Suppling new MetadataExtractor
dogo2
Post Sun Apr 19, 2015 1:48 pm
I'd like to suppy a new MetadataExtractor. How do I register it with Serviio?
Post Mon Apr 20, 2015 11:03 am
Re: Suppling new MetadataExtractor
That is not available through the plugin API.
What extractor do you have?
dogo2
Post Fri Apr 24, 2015 10:49 pm
I'd like to provide an Extractor for DSF files: http://dsd-guide.com/sites/default/file ... Spec_E.pdf
If you're not able to supply this as API, I'll just try to extend the jaudiotag lib and let it return the ID3 tags
Post Sun Apr 26, 2015 11:14 am
Yes, that would be the best place to implement it :-) let me know when there is a version I can use in Serviio.
dogo2
Post Tue May 05, 2015 5:19 pm
Hi again,
I've made a contribution (https://bitbucket.org/ijabz/jaudiotagger/pull-request/8/issue-62-added-reading-dsf-file-support/diff) to jaudiotagger. Maybe you'd like to check it out. Can you work with an AudioFile containing GenericAudioHeader and an AbstractID3v2Tag only?
Post Tue May 05, 2015 8:08 pm
I guess that should be fine. Thanks for the work, I'll wait for their release and upgrade. Perhaps you can keep an eye on that too and ping me to remind me.
dogo2
Post Sun Jul 05, 2015 3:53 pm
It has been a while, but the new version of jaudiotagger is now online: https://bitbucket.org/ijabz/jaudiotagger/downloads
Post Sat Jul 11, 2015 10:09 am
great, I'll upgrade it for 1.6
Return to Plugin development
