Online sources disappeared since update
JonnyL
Post Mon Apr 13, 2015 9:46 pm
I'm having trouble accessing online sources since updating from 1.4* to 1.5.1 then 1.5.2.
I've been using this for some time now successfully streaming http sources and now they are not visible on other devices. Streaming through acestream and sopcast on http://localhost:8902/tv.asf & http://127.0.0.1:8902/
I mostly stream to serviigo on android tablet but have tried out other DLNA apps etc with the same result. Prior to the update they were visible in the online sections but now this shows no sources available.
Sources added to the library and show with the green tick when the stream url is checked when they are active.
Tried re-adding sources and re-installing serviigo and other apps.
Any help much appreciated.
JonnyL
Post Sat Apr 18, 2015 4:10 pm
Re: Online sources disappeared since update
Hi again,
Anyone know how long it usually takes for someone from serviio to respond?
Thanks very much
PervySage
Post Sat Apr 25, 2015 2:18 am
I'm getting the same issue, at first I was able to fix it by updating the plugins, but that was only temporary and I'm now getting the same issue again :(
Post Sun Apr 26, 2015 1:53 pm
you have to post some detailed logs of adding the online resource
Users browsing this forum: Baidu [Spider] and 31 guests
