x265 Transcoding does not work on Samsung TV
mark_sa
Post Thu Apr 23, 2015 3:29 pm
Hi.
I have a file encoded with x265 profile, And I try to play it on Samsung LA32D550 TV (Series C/D)
Since the TV does not support this codec, I'd expect Serviio to transcode it, however I still get "Unsupported Codec" message on tv when trying to play the file.
Can someone advice how to enable this transcoding? (except re-encoding the file offline)
File details are below, serviio log is attached
Thanks!
File info:
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, matroska,webm, from 'C:\Movies\MyMovie.720p.HDTV.2CH.x265.HEVC-PSA.mkv':
    title           : PSArips.com | MyMovie.720p.HDTV.2CH.x265.HEVC-PSA.mkv
    encoder         : libebml v1.3.1 + libmatroska v1.4.2
    creation_time   : 2015-02-26 20:20:11
  Duration: 01:03:36.23, start: 0.000000, bitrate: 447 kb/s
    Stream #0:0: Video: hevc (Main), yuv420p(tv, bt709), 1280x720 [SAR 1:1 DAR 1
6:9], 25 fps, 25 tbr, 1k tbn, 25 tbc (default)
      BPS             : 397910
      BPS-eng         : 397910
      DURATION        : 01:03:36.120000000
      DURATION-eng    : 01:03:36.120000000
      NUMBER_OF_FRAMES: 95403
      NUMBER_OF_FRAMES-eng: 95403
      NUMBER_OF_BYTES : 189809486
      NUMBER_OF_BYTES-eng: 189809486
      _STATISTICS_WRITING_APP: mkvmerge v7.6.0 ('Garden of Dreams') 64bit built
on Feb  8 2015 13:04:34
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.6.0 ('Garden of Dreams') 64bit bu
ilt on Feb  8 2015 13:04:34
      _STATISTICS_WRITING_DATE_UTC: 2015-02-26 20:20:11
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-02-26 20:20:11
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default)
      title           : Stereo
      BPS             : 48000
      BPS-eng         : 48000
      DURATION        : 01:03:36.064000000
      DURATION-eng    : 01:03:36.064000000
      NUMBER_OF_FRAMES: 89439
      NUMBER_OF_FRAMES-eng: 89439
      NUMBER_OF_BYTES : 22896690
      NUMBER_OF_BYTES-eng: 22896690
    Stream #0:2: Subtitle: subrip (default)
      BPS             : 50
      BPS-eng         : 50
      DURATION        : 01:03:24.321000000
      DURATION-eng    : 01:03:24.321000000
      NUMBER_OF_FRAMES: 808
      NUMBER_OF_FRAMES-eng: 808
      NUMBER_OF_BYTES : 23792
      NUMBER_OF_BYTES-eng: 23792
Mediainfo
Unique ID                                : 201223212502187771209370177582142650659 (0x97622E590E27BCBD9A8D066C66F0F923)
Complete name                            : C:\Movies\MyMovie.720p.HDTV.2CH.x265.HEVC-PSA\MyMovie.720p.HDTV.2CH.x265.HEVC-PSA.mkv
Format version                           : Version 4 / Version 2
File size                                : 204 MiB
Duration                                 : 1h 3mn
Overall bit rate                         : 448 Kbps
Movie name                               : PSArips.com | MyMovie.720p.HDTV.2CH.x265.HEVC-PSA
Encoded date                             : UTC 2015-02-26 20:20:11
Writing application                      : mkvmerge v7.6.0 ('Garden of Dreams') 64bit built on Feb  8 2015 13:04:34
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
NUMBER_OF_FRAMES                         : 808
_STATISTICS_WRITING_APP                  : mkvmerge v7.6.0 ('Garden of Dreams') 64bit built on Feb  8 2015 13:04:34
_STATISTICS_WRITING_DATE_UTC             : 2015-02-26 20:20:11
_STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main@L3.1@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 1h 3mn
Frame rate                               : 25.000 fps
Writing library                          : x265 1.5:[Windows][GCC 4.9.0][64 bit]
Encoding settings                        : wpp / ctu=64 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / no-fast-cbf / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / weightp / no-weightb / aq-mode=2 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / psy-rdoq=0.00 / signhide / lft / sao / no-sao-non-deblock / b-pyramid / cutree / rc=crf / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Color range                              : Limited
NUMBER_OF_FRAMES                         : 95403
Format profile                           : HE-AACv2 / HE-AAC / LC
Codec ID                                 : A_AAC
Duration                                 : 1h 3mn
Channel(s)                               : 2 channels / 2 channels / 2 channels
Channel positions                        : Front: L R / Front: L R / Front: L R
Sampling rate                            : 48.0 KHz / 48.0 KHz / 24.0 KHz
Delay relative to video                  : -105ms
Title                                    : Stereo
NUMBER_OF_FRAMES                         : 89439
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
serviiolog.txt
(114.52 KiB) Downloaded 1037 times
Post Thu Apr 23, 2015 11:42 pm
Re: x265 Transcoding does not work on Samsung TV
That appears to be a pretty old version of FFMPEG. What version of Serviio are you using? I'm not sure exactly when FFMPEG began supporting x265.
