MediaBrowser Data Port Setting?
Lavarocker
Post Sun Apr 19, 2015 2:09 am
Greetings,
Am enjoying the solid features of Serviio :) . I have a simple question: can the port number of the Mediabrowser be changed? I've poked around in the config files and don't see anything obvious. I'd prefer to use something a bit easier to remember on my LAN.
If it's compiled/fixed, that would be a handy future feature to allow the user to change.
Thanks!
Post Sun Apr 19, 2015 11:43 pm
Re: MediaBrowser Data Port Setting?
I believe it's embedded within one of the jar files. Couldn't say which one. I seem to recall Zip advising someone how to change it. However, remember that every time you update Serviio, that file will likely be overwritten. So there's now way to change it long term.
It would be nice to be able to modify it more easily.
