Sony BDP-BX37 - "There is no playable file"
got2bfree.lrh
Post Fri Apr 24, 2015 3:55 am
I'm running Windows 8 and Serviio 1.5.2. Serviio automatically detected my bluray device (Sony BDP-BX37) and it's using the profile: "Sony BDP-Sx70/SMP-N100(2010)". The light on the Render Profile screen is orange though. :-( Also on the Bluray it displays the the folders. It will recognize and play my music files which are MP3s.
However I cannot get it to load any video content. For example I installed the Tube+ plugin in the plugins folder. Then I added the following in the Online Sources tab:
Source Type = Web Resource
Source URL = http://www.tubeplus.is/player/2161885/C ... clqq0icdk5
Display Name = Criminal Minds Mr. Scratch
When I went to the online folder under video on my bluray player I got message: "There is no playable file".
Any ideas?
Thanks!
JP
Post Fri Apr 24, 2015 8:07 am
Re: Sony BDP-BX37 - "There is no playable file"
Do you see them one the Serviio Browser ?
Enable detailed logging and check if plugins streams are added to library.
got2bfree.lrh
Post Sun Apr 26, 2015 12:54 am
Thanks so much! I was surprised to see a reply so fast. I forgot to turn on the notifications...but anyway, this is what I've got:
I have 2 plugins installed:
TubePlus - Added O.K. but get the following error on a feed:
2015-04-25 17:12:36,056 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://www.tubeplus.is/player/2161885/C ... clqq0icdk5, waiting for expiry time to try again: Error during feed parsing, provided URL probably doesn't point to a valid RSS/Atom feed. Message: Invalid XML: Error on line 25: The element type "img" must be terminated by the matching end-tag "</img>".
org.serviio.library.online.metadata.OnlineResourceParseException: Error during feed parsing, provided URL probably doesn't point to a valid RSS/Atom feed. Message: Invalid XML: Error on line 25: The element type "img" must be terminated by the matching end-tag "</img>"
TvheadendChannels - Not added
2015-04-25 16:56:44,942 WARN [PluginCompilerThread] Plugin TvheadendChannels.groovy failed to compile: startup failed:
C:\Program Files\Serviio\plugins\TvheadendChannels.groovy: 4: unexpected token: < @ line 4, column 1.
<!DOCTYPE html>
1 error
Oh...and I do not see the files in the Serviio Browser. But I tested adding some audio (mp3) and I can see those fine, under the folder icon.
Thanks again!
got2bfree.lrh
Post Sun Apr 26, 2015 2:44 am
It seems I've made some progress on this issue. I was lucky enough to find this issue resolved by JAB_98 in this thread:
viewtopic.php?f=20&t=14176&p=100205&hilit=add+tubeplus#p100210
For the Tubeplus plugin, I can also confirm the plugin file is pointing to the wrong domain.
Live domain address is: http://www.tubeplus.is
Plugin domain address is: http://www.tubeplus.me
When I did a find and replace all instances from "tubeplus.is" to "tubeplus.me" I was able to get tubeplus working using the following settings:
Source URL = http://www.tubeplus.is/player/819210/Cr ... s/season_2
Display Name = Criminal Minds Season 2
Worked like a charm.
I believe the TvheadendChannels plugin is a different issue. So if anyone has any ideas, that would be great.
Post Sun Apr 26, 2015 8:14 am
Please post issues on specific plugins forum section. Thanks.
