Embedded subtitles not displayed
stefana888
Post Sun Apr 12, 2015 8:18 pm
I have a .mkv file of about 1GB with an embedded .srt subtitle track as shown in ffmpeg. Embedded subs is activated in the Serviio console. When I play the file no subtitle is detected by the TV. But when I extract the subtitles manually as an external file a subtitle menu is available and the subtitles are displayed as expected.
What is the possible reason to this? May the processor (1.8 GHz Atom Dual Core) really not be fast enough for Serviio to extract it? I doubt that because it is capable to do some quite heavy transcoding with ffmpeg. No informative logging is generated.
Post Mon Apr 13, 2015 9:06 pm
Re: Embedded subtitles not displayed
Did you specify the language code to extract? http://serviio.org/index.php?option=com ... icle&id=33
Post Mon Apr 13, 2015 11:44 pm
It also depends on the type of track. If they are in PGS (Blu-Ray) format, Serviio cannot extract them. I also have not had any luck with EIA-608/708 (Broadcast TV captions). VOBSUB (DVD) work fine.
stefana888
Post Tue Apr 14, 2015 7:35 pm
zip wrote:Did you specify the language code to extract? http://serviio.org/index.php?option=com ... icle&id=33
Yes, the language code is 'swe' (one track only). I tried both with and without the code since I was unsure if the code is mandatory.
stefana888
Post Tue Apr 14, 2015 7:40 pm
atc98092 wrote:It also depends on the type of track. If they are in PGS (Blu-Ray) format, Serviio cannot extract them. I also have not had any luck with EIA-608/708 (Broadcast TV captions). VOBSUB (DVD) work fine.
I tried a with many different downloaded movie rips. They sub track is in SubRip format which Serviio should handle.
Post Wed Apr 15, 2015 11:42 am
post ffmpeg -i of the file and detailed log of playing the file.
But yes, the request for subs could expire if it takes ages to extract the subtitles from the file.
stefana888
Post Tue Apr 21, 2015 6:27 pm
zip wrote:post ffmpeg -i of the file and detailed log of playing the file.
I use a network drive for the file here but the same problem exist using a local drive.
2015-04-21 20:06:45,706 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:37861: HEAD /resource/69/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.16:8895]]
2015-04-21 20:06:45,708 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:45,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:45,716 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:45,718 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'MEDIA_ITEM' received
2015-04-21 20:06:45,718 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:45,719 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:45,723 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:45,729 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 69, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-04-21 20:06:45,731 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Tue, 21 Apr 2015 18:06:45 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-21 20:06:45,760 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:53464: GET /resource/69/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.1.16:8895]]
2015-04-21 20:06:45,761 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:45,763 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:45,766 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:45,766 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'MEDIA_ITEM' received
2015-04-21 20:06:45,766 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:45,767 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:45,769 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:45,772 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 69, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-04-21 20:06:45,774 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:45,775 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:45,777 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:45,781 DEBUG [VideoDeliveryEngine] Delivering item '69' for client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:45,782 DEBUG [VideoDeliveryEngine] Delivering file 'Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv' in native format
2015-04-21 20:06:45,782 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:46,771 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 69) as read
2015-04-21 20:06:46,777 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-21 20:06:46,778 DEBUG [GETMethodProcessor] Stream entity has length: 1726698291
2015-04-21 20:06:46,779 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Tue, 21 Apr 2015 18:06:46 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 0-1726698290/1726698291,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=8099000;]]
2015-04-21 20:06:46,855 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:56278: GET /resource/69/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=1726618200-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.16:8895]]
2015-04-21 20:06:46,856 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:46,858 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:46,861 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:46,861 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'MEDIA_ITEM' received
2015-04-21 20:06:46,862 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:46,862 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:46,865 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:46,868 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 69, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-04-21 20:06:46,870 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:46,870 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:46,873 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:46,876 DEBUG [VideoDeliveryEngine] Delivering item '69' for client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:46,878 DEBUG [VideoDeliveryEngine] Delivering file 'Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv' in native format
2015-04-21 20:06:46,878 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:47,084 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-04-21 20:06:47,098 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 69) as read
2015-04-21 20:06:47,102 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-21 20:06:47,102 DEBUG [GETMethodProcessor] Stream entity has length: 80091
2015-04-21 20:06:47,103 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 80091,Date: Tue, 21 Apr 2015 18:06:47 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 1726618200-1726698290/1726698291,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-21 20:06:47,808 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:53438: GET /resource/69/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=5664-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.16:8895]]
