ffmpeg command?
edraven
Post Sat Feb 26, 2011 3:37 pm
ffmpeg command?
I'm trying to figure out if my device is powerful enough to run serviio before I go through with installing it. Could someone post an example of the exact ffmpeg command serviio would use to transcode a mkv for a ps3?
Post Sat Feb 26, 2011 4:28 pm
Re: ffmpeg command?
wouldnt it be quicker to just ask and let us tell you if it would work LOL
Post Sat Feb 26, 2011 4:50 pm
Re: ffmpeg command?
there are different commands use, depends on the source/taget file types and whether you're transcoding or remuxing. Remuz isok on any hardware, transcode (especially hd content) requires more CPU. The PS3 profile remuxes MKV, so you should be ok.
