0c770c-830e-45d2-b375-e24c3bdf4aa6, ipAddress=192.168.24.114, name=Windows Media Player, profileId=1, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2015-04-20 09:37:08,325 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.114:2869/upnphost/udh ... 4c3bdf4aa6, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:37:08,325 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 6d0c770c-830e-45d2-b375-e24c3bdf4aa6 from address 192.168.24.114
2015-04-20 09:37:08,481 DEBUG [ServiioHttpService] Incoming request from /192.168.24.114:50784: GET /deviceDescription/0072ceea-670e-3d8a-b9d2-273003fc0d3e HTTP/1.1, headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.24.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]]
2015-04-20 09:37:08,481 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.114
2015-04-20 09:37:08,481 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0072ceea-670e-3d8a-b9d2-273003fc0d3e from 192.168.24.114 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.24.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2015-04-20 09:37:08,481 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.24.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2015-04-20 09:37:08,481 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-04-20 09:37:08,528 DEBUG [ServiioHttpService] Incoming request from /192.168.24.114:50785: GET /icon/smallPNG HTTP/1.1, headers = [Connection: Keep-Alive,User-Agent: Windows-Media-Player-DMS/12.0.7601.17514,Host: 192.168.24.110:8895]]
2015-04-20 09:37:08,528 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.114
2015-04-20 09:37:08,528 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:37:08,637 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-04-20 09:37:09,621 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.114:2869/upnphost/udh ... 4c3bdf4aa6, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:37:09,621 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 6d0c770c-830e-45d2-b375-e24c3bdf4aa6 from address 192.168.24.114
2015-04-20 09:37:12,641 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-04-20 09:37:16,673 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:37:16,673 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0072ceea-670e-3d8a-b9d2-273003fc0d3e
2015-04-20 09:37:18,452 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.24.137:53047s
2015-04-20 09:37:18,452 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.24.137:53047
2015-04-20 09:37:18,639 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-04-20 09:37:19,398 INFO [ServiioConsole] Initializing Serviio Console
2015-04-20 09:37:19,417 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2015-04-20 09:37:19,419 INFO [ServiioConsole] Starting Serviio Console
2015-04-20 09:37:19,496 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2015-04-20 09:37:19,528 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-04-20 09:37:19,528 DEBUG [ServiioConsole] Checking if server is running
2015-04-20 09:37:19,883 DEBUG [ServiioConsole] Retrieving console settings
2015-04-20 09:37:19,904 DEBUG [ServiioConsole] Setting console locale to be: en
2015-04-20 09:37:19,908 INFO [Messages] Loaded console message bundle for locale: en
2015-04-20 09:37:19,908 DEBUG [ServiioConsole] Reading application data
2015-04-20 09:37:20,000 DEBUG [ServiioFrameView] Initializing main frame
2015-04-20 09:37:20,012 DEBUG [ServiioFrameView] System tray is supported
2015-04-20 09:37:20,380 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-04-20 09:37:20,498 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.24.110:54663s
2015-04-20 09:37:20,873 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-04-20 09:37:20,874 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2015-04-20 09:37:20,889 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:20,892 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,894 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,898 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,900 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,901 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,905 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,906 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,907 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,910 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,911 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,918 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,922 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,928 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,929 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,930 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2015-04-20 09:37:20,931 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,936 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,938 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,940 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,942 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,943 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,944 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
Sparky
Post Mon Apr 20, 2015 8:48 am
Here's the rest of it.
