Selecting optimus profile
I only remember that the TV was showing smooth streaming in MP4, all attempts to do it from .tts files have failed. Now here's the url of the stream which is active and correctly from Serviio Console (v1.5):
http://live-edge01.telecentro.net.ar:19 ... ylist.m3u8?
Here's what ffmpeg -i command shows (I have no idea what it means):
C:\Users\Pableeeto>ffmpeg -i http://live-edge01.telecentro.net.ar:1935/live/13hd
-360/playlist.m3u8?
ffmpeg version N-71727-g46778ab Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.9.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-l
ibilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enab
le-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --en
able-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --ena
ble-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc
--enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enabl
e-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --ena
ble-decklink --enable-zlib
libavutil 54. 23.101 / 54. 23.101
libavcodec 56. 35.101 / 56. 35.101
libavformat 56. 31.100 / 56. 31.100
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 14.100 / 5. 14.100
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Using network protocols without global network initialization. Please use avform
at_network_init(), this will become mandatory later.
Last message repeated 5 times
Input #0, hls,applehttp, from 'http://live-edge01.telecentro.net.ar:1935/live/13
hd-360/playlist.m3u8?':
Duration: N/A, start: 34930.102856, bitrate: N/A
Program 0
variant_bitrate : 1233089
Stream #0:0: Data: timed_id3 (ID3 / 0x20334449)
Stream #0:1: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yu
v420p, 640x360 [SAR 1:1 DAR 16:9], 30 fps, 30 tbr, 90k tbn, 60 tbc
Stream #0:2: Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, flt
p, 63 kb/s
I think it's not a hardware problem from the DLNA server, it's an i5 3230, 8Gb RAM, Serviio Console is using the Nvidia GPU.
I hope you can help me...thanks