My first suggestion is to update your FFMPEG with the latest 64 bit version. The other thing is, have you created or modified a profile for your Samsung to transcode x265 MKV files? When I look at the existing stock profiles, I don't see a line to capture h265. That would explain why it can't be played, because the profile isn't telling it to transcode the file.
Post Wed Apr 29, 2015 6:19 pm
It works fine for me with the stock 1.5.2 profile, playing the H265 version of BIG BUCK BUNNY. http://www.elecard.com/assets/files/oth ... _720p_c.ts
The transcode is in the "sam_h" profile
<Profile id="sam_h" name="Samsung TV / player (H-series)" extendsProfileId="1">
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" forceInheritance="true">
<Matches container="*" vCodec="h265" />
which is inherited by sam_ef
<Profile id="sam_ef" name="Samsung TV / player (E/F-series)" extendsProfileId="sam_h">
which is inherited by CD
<Profile id="7" name="Samsung TV / player (C/D-series)" extendsProfileId="sam_ef">
Here is my log
2015-04-29 08:31:59,044 DEBUG [ServiioHttpService] Incoming request from /192.168.1.23:40060: HEAD /resource/27971/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.10:8895]]
2015-04-29 08:31:59,045 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.23
2015-04-29 08:31:59,046 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.23
2015-04-29 08:31:59,046 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.23, Profile=Samsung TV / player (C/D-series)'
2015-04-29 08:31:59,046 DEBUG [ResourceDeliveryProcessor] Request for resource 27971 and type 'MEDIA_ITEM' received
2015-04-29 08:31:59,046 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 27971 (local)
2015-04-29 08:31:59,054 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 27971, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2015-04-29 08:31:59,054 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file bbb_720p_c.ts
2015-04-29 08:31:59,054 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_EU_ISO
2015-04-29 08:31:59,054 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_NA_ISO
2015-04-29 08:31:59,054 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_KO_ISO
2015-04-29 08:31:59,056 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 29 Apr 2015 12:31:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-04-29 08:31:59,066 DEBUG [ServiioHttpService] Incoming request from /192.168.1.23:58211: GET /resource/27971/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.10:8895]]
2015-04-29 08:31:59,066 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.23
2015-04-29 08:31:59,068 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.23, Profile=Samsung TV / player (C/D-series)'
2015-04-29 08:31:59,068 DEBUG [ResourceDeliveryProcessor] Request for resource 27971 and type 'MEDIA_ITEM' received
2015-04-29 08:31:59,068 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 27971 (local)
2015-04-29 08:31:59,069 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 27971, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2015-04-29 08:31:59,069 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file bbb_720p_c.ts
2015-04-29 08:31:59,069 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_EU_ISO
2015-04-29 08:31:59,069 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_NA_ISO
2015-04-29 08:31:59,069 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_KO_ISO
2015-04-29 08:31:59,070 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 27971 (local)
2015-04-29 08:31:59,070 DEBUG [VideoDeliveryEngine] Delivering item '27971' for client 'Identifier=192.168.1.23, Profile=Samsung TV / player (C/D-series)'
2015-04-29 08:31:59,070 DEBUG [VideoDeliveryEngine] Delivering file 'bbb_720p_c.ts' using transcoding
2015-04-29 08:31:59,071 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.23, Profile=Samsung TV / player (C/D-series)'
2015-04-29 08:31:59,074 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: D:\All Video Recordings\All Video Test Files\All Test Videos\H265\bbb_720p_c.ts
2015-04-29 08:31:59,074 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib\ffdump.bat -threads 8 -i D:\All Video Recordings\All Video Test Files\All Test Videos\H265\bbb_720p_c.ts -y -threads 8 -c:v mpeg2video -pix_fmt yuv420p -qscale:v 1 -r 24 -g 15 -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts D:\TEMP\Serviio\transcoding-temp-27971-7-ORIGINAL.stf
2015-04-29 08:32:00,076 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2015-04-29 08:32:00,081 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_EU_ISO
2015-04-29 08:32:00,081 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_NA_ISO
2015-04-29 08:32:00,081 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "bbb_720p_c.ts": MPEG_TS_SD_KO_ISO
2015-04-29 08:32:00,141 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-29 08:32:00,141 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
Your log is similar and shows the same ffmpeg command being generated and MPEG2VIDEO being sent to the TV so "Unsupported Codec" makes no sense. Try the BIG BUCK BUNNY file. Perhaps it is the audio causing the problem.
