Transcoding for Android Devices
simplesi
Post Wed Jan 19, 2011 8:24 pm
I'm really liking Serviio and I'm using it to feed files from my main computer to a Sony BDP-S370 in the living room.
I also use my HTC Desire for watching programs late at night in bed and use Rockplayer to play them back from the SD Card. (They are mostly xvid/mp3 avi files).
I'd very much like to use Serviio to transcode these files into an acceptable native format for the Android but it basically only plays mp4 container files using H.263 or H.264 AVC for video and AAC for audio.
Are there any near future plans to incorporate the ability to transcode to an mp4 compatible container format?
(Or is it possible now and I just haven't worked it out? :) )
I've made the following profile which allows Serviio to have its own profile for HTC devices but I'm stuck on the transcoding issue
<Profile id="11" name="Android" extendsProfileId="1">
      <Detection>
         <User-Agent>.*HTC.*</User-Agent>
      </Detection>
                       <!--- this doesn't work but it does trigger transcoding to operate for testing to prove the user agent detection  is working -->
         <Video targetContainer="mpegts"   >
            <Matches container="mp4" />
regards
Simon
Post Wed Jan 19, 2011 10:09 pm
Re: Transcoding for Android Devices
From what i understand MP4 is not a valid container for transcoded files, so this can not be done till support for it is added to FFmpeg, but Zip will correct me if i have misunderstood.
Post Wed Jan 19, 2011 11:14 pm
yeah, mp4 is not suitable for realtime transcoding.
simplesi
Post Wed Jan 19, 2011 11:49 pm
Thanks for the quick replies :)
Shame it can't be done :(
regards
Simon
Post Thu Jan 20, 2011 12:47 am
as soon as FFmpeg support it im sure ZIP will add it to serviio :)
Zek
Post Thu Jan 20, 2011 2:52 am
Rockplayer supports a lot more than MP4:
http://rockplayer.freecoder.org/index_en.html
I was watching TrueBlood 720p in MKVs on the plane this summer on my Nexus One. You don't need DLNA though. Just mount the share using CifsManager and RockPlayer thinks your share is a local directory. I was watching movies in my bed the other month that way.
Cheers,
Zek
Sony Bravia KDL-55NX810 | Serviio 0.5 (rev. 975aa458693c) | Synology DS-1010+
simplesi
Post Sat Jan 22, 2011 10:52 pm
I took zip's comments to mean it can't be done :(
@zek
cifsmanager needs root to work (and a ROM that supports it) :(
regards
Simon
simplesi
Post Sat Jan 22, 2011 11:06 pm
I realise this is drifting completely away from Serviio and I would fully understand if this post was deleted but I've just discovered GMote has direct to phone function and it can utilise Rockplayer so problem solved. :)
But still would be great in the future to just have the one media server for all devices :)
regards
Simon
Post Sun Jan 23, 2011 12:45 am
simplesi wrote:I would fully understand if this post was deleted
:-) It's not how it's working here. Glad you found something for you.
mike.clayton999
Post Sat Feb 26, 2011 9:26 am
Hi Guys,
I have had a lot of support from this Forum (Thanks Guys) so time for me to give a bit back. I have a Galaxy S running Android 2.2.1 which came with AllShare. In my attempts to get a DLNA server that will work with my WDLive TV and my Galaxy S/AllShare I have tried a number but only found one that would stream to the Galaxy and that was the Samsung PC Share (This ignored the WDLive TV completely). The Samsung software is not a patch on Serviio but it does highlight that it should be possible to stream to the Android device.
From AllShare I can access Servillo and see all the data (Series/Movies/Directors/Actors/etc) I can even look at my photos.. I just can't access Films or MP3's. I would also like to get my Android working fully with Serviio and now the Android Tablets are becoming more popular I expect there will be more people trying to get this working.
If I work out how to do it I will post back...
Mike
Post Sat Feb 26, 2011 9:46 am
mike.clayton999 wrote:Hi Guys,
Mike
have you tried the samsung C series profile ? it a long shot but from what i know they use the same version of allshare.
can you also Provide supported formats of a device ( see signiture for howto ) so that we can comfirm what i think is true and the galaxy S will work same as C series TVs
Zek wrote:Rockplayer supports a lot more than MP4:
Cheers,
Zek
can you do the same and Provide supported formats of a device for the HTC?
mike.clayton999
Post Sat Feb 26, 2011 9:12 pm
Hope I have done this right.