2015-04-21 20:06:47,809 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:47,813 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:47,817 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:47,818 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'MEDIA_ITEM' received
2015-04-21 20:06:47,819 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:47,819 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:47,823 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:47,828 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 69, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-04-21 20:06:47,830 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:47,830 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:47,833 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:47,836 DEBUG [VideoDeliveryEngine] Delivering item '69' for client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:47,837 DEBUG [VideoDeliveryEngine] Delivering file 'Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv' in native format
2015-04-21 20:06:47,838 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:47,849 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 69) as read
2015-04-21 20:06:47,856 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-21 20:06:47,857 DEBUG [GETMethodProcessor] Stream entity has length: 1726692627
2015-04-21 20:06:47,858 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 1726692627,Date: Tue, 21 Apr 2015 18:06:47 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 5664-1726698290/1726698291,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-21 20:06:49,924 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:33627: HEAD /resource/69/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2015-04-21 20:06:49,928 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:49,932 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:49,936 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:49,937 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'MEDIA_ITEM' received
2015-04-21 20:06:49,938 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:49,938 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:49,942 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:49,947 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 69, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-04-21 20:06:49,951 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:49,956 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:50,021 DEBUG [SubtitlesService] Found embedded subtitles track: swe
2015-04-21 20:06:50,022 DEBUG [ResourceValuesBuilder] Softsubs for media item 69 found, will be served as a resource
2015-04-21 20:06:50,022 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Tue, 21 Apr 2015 18:06:49 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,CaptionInfo.sec: http://192.168.1.16:8895/resource/69/SUBTITLE.srt,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2015-04-21 20:06:50,458 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:60184: HEAD /resource/69/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2015-04-21 20:06:50,461 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:50,465 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:50,469 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:50,470 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'MEDIA_ITEM' received
2015-04-21 20:06:50,470 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 69 (local)
2015-04-21 20:06:50,471 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 69)
2015-04-21 20:06:50,475 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:50,479 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 69, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-04-21 20:06:50,483 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:50,488 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:50,539 DEBUG [SubtitlesService] Found embedded subtitles track: swe
2015-04-21 20:06:50,540 DEBUG [ResourceValuesBuilder] Softsubs for media item 69 found, will be served as a resource
2015-04-21 20:06:50,541 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Tue, 21 Apr 2015 18:06:50 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,CaptionInfo.sec: http://192.168.1.16:8895/resource/69/SUBTITLE.srt,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2015-04-21 20:06:50,592 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:47605: GET /resource/69/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.168.1.16:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2015-04-21 20:06:50,593 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:50,597 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-04-21 20:06:50,603 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-04-21 20:06:50,604 DEBUG [ResourceDeliveryProcessor] Request for resource 69 and type 'SUBTITLE' received
2015-04-21 20:06:50,608 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:50,611 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:50,658 DEBUG [SubtitlesService] Found embedded subtitle track: 0 (swe)
2015-04-21 20:06:50,661 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 69
2015-04-21 20:06:50,664 DEBUG [VideoDAOImpl] Reading a Video (id = 69)
2015-04-21 20:06:50,667 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:50,715 DEBUG [SubtitlesService] Found embedded subtitle track: 0 (swe)
2015-04-21 20:06:50,715 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 69
2015-04-21 20:06:50,716 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2015-04-21 20:06:50,719 DEBUG [FFMPEGWrapper] Invoking FFMPEG to extract SRT subtitle file from: Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv
2015-04-21 20:06:50,722 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe -i \\RT-N56U\sda1\ServiioShare\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv -y -an -vn -map 0:0 -c:s srt -f srt pipe:
2015-04-21 20:06:52,227 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2015-04-21 20:06:52,227 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-04-21 20:07:08,362 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (Broadcom 802.11bgn Wireless SDIO Adapter) and address 192.168.1.16, timeout = 0
2015-04-21 20:07:08,378 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 44cabc24-0b16-30ef-b62d-9cdfe58d490f
2015-04-21 20:07:10,342 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:31 (advertisement duration is 1800 sec.)