jart352015yup
Post Thu Apr 30, 2015 1:06 am
jhb50 wrote:It works fine for me with the stock 1.5.2 profile, playing the H265 version of BIG BUCK BUNNY. http://www.elecard.com/assets/files/oth ... _720p_c.ts
Here is my log
Well tested the above as the others mentioned and used the test file mentioned and it works for me. update your serviio to the latest version 1.5.2 and go from there. use the suggested profile... The sam_h profile seems to work just fine for me.... try this and post results and we will help more if we can.
cheers
DTigerBKK
Post Thu Oct 22, 2015 1:50 am
cheers
Best to use that "old" thread...
I'm trying to watch x265 encoded movies, starting by that BIG BUCK BUNNY http://www.elecard.com/assets/files/oth ... _720p_c.ts which I downloaded to be sure I used the same one, and it does not work, giving me the "unsupported codec" message.
Have Serviio 1.5.2 on Windows 7 and for plugins purpose a very recent FFmpeg version.
Any idea where to go from there?
dicko1966
Post Mon Nov 23, 2015 3:09 am
I think the following provides a fix for this issue:
I'm running Serviio 1.5.2 on Windows 7. I had the same problem with this on my Samsung UE40D5520 TV when using the "Samsung TV / player (C/D-series)" profile (Profile id="7"). A lot of video that was being transcoded, and all H.265 stuff, was giving the "video codec not supported error" on the TV. What I did was systematically try all the profiles in turn until I found one that worked when transcoding a H.265 encoded video. The first profile when assigned to the TV that managed to play the video (and I stopped trying at that point) was "Panasonic BD Player" (Profile id="panasonicBDT220"). The Transcoding lines for that profile for all the different classes of video/audio read:
<Video targetContainer="mpegts" maxVBitrate="15360" DAR="16:9">
<Video targetContainer="mpegts" targetACodec="ac3" maxVBitrate="15360" DAR="16:9">
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="15360" DAR="16:9">
I then compared this to the transcoding line that gets executed when using the "Samsung TV / player (C/D-series)" profile to play a H.265 encoded video. By inheritance this appears within the "Samsung TV / player (H-series)" profile (Profile id="sam_h") and is:
The obvious difference that may matter between the two appears to be the use of maxVBitrate="15360" parameter for the "Panasonic BD Player" profile. So I changed the "Samsung TV / player (H-series)" transcoding line to include this parameter thus:
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="15360" aBitrate="192" forceInheritance="true">
and voila, it worked.
Incidentally, I don't know what the the largest maxVBitrate is that my Samsung D series TV supports and haven't tested it. Anyone? Having got the transcoding to work I was then stuck with the problem of the time search then not working which I see there is no solution to and so I have once more reverted to recoding H.265 video back to H.264 using Handbrake which is a shame given the much smaller H.265 file sizes.
Anyway, I hope that helps someone.
Eastends
Post Fri Jan 08, 2016 11:41 pm
Hi i would like to know if this is the definite fix for this issue ?
So far this is what i am getting .
it plays perfectly fine on my ps3 .
