File is corrupt or not supported
martinskn
Post Sat Feb 26, 2011 3:39 pm
I am fairly new to the serviio though my Sony BDP-s570 is working great and I have watched several movies on it paired with serviio.
I am having problems with one movie and I cannot figure out why I keep getting a file is corrupt. I can play this movie on a standard VLC player just fine. I have tried ripping it mp4 and mkv and Serviio does not like it. It shows up in the list of movies but will not play it.
Is there something else I could try?
Post Sat Feb 26, 2011 4:28 pm
Re: File is corrupt or not supported
can you Provide details of a video file that doesn't play. theres a how to in my signiture.
mmmmmmmmmmh
Post Sun Oct 30, 2011 7:01 pm
I have had the same problem with my sony BDV-570 player. I have pasted below the output of what you requested. I did notice that it seems like the files that don't play are "DivX 5" per MediaInfo, while those that do play are "XviD" - but I didn't check all of the files.
ffmpeg:
Input #0, avi, from 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX':
encoder : VirtualDubMod 1.5.10.1 (build 2366/release)
Duration: 02:24:33.75, start: 0.000000, bitrate: 775 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 580x234 [PAR 1:1 DAR 290:117], 23.98 tbr
, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 96 kb/s
MediaInfo:
Format : AVI
File size : 802 MiB
Duration : 2h 24mn
Overall bit rate : 776 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 2h 24mn
Bit rate : 671 Kbps
Width : 580 pixels
Height : 234 pixels
Display aspect ratio : 2.479
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.206
Stream size : 693 MiB (86%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 24mn
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 99.3 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 504 ms