2015-04-21 20:07:12,576 DEBUG [SearchManager] Committing search index
2015-04-21 20:07:20,736 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-123,5,main]
2015-04-21 20:07:20,917 DEBUG [ProcessUtils] Killing the Windows process: 5872
2015-04-21 20:07:21,346 DEBUG [GETMethodProcessor] Stream entity has length: 4057
2015-04-21 20:07:21,347 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: smi/caption,Content-Length: 4057,Date: Tue, 21 Apr 2015 18:07:21 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Background,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-21 20:07:21,355 DEBUG [WebServer] I/O error: Software caused connection abort: recv failed
2015-04-21 20:07:42,579 DEBUG [SearchManager] Committing search index
2015-04-21 20:07:52,232 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2015-04-21 20:07:52,232 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-04-21 20:08:12,580 DEBUG [SearchManager] Committing search index
2015-04-21 20:08:32,128 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 3bfaf799-97a4-eec0-79a0-45a655627a39 from address 192.168.1.196
2015-04-21 20:08:32,376 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 3bfaf799-97a4-eec0-79a0-45a655627a39 from address 192.168.1.196
2015-04-21 20:08:42,582 DEBUG [SearchManager] Committing search index
2015-04-21 20:08:52,242 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2015-04-21 20:08:52,242 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-04-21 20:09:12,585 DEBUG [SearchManager] Committing search index
2015-04-21 20:09:25,141 DEBUG [PortMapper] Renewing port mapping lease
2015-04-21 20:09:25,144 DEBUG [UPnPWebGateway] Adding/updating router port mapping (23424 -> 23424) for IP 192.168.1.16 with lease of 1800 sec.
2015-04-21 20:09:42,588 DEBUG [SearchManager] Committing search index
2015-04-21 20:09:52,077 DEBUG [PlaylistDAOImpl] Reading all Playlists
2015-04-21 20:09:52,251 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2015-04-21 20:09:52,251 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-04-21 20:10:12,590 DEBUG [SearchManager] Committing search index
C:\Users\Stefan>ffmpeg -i \\RT-N56U\sda1\ServiioShare\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy\Fury.2014.SWESUB.DVDSCR.x2
4-Mr.Stiffy.mkv
ffmpeg version N-68675-g1515bfb Copyright (c) 2000-2014 the FFmpeg developers
  built on Dec 24 2014 22:56:55 with gcc 4.9.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconf
g --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca -
enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-li
opencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroeding
r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc -
enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable
libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib
  libavutil      54. 15.100 / 54. 15.100
  libavcodec     56. 16.100 / 56. 16.100
  libavformat    56. 16.101 / 56. 16.101
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  5.101 /  5.  5.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, matroska,webm, from '\\RT-N56U\sda1\ServiioShare\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy\Fury.2014.SWESUB.DVDS
R.x264-Mr.Stiffy.mkv':
    encoder         : libebml v1.3.0 + libmatroska v1.4.1
    creation_time   : 2014-12-06 09:20:45
  Duration: 02:14:59.05, start: 0.000000, bitrate: 1705 kb/s
    Stream #0:0(swe): Subtitle: subrip (default)
      BPS             : 36
      BPS-eng         : 36
      DURATION        : 02:03:34.630000000
      DURATION-eng    : 02:03:34.630000000
      NUMBER_OF_FRAMES: 1133
      NUMBER_OF_FRAMES-eng: 1133
      NUMBER_OF_BYTES : 33520
      NUMBER_OF_BYTES-eng: 33520
      _STATISTICS_WRITING_APP: mkvmerge v7.3.0 ('Nouages') 64bit built on Oct 22 2014 19:46:47
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.3.0 ('Nouages') 64bit built on Oct 22 2014 19:46:47
      _STATISTICS_WRITING_DATE_UTC: 2014-12-06 09:20:45
      _STATISTICS_WRITING_DATE_UTC-eng: 2014-12-06 09:20:45
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1: Video: h264 (High), yuv420p, 720x304 [SAR 1:1 DAR 45:19], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (def
ult)
      BPS             : 1383799
      BPS-eng         : 1383799
      DURATION        : 02:14:59.050000000
      DURATION-eng    : 02:14:59.050000000
      NUMBER_OF_FRAMES: 194183
      NUMBER_OF_FRAMES-eng: 194183
      NUMBER_OF_BYTES : 1400932326
      NUMBER_OF_BYTES-eng: 1400932326
    Stream #0:2: Audio: ac3, 48000 Hz, 5.1(side), fltp, 320 kb/s (default)
      BPS             : 320000
      BPS-eng         : 320000
      DURATION        : 02:14:58.880000000
      DURATION-eng    : 02:14:58.880000000
      NUMBER_OF_FRAMES: 253090
      NUMBER_OF_FRAMES-eng: 253090
      NUMBER_OF_BYTES : 323955200
      NUMBER_OF_BYTES-eng: 323955200
C:\Users\Stefan>
Post Fri Apr 24, 2015 12:16 pm
You can see that the ffmpeg process to extract the subs is killed after 30 seconds (by Serviio):
I'm not sure if remuxing the file would help (ie it might store the subs packets closer to the mkv file's beginning).
stefana888
Post Tue May 05, 2015 11:12 am
I tried remuxing with a later version of Mkvmerge but it is still not working. Any suggestioms?