Thanks for the help
Unique ID                                : 219697309726785477775860563026251255806 (0xA54829AA02D6A81BB9B66720BF668FFE)
Complete name                            : D:\TV Series\Gotham\Season 2\Gotham S02E01 720p [Lucifer22] .mkv
File size                                : 146 MiB
Duration                                 : 44mn 1s
Overall bit rate                         : 463 Kbps
Encoded date                             : UTC 2015-11-27 12:08:28
Writing application                      : mkvmerge v7.9.0 ('Birds') 32bit
Format                                   : HEVC
Format profile                           : Main@L4@Main
Duration                                 : 44mn 1s
Bit rate                                 : 391 Kbps
Frame rate                               : 23.976 (24000/1001) fps
Bits/(Pixel*Frame)                       : 0.018
Stream size                              : 123 MiB (84%)
Writing library                          : x265 1.8+2-55a4a9b920ff:[Windows][GCC 5.2.0][64 bit] 8bit+10bit+12bit
Encoding settings                        : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=8 / bframe-bias=0 / b-adapt=2 / ref=6 / limit-refs=0 / weightp / no-weightb / aq-mode=2 / qg-size=32 / aq-strength=0.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.00 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=crf / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Codec ID                                 : A_AAC
Duration                                 : 44mn 1s
Bit rate                                 : 72.0 Kbps
Channel(s)                               : 2 channels / 1 channel / 1 channel
Channel positions                        : Front: L R / Front: C / Front: C
Frame rate                               : 23.438 fps (1024 spf)
Stream size                              : 22.3 MiB (15%)
6-01-07 18:56:08,605 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:34458: HEAD /resource/63179/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:08,605 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:08,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:08,610 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:08,610 DEBUG [ResourceDeliveryProcessor] Request for resource 63179 and type 'MEDIA_ITEM' received
2016-01-07 18:56:08,610 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63179 (local)
2016-01-07 18:56:08,610 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63179)
2016-01-07 18:56:08,627 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:08,628 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63179, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:08,628 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E04 720p [Lucifer22] .mkv
2016-01-07 18:56:08,628 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:08,628 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:08,628 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:08,628 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:08,628 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:08,629 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:08,629 DEBUG [ResourceValuesBuilder] Softsubs for media item 63179 found, will be served as a resource
2016-01-07 18:56:08,629 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63179/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:08,633 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:39523: HEAD /resource/63179/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:08,633 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:08,634 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:08,636 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:08,636 DEBUG [ResourceDeliveryProcessor] Request for resource 63179 and type 'MEDIA_ITEM' received
2016-01-07 18:56:08,636 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63179 (local)
2016-01-07 18:56:08,636 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63179)
2016-01-07 18:56:08,637 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:08,637 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63179, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:08,637 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E04 720p [Lucifer22] .mkv
2016-01-07 18:56:08,638 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:08,638 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:08,638 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:08,638 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:08,638 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:08,639 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:08,639 DEBUG [ResourceValuesBuilder] Softsubs for media item 63179 found, will be served as a resource
2016-01-07 18:56:08,639 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63179/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:08,687 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:50672: GET /resource/63179/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.110.15.100:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2016-01-07 18:56:08,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:08,688 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:08,688 DEBUG [ResourceDeliveryProcessor] Request for resource 63179 and type 'SUBTITLE' received
2016-01-07 18:56:08,688 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:08,688 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:08,689 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:08,689 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 63179
2016-01-07 18:56:08,689 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:08,689 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:08,690 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:08,690 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 63179
2016-01-07 18:56:08,704 DEBUG [GETMethodProcessor] Stream entity has length: 59505
2016-01-07 18:56:08,704 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 59505,Content-Type: smi/caption,Cache-control: no-cache,Connection: close,Date: Thu, 07 Jan 2016 23:56:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Background]]
2016-01-07 18:56:09,097 DEBUG [SearchManager] Committing search index
2016-01-07 18:56:09,518 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:41041: HEAD /resource/63179/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:09,518 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:09,519 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:09,519 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:09,519 DEBUG [ResourceDeliveryProcessor] Request for resource 63179 and type 'MEDIA_ITEM' received
2016-01-07 18:56:09,519 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63179 (local)
2016-01-07 18:56:09,519 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63179)
2016-01-07 18:56:09,519 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:09,520 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63179, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:09,520 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E04 720p [Lucifer22] .mkv
2016-01-07 18:56:09,520 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:09,520 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:09,520 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:09,521 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:09,521 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:09,523 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:09,523 DEBUG [ResourceValuesBuilder] Softsubs for media item 63179 found, will be served as a resource
2016-01-07 18:56:09,523 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63179/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:09 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:09,530 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:55062: HEAD /resource/63179/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:09,538 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:09,539 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:09,539 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:09,539 DEBUG [ResourceDeliveryProcessor] Request for resource 63179 and type 'MEDIA_ITEM' received
