ip camera online video
kdext
Post Wed Apr 15, 2015 7:38 pm
Hello all
I have created a plugin to add my IP camera video to Serviio so that I can view camera video using MediaBrowser.
Now I want to create my own web page that will show original video (not transcoded) using Flowplayer flash component.
Using CDS API I am able to get content URL
http://server:23424/cds/resource/1000000020001274/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL?profile=0&authToken=465bcc876e104484a49e082b2bac8e5c
But when I setup my web page it does not work
   <!-- the player -->
   <div class="flowplayer" data-swf="flowplayer.swf" data-ratio="0.5625">
      <video>
         <source type="video/x-flv" src="http://server:23424/cds/resource/1000000020001274/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL?profile=0&authToken=465bcc876e104484a49e082b2bac8e5c">
      </video>
   </div>
I can not see any video in FlowPlayer.
Can someone help me get this working?
Thank you
Post Thu Apr 16, 2015 9:29 am
Re: ip camera online video
it the token still valid at that point?
kdext
Post Thu Apr 16, 2015 2:08 pm
Yes, auth token is active
Here is log file snippet
2015-04-15 21:28:13,320 DEBUG [CDSRetrieveMediaServerResource] GET http://server:23424/cds/resource/1000000020001274/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL?profile=0&authToken=465bcc876e104484a49e082b2bac8e5c&clientId=2103 HTTP/1.1, headers = [host: server:23424,user-agent: Mozilla/5.0 (Windows NT 5.1; rv:37.0) Gecko/20100101 Firefox/37.0,accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8,accept-language: en-US,en;q=0.5,accept-encoding: gzip, deflate,dnt: 1,referer: http://server:22180/flowplayer/flowplayer.swf,cookie: indextabs=2; serverstatustab=0; rendererprofiletab=0; networksettingtab=0; librarystatustabs=0,connection: keep-alive]
2015-04-15 21:28:13,321 DEBUG [CDSRetrieveMediaServerResource] Creating client with id '2103'
2015-04-15 21:28:13,321 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=2103, Profile=Generic DLNA profile'
2015-04-15 21:28:13,321 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001274 and type 'MEDIA_ITEM' received
2015-04-15 21:28:13,321 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001274 (online)
2015-04-15 21:28:13,321 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-04-15 21:28:13,322 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-04-15 21:28:13,322 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001274, format MPEG_PS_PAL and profile Generic DLNA profile
2015-04-15 21:28:13,322 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://141.138.41.47:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=
2015-04-15 21:28:13,322 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "rtsp://141.138.41.47:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=": MPEG_PS_PAL
2015-04-15 21:28:13,322 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "rtsp://141.138.41.47:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=": MPEG_PS_NTSC
2015-04-15 21:28:13,323 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001274 (online)
2015-04-15 21:28:13,323 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-04-15 21:28:13,323 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001274' for client 'Identifier=2103, Profile=Generic DLNA profile'
2015-04-15 21:28:13,323 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://141.138.41.47:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=' using transcoding
2015-04-15 21:28:13,323 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=2103, Profile=Generic DLNA profile'
2015-04-15 21:28:13,332 DEBUG [TranscodingJobListener] Deleted temp file '/tmp/Serviio/transcoding-temp-1000000020001274-1-ORIGINAL.stf': true
2015-04-15 21:28:13,332 DEBUG [AbstractTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-1000000020001274-1-ORIGINAL.stf' of client 'Identifier=2103, Profile=Generic DLNA profile'
2015-04-15 21:28:13,332 DEBUG [AbstractTranscodingDeliveryEngine] Removing transcoding listener with id transcoding-temp-1000000020001274-1-ORIGINAL.stf
Post Thu Apr 16, 2015 2:20 pm
You are using the generic profile (id=0), which transcodes to mpeg. You have to use the flv_player profile - note, the resource URL will then also change.