Before:
C:\Users\Stefan>ffmpeg -i \\RT-N56U\sda1\ServiioShare\American.Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON\American.
Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON.mkv
ffmpeg version N-71737-gb410c69 Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.9.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfi
g --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libm
p3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --en
able-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --ena
ble-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enabl
e-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
  libavutil      54. 23.101 / 54. 23.101
  libavcodec     56. 35.101 / 56. 35.101
  libavformat    56. 31.100 / 56. 31.100
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 14.100 /  5. 14.100
Input #0, matroska,webm, from '\\RT-N56U\sda1\ServiioShare\American.Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON\Amer
ican.Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON.mkv':
    creation_time   : 2015-04-16 19:55:39
  Duration: 02:12:37.92, start: 0.000000, bitrate: 1119 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1280x530 [SAR 1:1 DAR 128:53], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (de
fault)
      _STATISTICS_WRITING_APP: mkvmerge v7.4.0 ('Circles') 32bit built on Dec 12 2014 12:10:09
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.4.0 ('Circles') 32bit built on Dec 12 2014 12:10:09
      _STATISTICS_WRITING_DATE_UTC: 2015-04-16 19:55:39
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-04-16 19:55:39
      BPS             : 733807
      BPS-eng         : 733807
      DURATION        : 02:12:37.909000000
      DURATION-eng    : 02:12:37.909000000
      NUMBER_OF_FRAMES: 190799
      NUMBER_OF_FRAMES-eng: 190799
      NUMBER_OF_BYTES : 729946829
      NUMBER_OF_BYTES-eng: 729946829
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
      BPS             : 384000
      BPS-eng         : 384000
      DURATION        : 02:12:37.920000000
      DURATION-eng    : 02:12:37.920000000
      NUMBER_OF_FRAMES: 248685
      NUMBER_OF_FRAMES-eng: 248685
      NUMBER_OF_BYTES : 381980160
      NUMBER_OF_BYTES-eng: 381980160
    Stream #0:2(swe): Subtitle: subrip (default)
      BPS             : 56
      BPS-eng         : 56
      DURATION        : 02:04:30.085000000
      DURATION-eng    : 02:04:30.085000000
      NUMBER_OF_FRAMES: 1298
      NUMBER_OF_FRAMES-eng: 1298
      NUMBER_OF_BYTES : 52585
      NUMBER_OF_BYTES-eng: 52585
    Stream #0:3(dan): Subtitle: subrip
      BPS             : 49
      BPS-eng         : 49
      DURATION        : 02:04:29.798000000
      DURATION-eng    : 02:04:29.798000000
      NUMBER_OF_FRAMES: 1231
      NUMBER_OF_FRAMES-eng: 1231
      NUMBER_OF_BYTES : 46320
      NUMBER_OF_BYTES-eng: 46320
    Stream #0:4(nor): Subtitle: subrip
      BPS             : 50
      BPS-eng         : 50
      DURATION        : 02:04:29.685000000
      DURATION-eng    : 02:04:29.685000000
      NUMBER_OF_FRAMES: 1279
      NUMBER_OF_FRAMES-eng: 1279
      NUMBER_OF_BYTES : 47383
      NUMBER_OF_BYTES-eng: 47383
    Stream #0:5(fin): Subtitle: subrip
      BPS             : 50
      BPS-eng         : 50
      DURATION        : 02:04:44.128000000
      DURATION-eng    : 02:04:44.128000000
      NUMBER_OF_FRAMES: 1489
      NUMBER_OF_FRAMES-eng: 1489
      NUMBER_OF_BYTES : 47281
      NUMBER_OF_BYTES-eng: 47281
After:
C:\Users\Stefan>ffmpeg -i "\\RT-N56U\sda1\ServiioShare\American.Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON\American
.Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON (1).mkv"
ican.Sniper.2014.SweSub.720p.BluRay.AC3.x264-SWAXXON (1).mkv':
    encoder         : libebml v1.3.1 + libmatroska v1.4.2
    creation_time   : 2015-05-05 10:53:26
fault)
      _STATISTICS_WRITING_APP: mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02
      _STATISTICS_WRITING_DATE_UTC: 2015-05-05 10:53:26
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-05-05 10:53:26
      BPS             : 733807
      BPS-eng         : 733807
      BPS             : 384000
      BPS-eng         : 384000
      BPS             : 56
      BPS-eng         : 56
      BPS             : 49
      BPS-eng         : 49
      BPS             : 50
      BPS-eng         : 50
      BPS             : 50
      BPS-eng         : 50
Post Tue May 05, 2015 8:11 pm
Try to run this command locally and check how long it takes.