2015-04-20 09:37:20,947 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,949 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,950 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,950 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random_music, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:20,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2015-04-20 09:37:20,954 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_RA, titleKey=random_albums, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:20,956 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=no_cache
2015-04-20 09:37:20,957 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2015-04-20 09:37:20,961 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_LVA, titleKey=last_listened_albums, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2015-04-20 09:37:20,962 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListLastViewedAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:20,964 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:20,966 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_LAA, titleKey=last_added_albums, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2015-04-20 09:37:20,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListLastAddedAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:20,969 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:20,970 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,973 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,974 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,975 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:20,976 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2015-04-20 09:37:20,979 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2015-04-20 09:37:20,980 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,982 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2015-04-20 09:37:20,983 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,986 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,987 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AA, titleKey=Artist Albums, class=CONTAINER, cacheRegion=no_cache, browsable = false, editable = null
2015-04-20 09:37:20,988 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistNameCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=no_cache
2015-04-20 09:37:20,991 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2015-04-20 09:37:20,992 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:20,993 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:20,994 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,997 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2015-04-20 09:37:20,998 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2015-04-20 09:37:21,001 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,004 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,006 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,007 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,010 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,011 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,012 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,014 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,017 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,018 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,019 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:21,021 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2015-04-20 09:37:21,024 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2015-04-20 09:37:21,025 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,026 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:21,029 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,032 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,033 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,037 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,038 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,039 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:21,043 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:21,044 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:21,045 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,047 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2015-04-20 09:37:21,050 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2015-04-20 09:37:21,051 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2015-04-20 09:37:21,053 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,056 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,057 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LANV, titleKey=last_added_not_viewed, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,059 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedNotViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,060 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,064 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,066 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,067 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_R, titleKey=ratings, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,071 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoRatingsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=RAT, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,073 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosForRatingCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,074 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,076 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,079 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,081 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,083 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,086 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,088 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,090 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,091 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,095 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,097 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,098 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,102 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_RY, titleKey=release_years, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,104 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoReleaseYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=Y, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,105 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosForReleaseYearCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,107 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2015-04-20 09:37:21,113 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,115 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2015-04-20 09:37:21,117 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2015-04-20 09:37:21,120 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2015-04-20 09:37:21,123 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-04-20 09:37:21,372 DEBUG [ServiioConsole] Reading application data