2016-01-07 18:56:09,540 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63179 (local)
2016-01-07 18:56:09,540 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63179)
2016-01-07 18:56:09,540 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:09,540 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63179, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:09,540 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E04 720p [Lucifer22] .mkv
2016-01-07 18:56:09,540 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:09,540 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:09,540 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E04 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:09,541 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:09,541 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:09,541 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:09,541 DEBUG [ResourceValuesBuilder] Softsubs for media item 63179 found, will be served as a resource
2016-01-07 18:56:09,542 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63179/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:09 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:09,559 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:50673: GET /resource/63179/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.110.15.100:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2016-01-07 18:56:09,559 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:09,560 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:09,560 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:09,560 DEBUG [ResourceDeliveryProcessor] Request for resource 63179 and type 'SUBTITLE' received
2016-01-07 18:56:09,560 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:09,560 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:09,561 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:09,561 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 63179
2016-01-07 18:56:09,561 DEBUG [VideoDAOImpl] Reading a Video (id = 63179)
2016-01-07 18:56:09,562 DEBUG [MediaItemDAOImpl] Getting file of media item 63179
2016-01-07 18:56:09,566 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E04 720p [Lucifer22] .srt
2016-01-07 18:56:09,566 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 63179
2016-01-07 18:56:09,566 DEBUG [GETMethodProcessor] Stream entity has length: 59505
2016-01-07 18:56:09,566 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 59505,Content-Type: smi/caption,Cache-control: no-cache,Connection: close,Date: Thu, 07 Jan 2016 23:56:09 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Background]]
2016-01-07 18:56:10,030 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-01-07 18:56:13,065 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:47518: HEAD /resource/63180/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.110.15.100:8895]]
2016-01-07 18:56:13,065 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:13,071 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:13,072 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'MEDIA_ITEM' received
2016-01-07 18:56:13,072 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63180 (local)
2016-01-07 18:56:13,072 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63180)
2016-01-07 18:56:13,072 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:13,072 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63180, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:13,072 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:13,072 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:13,072 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:13,072 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:13,073 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:13 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:13,088 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:45288: GET /resource/63180/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.110.15.100:8895]]
2016-01-07 18:56:13,088 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:13,094 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:13,094 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:13,094 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'MEDIA_ITEM' received
2016-01-07 18:56:13,095 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63180 (local)
2016-01-07 18:56:13,095 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63180)
2016-01-07 18:56:13,095 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:13,095 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63180, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:13,095 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:13,095 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:13,095 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:13,095 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:13,096 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:13,096 DEBUG [VideoDeliveryEngine] Delivering item '63180' for client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:13,096 DEBUG [VideoDeliveryEngine] Delivering file 'Gotham S02E05 720p [Lucifer22] .mkv' using transcoding
2016-01-07 18:56:13,096 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-63179-7-ORIGINAL.stf', will stop the job
2016-01-07 18:56:13,096 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-63179-7-ORIGINAL.stf'
2016-01-07 18:56:13,096 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-324,5,main]
2016-01-07 18:56:13,096 DEBUG [ProcessUtils] Killing the Windows process: 3948
2016-01-07 18:56:13,101 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2016-01-07 18:56:13,103 DEBUG [TranscodingJobListener] Deleted temp file 'G:\Serviio\transcoding-temp-63179-7-ORIGINAL.stf': true
2016-01-07 18:56:13,103 DEBUG [AbstractTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-63179-7-ORIGINAL.stf' of client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:13,103 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:13,104 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:13,105 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: D:\TV Series\Gotham\Season 2\Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:13,110 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe -threads auto -i D:\TV Series\Gotham\Season 2\Gotham S02E05 720p [Lucifer22] .mkv -y -threads auto -c:v mpeg2video -pix_fmt yuv420p -qscale:v 3 -r 24000/1001 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts G:\Serviio\transcoding-temp-63180-7-ORIGINAL.stf
2016-01-07 18:56:13,605 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2016-01-07 18:56:13,605 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:13,605 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:13,605 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:13,605 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 63180) as read
2016-01-07 18:56:13,610 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-01-07 18:56:13,610 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2016-01-07 18:56:13,612 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:13 GMT,MediaInfo.sec: SEC_Duration=2569000;,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,TimeSeekRange.dlna.org: npt=0-2569/2569,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:15,710 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:53098: HEAD /resource/63180/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:15,710 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:15,714 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:15,714 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:15,714 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'MEDIA_ITEM' received
2016-01-07 18:56:15,714 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63180 (local)
2016-01-07 18:56:15,714 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63180)
2016-01-07 18:56:15,715 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:15,715 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63180, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:15,715 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:15,715 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:15,715 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:15,715 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:15,715 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:15,716 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:15,716 DEBUG [ResourceValuesBuilder] Softsubs for media item 63180 found, will be served as a resource