ffmpeg.exe -i \\RT-N56U\sda1\ServiioShare\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv -y -an -vn -map 0:0 -c:s srt -f srt output.srt
You might also try to run the same command on the same file, but stored locally on your PC.
stefana888
Post Wed May 06, 2015 12:52 pm
I tried running your suggested test both with the file stored on a remote drive and stored on a local drive. On a remote drive ffmpeg takes several minutes and on a local drive it finishes in about 25 seconds.
I tried to play the remuxed file locally. A different I/O errror now in the log and ffmpeg appears not being killed by Serviio this time at the 30 sec timeout. Any suggestions?
2015-05-06 14:24:04,620 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:49332: HEAD /resource/78/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.16:8895]]
2015-05-06 14:24:04,621 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:04,626 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:04,630 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:04,631 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'MEDIA_ITEM' received
2015-05-06 14:24:04,632 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:04,633 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:04,668 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:04,674 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-05-06 14:24:04,678 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Wed, 06 May 2015 12:24:04 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-05-06 14:24:04,697 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:40763: GET /resource/78/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.1.16:8895]]
2015-05-06 14:24:04,698 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:04,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:04,704 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:04,705 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'MEDIA_ITEM' received
2015-05-06 14:24:04,705 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:04,705 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:04,707 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:04,710 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-05-06 14:24:04,712 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:04,712 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:04,714 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:04,717 DEBUG [VideoDeliveryEngine] Delivering item '78' for client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:04,718 DEBUG [VideoDeliveryEngine] Delivering file 'Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv' in native format
2015-05-06 14:24:04,718 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:04,720 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 78) as read
2015-05-06 14:24:04,754 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-05-06 14:24:04,755 DEBUG [GETMethodProcessor] Stream entity has length: 1726698291
2015-05-06 14:24:04,757 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Wed, 06 May 2015 12:24:04 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 0-1726698290/1726698291,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=8099000;]]
2015-05-06 14:24:04,799 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-05-06 14:24:04,805 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:33279: GET /resource/78/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=1726618200-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.16:8895]]
2015-05-06 14:24:04,805 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:04,807 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:04,809 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:04,810 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'MEDIA_ITEM' received
2015-05-06 14:24:04,810 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:04,810 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:04,812 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:04,815 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-05-06 14:24:04,817 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:04,817 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:04,819 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:04,822 DEBUG [VideoDeliveryEngine] Delivering item '78' for client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:04,823 DEBUG [VideoDeliveryEngine] Delivering file 'Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv' in native format
2015-05-06 14:24:04,823 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:04,825 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 78) as read
2015-05-06 14:24:04,830 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-05-06 14:24:04,830 DEBUG [GETMethodProcessor] Stream entity has length: 80091
2015-05-06 14:24:04,831 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 80091,Date: Wed, 06 May 2015 12:24:04 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 1726618200-1726698290/1726698291,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-05-06 14:24:05,501 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:54974: GET /resource/78/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=5664-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.16:8895]]
2015-05-06 14:24:05,502 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:05,507 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:05,512 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:05,513 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'MEDIA_ITEM' received
2015-05-06 14:24:05,514 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:05,515 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:05,520 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:05,524 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-05-06 14:24:05,526 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:05,526 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:05,529 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:05,533 DEBUG [VideoDeliveryEngine] Delivering item '78' for client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:05,534 DEBUG [VideoDeliveryEngine] Delivering file 'Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv' in native format
2015-05-06 14:24:05,535 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:05,538 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 78) as read