2015-04-20 09:37:21,372 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2015-04-20 09:37:21,393 INFO [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2015-04-20 09:37:26,674 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:37:26,674 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0072ceea-670e-3d8a-b9d2-273003fc0d3e
2015-04-20 09:37:28,639 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:44 (advertisement duration is 1800 sec.)
2015-04-20 09:37:32,649 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-04-20 09:37:32,649 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-04-20 09:37:32,649 INFO [LocalLibraryManager] Starting automatic library scan
2015-04-20 09:37:33,007 INFO [LibraryDeltaScanner] Added repository 'D:\My Music' to delta scanner (NATIVE)
2015-04-20 09:37:33,132 INFO [LibraryDeltaScanner] Added repository 'D:\My Pictures' to delta scanner (NATIVE)
2015-04-20 09:37:33,132 INFO [LibraryDeltaScanner] Added repository 'V:\Movies' to delta scanner (NATIVE)
2015-04-20 09:37:33,132 INFO [LibraryDeltaScanner] Starting the library delta scan
2015-04-20 09:37:33,148 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-04-20 09:37:37,650 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33675: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.24.110:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-04-20 09:37:37,650 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:37,650 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:37:37,681 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33676: POST /serviceControl HTTP/1.1, headers = [Accept: */*,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50,Host: 192.168.24.110:8895,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList",CONTENT-TYPE: text/xml; charset="utf-8",Content-Length: 291,Connection: close]]
2015-04-20 09:37:37,681 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:37,681 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.24.137
2015-04-20 09:37:37,759 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-04-20 09:37:37,822 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33677: POST /serviceControl HTTP/1.1, headers = [Accept: */*,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50,Host: 192.168.24.110:8895,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",CONTENT-TYPE: text/xml; charset="utf-8",Content-Length: 451,Connection: close]]
2015-04-20 09:37:37,822 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:37,822 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.24.137
2015-04-20 09:37:37,837 DEBUG [ContentDirectory] Browse() called for renderer UE48H6400 (profile sam_h) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2015-04-20 09:37:37,993 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-04-20 09:37:38,056 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33679: POST /serviceControl HTTP/1.1, headers = [Accept: */*,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50,Host: 192.168.24.110:8895,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",CONTENT-TYPE: text/xml; charset="utf-8",Content-Length: 452,Connection: close]]
2015-04-20 09:37:38,056 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:38,056 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.24.137
2015-04-20 09:37:38,056 DEBUG [ContentDirectory] Browse() called for renderer UE48H6400 (profile sam_h) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2015-04-20 09:37:38,165 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-04-20 09:37:38,227 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33680: POST /serviceControl HTTP/1.1, headers = [Accept: */*,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50,Host: 192.168.24.110:8895,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",CONTENT-TYPE: text/xml; charset="utf-8",Content-Length: 452,Connection: close]]
2015-04-20 09:37:38,227 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:38,227 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.24.137
2015-04-20 09:37:38,227 DEBUG [ContentDirectory] Browse() called for renderer UE48H6400 (profile sam_h) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 3, count = 30, sortCriteria =
2015-04-20 09:37:38,259 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-04-20 09:37:40,770 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33683: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.24.110:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-04-20 09:37:40,770 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:40,770 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:37:43,906 DEBUG [DCRawWrapper] Invoking DCRAW to retrieve thumbnail from file: D:\My Pictures\Misc\PAYMENT.JPG
2015-04-20 09:37:43,906 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\dcraw.exe -c -e D:\My Pictures\Misc\PAYMENT.JPG
2015-04-20 09:37:43,999 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (D:\My Pictures\Misc\PAYMENT.JPG). Message: Cannot read raw image file D:\My Pictures\Misc\PAYMENT.JPG using dcraw
2015-04-20 09:37:48,445 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.24.137:53047s
2015-04-20 09:37:48,445 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.24.137:53047
2015-04-20 09:37:59,911 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-04-20 09:37:59,911 DEBUG [RendererDAOImpl] Updating Renderer (uuid = 1017df81-000e-1000-898e-bc1485147d5f, ipAddress = 192.168.24.137)