2016-01-07 18:56:15,716 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63180/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:15 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:15,723 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:43773: HEAD /resource/63180/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:15,723 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:15,724 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:15,724 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'MEDIA_ITEM' received
2016-01-07 18:56:15,724 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63180 (local)
2016-01-07 18:56:15,724 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63180)
2016-01-07 18:56:15,724 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:15,724 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63180, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:15,724 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:15,725 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:15,725 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:15,725 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:15,725 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:15,725 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:15,726 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:15,726 DEBUG [ResourceValuesBuilder] Softsubs for media item 63180 found, will be served as a resource
2016-01-07 18:56:15,726 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63180/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:15 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:15,729 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:50674: GET /resource/63180/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.110.15.100:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2016-01-07 18:56:15,729 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:15,730 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:15,730 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:15,730 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'SUBTITLE' received
2016-01-07 18:56:15,730 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:15,730 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:15,731 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:15,731 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 63180
2016-01-07 18:56:15,731 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:15,731 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:15,732 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:15,732 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 63180
2016-01-07 18:56:15,746 DEBUG [GETMethodProcessor] Stream entity has length: 55896
2016-01-07 18:56:15,747 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 55896,Content-Type: smi/caption,Cache-control: no-cache,Connection: close,Date: Thu, 07 Jan 2016 23:56:15 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Background]]
2016-01-07 18:56:16,347 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:47780: HEAD /resource/63180/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:16,347 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:16,348 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:16,348 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'MEDIA_ITEM' received
2016-01-07 18:56:16,348 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63180 (local)
2016-01-07 18:56:16,348 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63180)
2016-01-07 18:56:16,348 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:16,348 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63180, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:16,348 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:16,349 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:16,349 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:16,349 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:16,349 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:16,349 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:16,351 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:16,351 DEBUG [ResourceValuesBuilder] Softsubs for media item 63180 found, will be served as a resource
2016-01-07 18:56:16,351 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63180/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:16 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:16,359 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:40504: HEAD /resource/63180/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2016-01-07 18:56:16,360 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:16,360 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:16,360 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'MEDIA_ITEM' received
2016-01-07 18:56:16,360 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 63180 (local)
2016-01-07 18:56:16,360 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 63180)
2016-01-07 18:56:16,361 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:16,361 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 63180, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2016-01-07 18:56:16,363 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Gotham S02E05 720p [Lucifer22] .mkv
2016-01-07 18:56:16,363 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_EU_ISO
2016-01-07 18:56:16,363 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_NA_ISO
2016-01-07 18:56:16,363 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Gotham S02E05 720p [Lucifer22] .mkv": MPEG_TS_SD_KO_ISO
2016-01-07 18:56:16,363 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:16,364 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:16,364 DEBUG [SubtitlesService] Found external subtitles file: Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:16,364 DEBUG [ResourceValuesBuilder] Softsubs for media item 63180 found, will be served as a resource
2016-01-07 18:56:16,364 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,CaptionInfo.sec: http://192.110.15.100:8895/resource/63180/SUBTITLE.srt,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 07 Jan 2016 23:56:16 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2016-01-07 18:56:16,370 DEBUG [ServiioHttpService] Incoming request from /192.110.15.104:50675: GET /resource/63180/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.110.15.100:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2016-01-07 18:56:16,370 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.110.15.104
2016-01-07 18:56:16,371 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.110.15.104, Profile=Samsung TV / player (C/D-series)'
2016-01-07 18:56:16,371 DEBUG [ResourceDeliveryProcessor] Request for resource 63180 and type 'SUBTITLE' received
2016-01-07 18:56:16,371 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:16,377 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:16,379 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:16,379 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 63180
2016-01-07 18:56:16,379 DEBUG [VideoDAOImpl] Reading a Video (id = 63180)
2016-01-07 18:56:16,380 DEBUG [MediaItemDAOImpl] Getting file of media item 63180
2016-01-07 18:56:16,380 DEBUG [SubtitlesService] Found external subtitle file: D:\TV Series\Gotham\Season 2\Gotham S02E05 720p [Lucifer22] .srt
2016-01-07 18:56:16,380 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 63180
2016-01-07 18:56:16,381 DEBUG [GETMethodProcessor] Stream entity has length: 55896
2016-01-07 18:56:16,381 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 55896,Content-Type: smi/caption,Cache-control: no-cache,Connection: close,Date: Thu, 07 Jan 2016 23:56:16 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Background]]
2016-01-07 18:56:16,872 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
Post Sat Jan 09, 2016 2:17 am
So add the fix and tell us if it works for you as well. Post your TV model as well.
