Poor Picture
• Page 1 of 1
Just replaced my 50 in Panasonic plasma with a 55 in Vizio LCD E55-C1. I use a Sony blu ray BDP-BX37 to use for my DLNA device and worked great with the Panasonic. Picture is great with broadcast on new Vizio, but awful when streaming. I've tried changing settings on TV and no luck. Is there something I can change with Seviio or have I purchased a TV that just doesn't mesh
Re: Poor Picture
cruisinfanatic wrote:Just replaced my 50 in Panasonic plasma with a 55 in Vizio LCD E55-C1. I use a Sony blu ray BDP-BX37 to use for my DLNA device and worked great with the Panasonic. Picture is great with broadcast on new Vizio, but awful when streaming. I've tried changing settings on TV and no luck. Is there something I can change with Seviio or have I purchased a TV that just doesn't mesh
I have a smaller Vizio in my home office (24"), and I'm not impressed with its DLNA abilities. Of course, this is a very inexpensive set that I mainly bought for monitoring broadcast TV, as well as a second computer monitor when I want an expanded desktop. At least with my set, it requires transcoding for practically all my files. Perhaps yours is being transcoded when it's not necessary. What happens if you use the Generic profile, which does not transcode anything? Will anything play, and if it does, does it look ok?
Re: Poor Picture
atc98092 wrote:cruisinfanatic wrote:Just replaced my 50 in Panasonic plasma with a 55 in Vizio LCD E55-C1. I use a Sony blu ray BDP-BX37 to use for my DLNA device and worked great with the Panasonic. Picture is great with broadcast on new Vizio, but awful when streaming. I've tried changing settings on TV and no luck. Is there something I can change with Seviio or have I purchased a TV that just doesn't mesh
the only thing I changed was the TV, not the DLNA device used. The faces look very plastered (too much makeup) looking and look like they are sweating in every scene on this TV
Re: Poor Picture
cruisinfanatic wrote:the only thing I changed was the TV, not the DLNA device used. The faces look very plastered (too much makeup) looking and look like they are sweating in every scene on this TV
Whoops. I missed that. Sorry
I am assuming you are using the same connection method between the BD player and TV (HDMI?). There shouldn't be anything different in the appearance between the two sets unless the TV settings are out of whack. Some sets can have different settings for each input. That could explain the difference between broadcast TV and the HDMI input.
If you play a Blu Ray disc does it look ok? How about some other streaming source, such as Netflix (again using the BD player)? Does the Sony recognize the proper resolution for the TV? It should automatically set itself to 1080p output, but who knows?
Re: Poor Picture
atc98092 wrote:cruisinfanatic wrote:the only thing I changed was the TV, not the DLNA device used. The faces look very plastered (too much makeup) looking and look like they are sweating in every scene on this TV
Whoops. I missed that. Sorry![]()
yes, everything is the same. Now I just discovered that dvd,s look terrible too. I guess it's time to call Vizio. Home it's a simple fix.
Re: Poor Picture
Yeah, if the DVD looks bad, then there's something up between the player and the TV. Nothing to do with Serviio. Hope you get it resolved soon!
• Page 1 of 1