2015-04-20 09:37:59,927 DEBUG [StatusServerResource] Storing bound NIC: eth3-0
2015-04-20 09:37:59,927 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = bound_nic_name)
2015-04-20 09:37:59,927 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = bound_nic_name, value = eth3-0)
2015-04-20 09:37:59,927 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = renderer_enabled_default)
2015-04-20 09:37:59,927 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = renderer_enabled_default, value = true)
2015-04-20 09:37:59,927 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = renderer_default_access_group_id)
2015-04-20 09:37:59,927 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = renderer_default_access_group_id, value = 1)
2015-04-20 09:37:59,943 DEBUG [DiscoveryManager] UPNP device 0072ceea-670e-3d8a-b9d2-273003fc0d3e (192.168.24.110) is unavailable
2015-04-20 09:37:59,943 DEBUG [WebServer] Socket closed
2015-04-20 09:37:59,943 DEBUG [WebServer] Marking the web server for exit
2015-04-20 09:37:59,943 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-04-20 09:37:59,943 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-20 09:37:59,943 INFO [WebServer] WebServer shutting down
2015-04-20 09:37:59,943 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2015-04-20 09:37:59,943 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2015-04-20 09:37:59,943 INFO [EventDispatcher] Leaving EventDispatcher
2015-04-20 09:37:59,943 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-04-20 09:37:59,943 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-04-20 09:37:59,989 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:37:59,989 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth3-0
2015-04-20 09:37:59,989 INFO [WebServer] WebServer starting on port 8895
2015-04-20 09:38:00,036 INFO [Device] Updated bound IP address of Device with UUID: 0072ceea-670e-3d8a-b9d2-273003fc0d3e, bound address: 192.168.24.110
2015-04-20 09:38:00,036 DEBUG [DiscoveryManager] UPNP device 0072ceea-670e-3d8a-b9d2-273003fc0d3e (192.168.24.110) is available
2015-04-20 09:38:00,052 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-04-20 09:38:00,052 INFO [EventDispatcher] Starting EventDispatcher
2015-04-20 09:38:00,052 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-04-20 09:38:00,102 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:38:00,104 INFO [RendererSearchSender] Searching for Renderer devices
2015-04-20 09:38:00,105 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:38:00,106 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-04-20 09:38:00,106 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.24.110:65379s
2015-04-20 09:38:00,184 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:38:00,184 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0072ceea-670e-3d8a-b9d2-273003fc0d3e
2015-04-20 09:38:00,403 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.137:7676/smp_15_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:38:00,403 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 1017df81-000e-1000-898e-bc1485147d5f from address 192.168.24.137
2015-04-20 09:38:00,418 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.137:7676/smp_15_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:38:00,418 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 1017df81-000e-1000-898e-bc1485147d5f from address 192.168.24.137
2015-04-20 09:38:00,434 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.137:7676/smp_15_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:38:00,434 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 1017df81-000e-1000-898e-bc1485147d5f from address 192.168.24.137
2015-04-20 09:38:00,886 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33690: GET /deviceDescription/0072ceea-670e-3d8a-b9d2-273003fc0d3e HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:38:00,886 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:38:00,886 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0072ceea-670e-3d8a-b9d2-273003fc0d3e from 192.168.24.137 (headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50])
2015-04-20 09:38:00,886 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]
2015-04-20 09:38:00,902 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-04-20 09:38:00,995 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33691: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:38:00,995 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:38:00,995 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2015-04-20 09:38:01,011 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-04-20 09:38:01,105 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33692: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:38:01,105 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:38:01,105 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2015-04-20 09:38:01,120 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-04-20 09:38:01,214 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33693: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [HOST: 192.168.24.110:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED48/1.0 DLNADOC/1.50]]
2015-04-20 09:38:01,214 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:38:01,214 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2015-04-20 09:38:01,229 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-04-20 09:38:01,323 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33696: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.24.110:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-04-20 09:38:01,323 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:38:01,323 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:38:01,339 DEBUG [ServiioHttpService] Incoming request from /192.168.24.137:33697: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.24.110:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-04-20 09:38:01,339 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:38:01,339 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:38:01,651 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2015-04-20 09:38:01,931 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.114:2869/upnphost/udh ... 4c3bdf4aa6, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:38:01,931 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 6d0c770c-830e-45d2-b375-e24c3bdf4aa6 from address 192.168.24.114
