Bravia W Series playback hangs after about 1 minute
Lowlander
Post Mon Apr 20, 2015 12:49 pm
Hi there,
I'd like to dig deeper into an issue that intermittendly accompanied me through various versions of Serviio, two Bravias and two versions of Windows Server:
A video starts to play and hangs after about one minute. Playback resumes after pressing pause/start, and likely, after another minute, hangs again. Possible fix for the particular video: Exit video and choose again from the list. Playback is resumed ok and carries on, passing the magic 1 minute barrier. Later, press pause to go and fetch a drink, press play and after about one minute, the video hangs and the whole game starts over again.
The Bravia has a wired connection to Server 2008 running Serviio. The video is mkv/avc/ac3 and IMHO played natively. The temp drive has been changed from SSD to HDD without any change.
Any suggestions where to poke next highly appreciated.
CU,
Low
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
Post Mon Apr 20, 2015 3:03 pm
Re: Bravia W Series playback hangs after about 1 minute
Suspect too low cpu power if movie was transcoding/remuxed (check detailed logging).
or
A network bottleneck. Check video bitrate with this tool viewtopic.php?f=17&t=2133 (is it for all your movies ?)
Lowlander
Post Thu Apr 23, 2015 9:14 am
Please bear with me, I'm still working on testing and providing more information...
Post Thu Apr 23, 2015 4:05 pm
Do you check/enabled subtitles on serviio console ? try disabling.
Please enable detailed logging and check that video was delivered in native format.