kdext
Post Sun Apr 19, 2015 6:07 pm
I have made this changes
      <video>
         <source type="video/x-flv" src="http://server:23424/cds/resource/1000000020001739/MEDIA_ITEM/FLV-0/ORIGINAL?profile=flv_player&authToken=a13535a121944425bc1d2c957ef35e61">
      </video>
   </div>
and this is the log file
2015-04-19 20:02:34,920 DEBUG [CDSRetrieveMediaServerResource] GET http://server:23424/cds/resource/1000000020001739/MEDIA_ITEM/FLV-0/ORIGINAL?profile=flv_player&authToken=a13535a121944425
bc1d2c957ef35e61 HTTP/1.1, headers = [host: server:23424,user-agent: Mozilla/5.0 (Windows NT 5.1; rv:37.0) Gecko/20100101 Firefox/37.0,accept: text/html,application/xhtml+xml,application/x
ml;q=0.9,*/*;q=0.8,accept-language: en-US,en;q=0.5,accept-encoding: gzip, deflate,dnt: 1,referer: http://server:22180/flowplayer/flowplayer.swf,cookie: indextabs=1; serverstatustab=0; rend
2015-04-19 20:02:34,921 DEBUG [CDSRetrieveMediaServerResource] Creating client with id '89.164.160.71'
2015-04-19 20:02:34,921 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=89.164.160.71, Profile=Flash player'
2015-04-19 20:02:34,921 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001739 and type 'MEDIA_ITEM' received
2015-04-19 20:02:34,921 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001739 (online)
2015-04-19 20:02:34,921 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-04-19 20:02:34,921 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001739, format FLV and profile Flash player
2015-04-19 20:02:34,921 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://89.164.160.71:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=
2015-04-19 20:02:34,922 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "rtsp://89.164.160.71:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=": FLV
2015-04-19 20:02:34,922 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001739 (online)
2015-04-19 20:02:34,922 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-04-19 20:02:34,922 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001739' for client 'Identifier=89.164.160.71, Profile=Flash player'
2015-04-19 20:02:34,922 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://89.164.160.71:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=' using transcoding
2015-04-19 20:02:34,922 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=89.164.160.71, Profile=Flash player'
2015-04-19 20:02:34,926 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: rtsp://89.164.160.71:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=
2015-04-19 20:02:34,927 DEBUG [ProcessExecutor] Starting /opt/ffmpeg/bin/ffmpeg -rtsp_transport +tcp+udp -analyzeduration 10000000 -fflags +genpts -threads auto -i rtsp://89.164.160.71:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM= -y -threads auto -c:v copy -an -map 0:0 -sn -f flv /tmp/Serviio/transcoding-temp-1000000020001739-flv_player-ORIGINAL.stf
This time, flowplayer shows the picture from the camera (snapshot) and when I click play nothing happens, no video stream is shown.
Post Mon Apr 20, 2015 11:05 am
Did yopu add it as live stream? It transcodes into a file, live stream should use pipe: as the output.
What happens if you run:
kdext
Post Fri Apr 24, 2015 7:14 am
When I run this
/opt/ffmpeg/bin/ffmpeg -rtsp_transport +tcp+udp -analyzeduration 10000000 -fflags +genpts -threads auto -i rtsp://141.136.221.69:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=
I get this as a result
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Mar 25 2015 23:24:34 with gcc 4.4.7 (GCC) 20120313 (Red Hat 4.4.7-11)
  configuration: --prefix=/opt/ffmpeg --enable-libx264 --enable-gpl --enable-avcodec --enable-static --extra-cflags='-I=/opt/x264/lib/pkgconfig' --extra-ldflags='-I=/opt/x264/lib/pkgconfig'
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, rtsp, from 'rtsp://141.136.221.69:22554/ISAPI/streaming/channels/101?auth=cHVzZXI6UHVzZXIxMjM=':
    title           : Media Presentation
  Duration: N/A, start: 0.319956, bitrate: N/A
    Stream #0:0: Video: h264 (Main), yuv420p(tv, bt709), 1920x1080, 25 fps, 25 tbr, 90k tbn, 50 tbc
Post Fri Apr 24, 2015 4:00 pm
and this?