2015-05-06 14:24:05,544 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-05-06 14:24:05,545 DEBUG [GETMethodProcessor] Stream entity has length: 1726692627
2015-05-06 14:24:05,546 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 1726692627,Date: Wed, 06 May 2015 12:24:05 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 5664-1726698290/1726698291,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-05-06 14:24:07,618 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:53943: HEAD /resource/78/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2015-05-06 14:24:07,621 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:07,625 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:07,629 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:07,630 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'MEDIA_ITEM' received
2015-05-06 14:24:07,631 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:07,633 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:07,641 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:07,647 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-05-06 14:24:07,649 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:07,653 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:07,656 DEBUG [SubtitlesService] Found embedded subtitles track: swe
2015-05-06 14:24:07,657 DEBUG [ResourceValuesBuilder] Softsubs for media item 78 found, will be served as a resource
2015-05-06 14:24:07,658 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Wed, 06 May 2015 12:24:07 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,CaptionInfo.sec: http://192.168.1.16:8895/resource/78/SUBTITLE.srt,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2015-05-06 14:24:07,672 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:46193: HEAD /resource/78/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2015-05-06 14:24:07,673 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:07,675 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:07,678 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:07,678 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'MEDIA_ITEM' received
2015-05-06 14:24:07,678 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 78 (local)
2015-05-06 14:24:07,679 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 78)
2015-05-06 14:24:07,681 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:07,683 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 78, format MATROSKA and profile Samsung TV / player (C/D-series)
2015-05-06 14:24:07,685 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:07,687 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:07,691 DEBUG [SubtitlesService] Found embedded subtitles track: swe
2015-05-06 14:24:07,691 DEBUG [ResourceValuesBuilder] Softsubs for media item 78 found, will be served as a resource
2015-05-06 14:24:07,692 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 1726698291,Date: Wed, 06 May 2015 12:24:07 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,CaptionInfo.sec: http://192.168.1.16:8895/resource/78/SUBTITLE.srt,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2015-05-06 14:24:07,711 DEBUG [ServiioHttpService] Incoming request from /192.168.1.196:52218: GET /resource/78/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.168.1.16:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2015-05-06 14:24:07,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:07,714 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2015-05-06 14:24:07,715 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.196, Profile=Samsung TV / player (C/D-series)'
2015-05-06 14:24:07,716 DEBUG [ResourceDeliveryProcessor] Request for resource 78 and type 'SUBTITLE' received
2015-05-06 14:24:07,718 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:07,720 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:07,723 DEBUG [SubtitlesService] Found embedded subtitle track: 0 (swe)
2015-05-06 14:24:07,725 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 78
2015-05-06 14:24:07,727 DEBUG [VideoDAOImpl] Reading a Video (id = 78)
2015-05-06 14:24:07,729 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:07,732 DEBUG [SubtitlesService] Found embedded subtitle track: 0 (swe)
2015-05-06 14:24:07,732 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 78
2015-05-06 14:24:07,733 DEBUG [MediaItemDAOImpl] Getting file of media item 78
2015-05-06 14:24:07,735 DEBUG [FFMPEGWrapper] Invoking FFMPEG to extract SRT subtitle file from: Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv
2015-05-06 14:24:07,736 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe -i C:\Users\Stefan\Videos\Fury.2014.SWESUB.DVDSCR.x264-Mr.Stiffy.mkv -y -an -vn -map 0:0 -c:s srt -f srt pipe:
2015-05-06 14:24:34,552 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2015-05-06 14:24:34,552 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-05-06 14:24:36,011 DEBUG [GETMethodProcessor] Stream entity has length: 74334
2015-05-06 14:24:36,012 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: smi/caption,Content-Length: 74334,Date: Wed, 06 May 2015 12:24:36 GMT,Server: Windows 8.1, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Background,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-05-06 14:24:36,018 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-05-06 14:24:46,766 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 3bfaf799-97a4-eec0-79a0-45a655627a39 from address 192.168.1.196
2015-05-06 14:24:47,012 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 3bfaf799-97a4-eec0-79a0-45a655627a39 from address 192.168.1.196
Post Wed May 06, 2015 9:01 pm
It meant the TV closed the connection for the subtitles request. Perhaps 25 seconds is too long still for the TV.
stefana888
Post Wed May 06, 2015 9:40 pm
zip wrote:It meant the TV closed the connection for the subtitles request. Perhaps 25 seconds is too long still for the TV.
OK the TV initiates the connection close. But this happens after the subs extraction has finished. It doesn't make sense. Or does it? I will try shorten the embedded subs file (reduce time) and see what happens...stay tuned.
stefana888
Post Sat May 09, 2015 5:49 am
It took about the same amount of time (20s) for ffmpeg to run with an extreme short subtitle file. It can not be optimal. I guess the TV cannot be used with embedded subs??
Post Sun May 10, 2015 11:09 am
It works for me, but I tried it on a file which takes 1 second to extract the subtitle.
Users browsing this forum: No registered users and 218 guests
