BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
bikergrove
Post Sun Nov 24, 2013 10:47 am
Re: BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
think this is broke thumbnails do not show?
patanpatan
Post Wed Feb 12, 2014 10:39 pm
Fixed thumbs (I'm not the author of the plugin, I just fixed that)
Beeg.groovy
(9.31 KiB) Downloaded 2578 times
matwalaboy
Post Thu Jan 01, 2015 2:22 pm
The list shows up right on my sony bravia - but when I click on any of them to play it says "playback not available" - any clue what could be going wrong. Just beginning to understand how some of this works, hence could be doing something silly maybe. Any help appreciated.
blase
Post Sun Mar 15, 2015 3:03 pm
I regard being had problems with version 11 from a few days ago I'm having this error
2015-03-15 16:00:30,215 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 400 error
org.serviio.upnp.protocol.http.transport.InvalidResourceRequestException: Invalid incoming request: /resource/1000000100002158/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0
        at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:69)
        at org.serviio.upnp.protocol.http.transport.AbstractProtocolHandler.getRequestedResourceDescription(AbstractProtocolHandler.java:36)
        at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:65)
        at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
        at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
        at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:196)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 3
        at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:66)
        ... 8 more
2015-03-15 16:00:31,986 WARN  [VideoDeliveryEngine] Cannot extract expired URL, using previous one which might not work
2015-03-15 16:00:33,937 WARN  [ProcessExecutor] Process /volume1/@appstore/Serviio/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
creationdate    : Tue Aug 30 16:53:51 2011
Encoded_With    : Sorenson Squeeze
Duration: 00:02:02.00, start: 0.000000, bitrate: 12 kb/s
Stream #0:0: Video: vp6f, yuv420p, 640x480, 49 kb/s, 1 tbr, 1k tbn, 1k tbc
Stream map '0:1' matches no streams.
2015-03-15 16:00:57,246 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/volume1/@tmp/Serviio/transcoding-temp-1000000100002158-1-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/volume1/@tmp/Serviio/transcoding-temp-1000000100002158-1-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
        at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
        at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
        at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
        at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
apart from that I 've stopped seeing the previous images
thanks
borjus
Post Mon Apr 20, 2015 6:57 pm
It still will not work for me: The list shows up right on my lg tv, but when I click on any of them to play get a blue screen with lyrics that say go beeg.com
I'm using Serviio v.1.5.2 on OS X Yosemite.
Am I doing something wrong?
mame32
Post Tue Jul 14, 2015 11:26 pm
I have Fixed Thumbnails and Videos.
It works for me. :D
2016/09/16 --> This plugin is not working any more. :(
This is because the beeg web site is rendered vía JavaScript in real time when your WebBrowser request any page.
This plugin uses the Groovy request to the website, but JavaScript don´t renders nothing into this "request". Therefore that's impossible to obtain urls to the Thumbnails and Links that are necessary to show in Serviio Server.
I dont´t know if the last version of Groovy Request has this capabilities (render pages html with javascript and css enabled)
One Idea to Programmers can be to use a proxy server that renders the html + javascript and then apply the Plugin parser normally... :roll:
I have no time to investigate this idea...(if it were possible..) :?:
Beeg.groovy
Version 12
(9.63 KiB) Downloaded 2269 times
tstrike
Post Thu Aug 20, 2015 2:12 am
mame32 wrote:I have Fixed Thumbnails and Videos.
It works for me. :D
I done this but no streams... I will turn up logging but it creates the Title of the WebResource but no videos
bikergrove
Post Fri Nov 06, 2015 4:58 pm
Can this be fixed has its not working 8-)
bikergrove
Post Thu Nov 12, 2015 7:32 pm
I mean can the plugin be fixed not the web site :shock:
paxri01
Post Fri Mar 04, 2016 2:48 am
This plug-in used to work for me, but not so much now. I have upgraded to Serviio 1.6, Beeg.groovy v12 and still no luck.
Keep getting index is out of range error.
Thanks for any assistance on this!
2016-03-03 21:22:26,796 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://beeg.com/1, will try again soon: Unexpected error while invoking plugin (Beeg): index is out of range 0..-1 (index = 0)
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (Beeg): index is out of range 0..-1 (index = 0)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
   at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
   at Beeg.extractItems(Beeg.groovy:132)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask.run(FutureTask.java:266)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
   ... 1 more
michaelrash
Post Tue Jan 24, 2017 10:07 pm
bikergrove wrote:think this is broke thumbnails do not show?
not a massive fan tbh. but kind of a cool looking site i must say :)
Jonna
Post Thu May 30, 2019 7:47 am
As it said, the tag must be valid. See the tags tab for the list.Also as it said the default number displayed is 10 AllPetsExpert
. If you want more use the "for" option.
Previous
Return to Available plugins