I tried the capture twice. Once using AllShare and Once using EyeCon as the streaming software
(Both apps on the Android Galaxy S)
AllShare
(String) Source
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520,http-get:*:video/mp4:*,http-get:*:video/3gpp:*,http-get:*:video/avi:*,http-get:*:audio/mp4:*,http-get:*:audio/mpeg:*,http-get:*:image/jpeg:*,http-get:*:image/png:*
EyeCon
(String Sink)
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,http-get:*:image/png:DLNA.ORG_PN=PNG_SM,http-get:*:image/png:DLNA.ORG_PN=PNG_MED,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG,http-get:*:image/png:DLNA.ORG_PN=PNG_TN,http-get:*:audio/x-aiff:*,http-get:*:audio/x-wav:*,http-get:*:audio/lpcm:*,http-get:*:audio/x-mpegurl:*,http-get:*:audio/x-scpls:*,http-get:*:audio/x-ms-asx:*,http-get:*:audio/rmp:*,http-get:*:video/mpeg2:*,http-get:*:video/dvd:*,http-get:*:video/x-msvideo:*,http-get:*:video/avi:*,http-get:*:video/mp4:*,http-get:*:video/MP4V-ES:*,http-get:*:video/MP4V:*,http-get:*:video/x-mpegurl:*,http-get:*:video/x-scpls:*,http-get:*:video/x-ms-asx:*,http-get:*:video/rmp:*,http-get:*:image/tiff:*,http-get:*:image/jpeg:*,http-get:*:image/jpeg2000:*,http-get:*:image/png:*,http-get:*:image/bmp:*,http-get:*:image/gif:*,http-get:*:image/x-mpegurl:*,http-get:*:image/x-scpls:*,http-get:*:image/x-ms-asx:*,http-get:*:image/rmp:*,http-get:*:application/ogg:*,file:*:audio/x-ms-wma:*,file:*:audio/x-aiff:*,file:*:audio/mpeg:*,file:*:audio/x-wav:*,file:*:audio/lpcm:*,file:*:audio/x-mpegurl:*,file:*:audio/x-scpls:*,file:*:audio/x-ms-asx:*,file:*:audio/rmp:*,file:*:video/mpeg:*,file:*:video/mpeg2:*,file:*:video/dvd:*,file:*:video/x-msvideo:*,file:*:video/mp4:*,file:*:video/MP4V-ES:*,file:*:video/MP4V:*,file:*:video/x-mpegurl:*,file:*:video/x-scpls:*,file:*:video/x-ms-asx:*,file:*:video/rmp:*,file:*:image/tiff:*,file:*:image/jpeg:*,file:*:image/jpeg2000:*,file:*:image/png:*,file:*:image/bmp:*,file:*:image/gif:*,file:*:image/x-mpegurl:*,file:*:image/x-scpls:*,file:*:image/x-ms-asx:*,file:*:image/rmp:*,file:*:application/ogg:*,rhapsody:*:audio/x-ms-wma:*,rhapsody:*:audio/x-mpegurl:*,rhapsody:*:audio/x-rhap-radio:*,uvox:*:audio/mpeg:*,http-get:*:image/sls:*,http-get:*:application/x-dtcp1;CONTENTFORMAT=image/jpeg:*,unicast:*:video/mpeg2ts:*,multicast:*:video/mpeg2ts:*,rtsp:*:video/mp4:*,rtsp:*:misc/sdp:*
I noticed that AllShare returned a (string) Source and not a (string) Sink like EyeCon and the WDTVLive do..Even when I told Allshare to try and play a movie from Serviio.
I get a lot of warnings/Errors in the log when Either AllShare or EyeCon try and connect to Serviio...
AllShare Errors
2011-02-26 15:24:58,764 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-26 15:24:59,951 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-02-26 15:25:19,808 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: For input string: ""
java.lang.NumberFormatException: For input string: ""
   at java.lang.NumberFormatException.forInputString(Unknown Source)
   at java.lang.Long.parseLong(Unknown Source)
   at java.lang.Long.<init>(Unknown Source)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:109)
   at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:52)
2011-02-26 15:25:20,027 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: For input string: ""
EyeCon Wanings
2011-02-26 20:58:50,078 INFO  [RendererManager] Stored a new renderer: uuid='bd76b317-8790-4d7a-9b01-a061f96766b0', name = 'Unrecognized device', ipAddress='10.1.1.7', profile = '1'
2011-02-26 20:58:51,343 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:51,515 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:51,562 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:51,984 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:52,015 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:52,046 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:54,374 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:54,530 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:58:54,577 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:59:06,217 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:59:06,670 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-26 20:59:06,888 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
I tried the Samsung C Series Profile (Infact I went through them all one by one) but none of them appeared to work.
If there is any other data you need from me please let me know...
