Log file Size
Post Sun Apr 19, 2015 9:24 am
Log file Size
I cannot seem to be able to vary the log file size. I have my own "standard" log4j.xml file as below - I set DEBUG mode on, excluding library details, and also set the log file size to 5000K (5MB):
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<!--  Log4j Configuration                                                  -->
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="false">
    <appender name="FILE" class="org.apache.log4j.RollingFileAppender">
       <param name="Threshold" value="DEBUG"/>
       <param name="Append" value="true" />
      <param name="File" value="${serviio.home}/log/serviio.log" />
      <param name="MaxFileSize" value="5000KB" />
      <param name="MaxBackupIndex" value="5" />
      <param name="Encoding" value="UTF-8" />
      <layout class="org.apache.log4j.PatternLayout">
         <param name="ConversionPattern" value="%d{ISO8601} %-5p [%c{1}] %m%n"/>
      </layout>
   </appender>
   <category name="org.serviio">
      <priority value="DEBUG"/>
   </category>
   <category name="org.serviio.library.local">
      <priority value="INFO"/>
   </category>
   <category name="org.serviio.library.online">
   </category>
   <category name="org.serviio.library.dao">
   </category>
   <category name="com.sun.syndication">
      <priority value="ERROR"/>
   </category>
   <category name="org.jaudiotagger">
   </category>
   <category name="org.restlet">
      <priority value="OFF"/>
   </category>
   <category name="LogService"> <!-- Restlet access log -->
   </category>
   <category name="org.apache.jcs">
      <priority value="WARN"/>
   </category>
   <root>
      <appender-ref ref="FILE"/>
   </root>
</log4j:configuration>
The DEBUG settings work fine, but the log file size setting doesn't - it keeps growing indefinitely. I have compared it to the standard log4j.xml file that ships with Serviio, and cannot see what is wrong. Can anyone see what is wrong, or is it a bug?
Post Mon Apr 20, 2015 12:33 pm
Re: Log file Size
If this is on Windows, it's probably caused by the log file being used by both, the server and the console (the file is locked by these two processes). So if you exit the console, the server should be able to manage the log file correctly.
Users browsing this forum: Google [Bot] and 31 guests