2015-04-20 09:38:02,150 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-04-20 09:38:03,037 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.114:2869/upnphost/udh ... 4c3bdf4aa6, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:38:03,037 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 6d0c770c-830e-45d2-b375-e24c3bdf4aa6 from address 192.168.24.114
2015-04-20 09:38:03,128 DEBUG [ServiioHttpService] Incoming request from /192.168.24.114:50785: GET /deviceDescription/0072ceea-670e-3d8a-b9d2-273003fc0d3e HTTP/1.1, headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.24.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]]
2015-04-20 09:38:03,129 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.114
2015-04-20 09:38:03,129 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0072ceea-670e-3d8a-b9d2-273003fc0d3e from 192.168.24.114 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.24.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2015-04-20 09:38:03,129 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.24.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2015-04-20 09:38:03,130 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-04-20 09:38:03,182 DEBUG [ServiioHttpService] Incoming request from /192.168.24.114:50786: GET /icon/smallPNG HTTP/1.1, headers = [Connection: Keep-Alive,User-Agent: Windows-Media-Player-DMS/12.0.7601.17514,Host: 192.168.24.110:8895]]
2015-04-20 09:38:03,183 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.114
2015-04-20 09:38:03,183 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-04-20 09:38:03,278 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.24.114:2869/upnphost/udh ... 4c3bdf4aa6, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-04-20 09:38:03,278 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 6d0c770c-830e-45d2-b375-e24c3bdf4aa6 from address 192.168.24.114
2015-04-20 09:38:04,843 INFO [ServiioConsole] Exitting Serviio Console
2015-04-20 09:38:04,849 DEBUG [RepositoryView] Instructing LibraryCheckingThread to stop
2015-04-20 09:38:04,849 DEBUG [RepositoryView$LibraryStatusCheckerThread] Interrupting thread
2015-04-20 09:38:04,849 INFO [ServiioConsole] Serviio Console completely closed
2015-04-20 09:38:04,850 DEBUG [RepositoryView$LibraryStatusCheckerThread] Leaving library status checking thread
2015-04-20 09:38:06,106 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-04-20 09:38:07,796 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2015-04-20 09:38:07,798 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2015-04-20 09:38:07,802 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2015-04-20 09:38:08,003 INFO [LibraryOneTimeScanner] Interrupting library scan
2015-04-20 09:38:08,003 INFO [LibraryDeltaScanner] Stopping the library delta scan
2015-04-20 09:38:08,004 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2015-04-20 09:38:08,104 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2015-04-20 09:38:08,104 INFO [FeedUpdaterWorker] Finished looking for online resources information
2015-04-20 09:38:08,204 INFO [PluginCompilerThread] Finished looking for plugins
2015-04-20 09:38:08,308 INFO [SearchManager] Starting up search engine
2015-04-20 09:38:08,499 INFO [SearchIndexer] Closing search index writer
2015-04-20 09:38:08,510 INFO [SearchIndexer] Closing search index writer
2015-04-20 09:38:08,511 DEBUG [WebServer] Socket closed
2015-04-20 09:38:08,511 DEBUG [WebServer] Marking the web server for exit
2015-04-20 09:38:08,511 INFO [WebServer] WebServer shutting down
2015-04-20 09:38:08,511 DEBUG [DiscoveryManager] UPNP device 0072ceea-670e-3d8a-b9d2-273003fc0d3e (192.168.24.110) is unavailable
2015-04-20 09:38:08,511 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-04-20 09:38:08,511 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2015-04-20 09:38:08,511 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-04-20 09:38:08,511 INFO [EventDispatcher] Leaving EventDispatcher
2015-04-20 09:38:08,511 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-04-20 09:38:08,545 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.24.110, timeout = 0
2015-04-20 09:38:08,545 INFO [DatabaseManager] Shutting down database
2015-04-20 09:38:08,545 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2015-04-20 09:38:08,607 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2015-04-20 09:38:08,607 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Windows 10 Pro 64-bit, Asus Sabertooth P67, Core i7-2600 3.4GHz, 16Gb DDR3-14900, Nvidia GeForce 8800GT 512Mb, HL-DT-ST GH22LS50, System: Intel SSD 520 Series 240Gb, VM: Intel SSD 330 Series 240Gb, Data: Seagate Barracuda ST31500341AS 1500GB 32Mb Cache, DLNA: Hitachi Deskstar P7K500 320GB 16Mb Cache
Samsung UE48H6400, Sony BDP-S490, PlayStation 3, Xbox 360, Xbox One.
Post Mon Apr 20, 2015 12:21 pm
Re: New to Serviio and confused
I'm not skilled in reading the detailed log, so someone else may need to assist here. I did see something about the generic profile. Did you switch to the Samsung H Series profile before attempting to play something? Like I said, I could have easily missed it in there.
Sparky
Post Mon Apr 20, 2015 1:47 pm
The log was so big I had to split it over 2 posts, the first time I tried the test I didn't exclude the library updates and the log was 9mb. :o
In the first part of the log;
2015-04-20 09:37:07,374 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.24.137
2015-04-20 09:37:07,499 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (H-series)'
I did swap the TV back to the Generic profile right at the end of the log [2015-04-20 09:38:00] before I went back to INFO level in the log config.
I'm amazed just how much data was generated. Hopefully it makes sense to someone..... :)
The error came back almost immediately from when I tried to open Serviio in the Smart Hub, so the test didn't take long. I set the log level, deleted the old log, started the server then, ran downstairs, did the test and came back upstairs, swapped the profile back to generic and stopped the service.
Users browsing this forum: Google [Bot] and 41 guests
