SEIKI SE501TS
jart352015yup
Post Tue Apr 07, 2015 9:33 pm
SEIKI SE501TS
Ok I use serviio to stream all my shows and movies to my tv thru my Roku 2 xs using Serviio v1.5.1
here is my profiles.xml settings.
<!-- custom profile - roku media player 2 xs -->
<Video targetContainer="mpegts" targetVCodec="h264" maxVBitrate="12000" targetACodec="mp3" aBitrate="320" forceStereo="true">
<Matches container="matroska" aCodec="dts-hd" />
<Matches container="matroska" aCodec="vorbis" />
<Matches container="matroska" vCodec="h265" />
<Matches container="ogg" vCodec="mpeg4" />
<Matches container="avi" />
<Audio targetContainer="mp3">
<Matches container="*" />
</Audio>
My tv only supports 2 channel audio, and now plays all my mkv, avi and mp4 files just fine. All over a wired network
I also updated to the latest ffmpeg and set the location of ffmpeg with properties attribute like so ( with help from others on the forum )
ServiioConsole.exe.vmoptions
has this for its option
-Dffmpeg.location=C:\Program Files\Serviio\lib\bin\ffmpeg.exe
and
ServiioService.exe.vmoptions
has this for its options
-Xmx1024m
-D<serviio.boundAddr>=<192.168.2.3>
the bound address can be changed in Console but has to match your ip for you and your devices
I set my ffmpeg location uing that function because i updated it to the newest version and because its 64 bit
jart352015yup
Post Wed Apr 15, 2015 6:19 am
Re: SEIKI SE501TS
ok I updated my profile some- 4-15-2015
This update includes adding the ability to transcode .M4V files that use mp4 as the base format and h265 as the codec with the .m4v as its container.
Was having trouble with these files not being playable. ( unsupported media so was not seen )
.m4v with h265 codec is not supported by Roku normally... unless transcoded to the right format.
I basically set all video that uses h265 as its codec to be always transcoded.... this lets them all be seen by my Roku 2 XS and they play perfectly on my TV
I also updated my ffmpeg program and added more ram usage for java to 1536mb.. The ( ServiioService )
here is the new profile transcode section i use now
<Matches container="*" vCodec="h265" />
</Audio>
My TV only supports 2 channel audio, and now plays all my mkv, avi and mp4 files just fine. All over a wired network
Using the latest ffmpeg and set the location of ffmpeg with properties attribute like so ( with help from others on the forum )
and
-Xmx1536m
jart352015yup
Post Wed Jun 10, 2015 8:03 pm
Re: SEIKI SE501TS (updated)
Updated profile 6-10-2015 and using 6.1 beta
only using java and ffmpeg version included with the beta 6.1
this is my full profile for roku.... i use the roku 2 xs and watch everything on my Seiki SE501TS tv
<Profile id="RokuMPApp" name="Roku Media Player" extendsProfileId="1">
<Detection>
<HttpHeaders>
<User-Agent>.*ROKU.*</User-Agent>
</HttpHeaders>
</Detection>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
</MediaFormatProfiles>
<Matches container="ogg" />
<Matches container="flv" />
<Audio targetContainer="mp3" aBitrate="320">
<Matches container="flac" />
<Matches container="lpcm" />
<Matches container="adts" />
<Matches container="asf" />
<Matches container="rtp" />
<Matches container="rtsp" />
<Matches container="wavpack" />
<Matches container="mpc" />
<Matches container="ape" />
</Audio>
<OnlineTranscoding>
<Video targetContainer="applehttp" targetVCodec="h264" maxVBitrate="12000" targetACodec="mp3" aBitrate="320" forceStereo="true"> <!-- dont transcode to ac3 -->
<Matches container="mp4" />
<Matches container="applehttp" vCodec="h264" />
</OnlineTranscoding>
<GenericTranscoding>
<Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360" forceStereo="true" />
</GenericTranscoding>
<Subtitles>
<SoftSubs mime-type="text/srt" />
</Subtitles>
-Xmx1536m
no options
cheers all.