kdext
Post Fri Apr 24, 2015 9:16 pm
[h264 @ 0x1f12800] RTP: missed 1 packets
[h264 @ 0x1f12800] RTP: missed 22 packets
[h264 @ 0x1f12800] RTP: missed 12 packets
[h264 @ 0x1f12800] RTP: missed 6 packets
    Last message repeated 3 times
[h264 @ 0x1f12800] RTP: missed 5 packets
[h264 @ 0x1f12800] RTP: missed 7 packets
[h264 @ 0x1f12800] RTP: missed 16 packets
    Last message repeated 1 times
  Duration: N/A, start: 0.319889, bitrate: N/A
Output #0, flv, to '/tmp/Serviio/transcoding-temp-1000000020001739-flv_player-ORIGINAL.stf':
    encoder         : Lavf56.14.100
    Stream #0:0: Video: h264 ([7][0][0][0] / 0x0007), yuv420p, 1920x1080, q=2-31, 25 fps, 1k tbn, 90k tbc
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
[flv @ 0x206ecc0] Non-monotonous DTS in output stream 0:0; previous: 0, current: -200; changing to 0. This may result in incorrect timestamps in the output file.
[flv @ 0x206ecc0] Non-monotonous DTS in output stream 0:0; previous: 0, current: -160; changing to 0. This may result in incorrect timestamps in the output file.
[flv @ 0x206ecc0] Non-monotonous DTS in output stream 0:0; previous: 0, current: -120; changing to 0. This may result in incorrect timestamps in the output file.
[flv @ 0x206ecc0] Non-monotonous DTS in output stream 0:0; previous: 0, current: -80; changing to 0. This may result in incorrect timestamps in the output file.
[flv @ 0x206ecc0] Non-monotonous DTS in output stream 0:0; previous: 0, current: -40; changing to 0. This may result in incorrect timestamps in the output file.
[NULL @ 0x1f12800] RTP: missed 6 packets
[NULL @ 0x1f12800] RTP: missed 7 packets
[NULL @ 0x1f12800] RTP: missed 16 packets
    Last message repeated 2 times
[NULL @ 0x1f12800] RTP: missed 17 packets
[NULL @ 0x1f12800] RTP: missed 8 packets
[NULL @ 0x1f12800] RTP: missed 7 packetskB time=00:00:01.64 bitrate=1461.8kbits/s
[NULL @ 0x1f12800] RTP: missed 15 packets
[NULL @ 0x1f12800] RTP: missed 27 packets
[NULL @ 0x1f12800] RTP: missed 7 packetskB time=00:00:02.16 bitrate=1242.9kbits/s
[NULL @ 0x1f12800] RTP: missed 9 packets
[NULL @ 0x1f12800] RTP: missed 18 packets
[NULL @ 0x1f12800] RTP: missed 5 packets
[NULL @ 0x1f12800] RTP: missed 20 packets
[NULL @ 0x1f12800] RTP: missed 19 packets
[NULL @ 0x1f12800] RTP: missed 14 packets
[NULL @ 0x1f12800] RTP: missed 10 packetsB time=00:00:02.72 bitrate=1098.6kbits/s
[NULL @ 0x1f12800] RTP: missed 2 packets
[NULL @ 0x1f12800] RTP: missed 42 packets
frame=   70 fps= 31 q=-1.0 Lsize=     396kB time=00:00:03.28 bitrate= 988.9kbits/s
video:394kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.426018%
Received signal 2: terminating.
kdext
Post Thu Apr 30, 2015 10:35 am
Any feedback on the output that I have last posted?
Post Thu Apr 30, 2015 4:10 pm
It looks ok.
How did you add the stream to the console?
kdext
Post Fri May 01, 2015 7:10 am
Camera is connected to my ADSL router and it connects to dynamic DNS service. My Groovy plugin fetches the camera IP address from dynamic DNS service creates the URL and adds it to the Serviio.
In Mediabrowser everything is working fine, I can see the camera in Online library and I can watch the video.
As I said the problem is when I try to watch the video in my web page.
Post Tue May 05, 2015 5:06 pm
So first, you should set 'live' attribute on the ContentURLContainer to 'true', otherwise you'll run out of disk space.
Second, does that Serviio URL play in VLC?
kdext
Post Thu May 07, 2015 1:57 pm
Yes, URL from the camera plays in VLC and other players.
Post Thu May 07, 2015 8:10 pm
I don't meant the URL from the camera, but the URL from serviio (that delivers the camera stream)
Users browsing this forum: No registered users and 76 guests
