nomedia file -- linux 1.5.2
rikm
Post Tue Apr 28, 2015 1:27 pm
> Ignored folders
> If you want to omit some folders (and their subfolders) from being indexed, just create an empty file .nomedia in the folder.
...this does not seem to work, or at least the log still shows the database churning thru stuff it's supposed to be ignoring
Post Tue Apr 28, 2015 11:23 pm
Re: nomedia file -- linux 1.5.2
If the files were added previously, they will stay there. This only applies to finding new files, and they should not be added if there is the .nomedia file in the directory.
If you think otherwise, post detailed log of files being added and also post directory listing where the .nomedia file is.
rikm
Post Wed Apr 29, 2015 12:21 pm
...hmmm, well I did add the dotfile after serviio got started, so that would explain it...but I just renamed the TLD of the branch of the music tree that I want it to ignore [the sub-dir where the .nomedia file resides, I mean] and the log showed the database pretty much immediately starting to add all the stuff in the 'new' dir all over again...
Renamed it again, just to be sure, and the log shows it being scanned and added again...will pressing the 'Force Refresh' button in the console make a difference, or to I really need to re-initialize the database to make it go away?
Post Wed Apr 29, 2015 11:49 pm
No, it should ignore any files from being added if the .nomedia file is in the same directory or any of the parent directories.
Users browsing this forum: No registered users and 50 guests