Mike
Post Sat Feb 26, 2011 10:26 pm
can you enable detailed logging and capture the errors again?
mike.clayton999
Post Sun Feb 27, 2011 9:50 am
Hi Guys,
Here is the detailed log from
Server Startup (I have removed the Library Meida Check)
2011-02-27 08:58:34,384 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-02-27 08:58:34,400 INFO  [MediaServer] ------------------------------------------------------------------------
2011-02-27 08:58:34,400 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5 (rev. 975aa458693c)
2011-02-27 08:58:34,400 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-02-27 08:58:34,400 INFO  [MediaServer] http://www.serviio.org
2011-02-27 08:58:34,400 INFO  [MediaServer] Java 1.6.0_15-Sun Microsystems Inc.
2011-02-27 08:58:34,400 INFO  [MediaServer] OS Windows XP x86 5.1
2011-02-27 08:58:34,400 INFO  [MediaServer] File encoding: windows-1252
2011-02-27 08:58:34,603 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-02-27 08:58:34,681 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-02-27 08:58:34,696 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-02-27 08:58:35,118 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-02-27 08:58:36,602 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-02-27 08:58:36,602 INFO  [Device] Created UPnP Device with UUID: 82389917-f0f6-3db1-8111-6fff694a3834, bound address: 10.1.1.7
2011-02-27 08:58:36,649 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-02-27 08:58:36,665 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-02-27 08:58:36,665 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-02-27 08:58:36,665 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-02-27 08:58:36,665 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-27 08:58:36,665 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-02-27 08:58:36,665 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1298797116665, LastAccessTime = 1298797116665, getTimeToLiveSeconds() = -1, createTime = 1298797116665 ]
2011-02-27 08:58:36,681 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-02-27 08:58:36,712 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-02-27 08:58:36,712 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-27 08:58:36,712 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-02-27 08:58:36,712 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-02-27 08:58:36,712 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-27 08:58:36,712 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-02-27 08:58:36,712 INFO  [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-02-27 08:58:36,790 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-02-27 08:58:36,806 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-02-27 08:58:36,806 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-02-27 08:58:36,806 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-02-27 08:58:36,806 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-02-27 08:58:36,806 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-02-27 08:58:36,806 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-02-27 08:58:37,305 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-02-27 08:58:37,368 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-02-27 08:58:38,352 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-02-27 08:58:38,352 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-02-27 08:58:38,665 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-02-27 08:58:38,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-02-27 08:58:38,805 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-02-27 08:58:38,946 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-02-27 08:58:39,024 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-02-27 08:58:39,024 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-02-27 08:58:39,243 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-02-27 08:58:39,243 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-02-27 08:58:39,321 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-02-27 08:58:39,321 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-02-27 08:58:39,555 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-02-27 08:58:39,555 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-02-27 08:58:39,633 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-02-27 08:58:39,649 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-02-27 08:58:40,149 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-02-27 08:58:40,149 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-02-27 08:58:41,055 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player (EU)' (id=10)
2011-02-27 08:58:41,055 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 11
2011-02-27 08:58:42,289 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player (US)' (id=11)
2011-02-27 08:58:42,289 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-02-27 08:58:42,414 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-02-27 08:58:42,414 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-02-27 08:58:42,664 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-02-27 08:58:42,664 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio_DLNA\bin\\..\lib/ffmpeg.exe
2011-02-27 08:58:42,664 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio_DLNA\bin\\..\lib/ffmpeg.exe
2011-02-27 08:58:42,821 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-02-27 08:58:42,930 INFO  [WebServer] WebServer starting on port 8895
2011-02-27 08:58:42,945 DEBUG [DiscoveryManager] UPNP device 82389917-f0f6-3db1-8111-6fff694a3834 (10.1.1.7) is available
2011-02-27 08:58:42,945 INFO  [RendererSearchSender] Searching for Renderer devices
2011-02-27 08:58:42,945 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-02-27 08:58:42,945 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-02-27 08:58:42,961 INFO  [EventDispatcher] Starting EventDispatcher
2011-02-27 08:58:42,961 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-02-27 08:58:43,024 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 08:58:43,727 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 08:58:43,758 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 08:58:43,789 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 08:58:43,789 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-02-27 08:58:43,789 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.189.1, timeout = 0
2011-02-27 08:58:43,805 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 08:58:43,805 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-02-27 08:58:43,805 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.1.1.7:2238
2011-02-27 08:58:45,570 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 08:58:45,570 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 08:58:47,383 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.189.1, timeout = 0
2011-02-27 08:58:47,383 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 08:58:49,195 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-27 08:58:49,804 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-02-27 08:58:59,272 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 08:58:59,272 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 08:59:01,084 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 08:59:01,084 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 08:59:02,896 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.189.1, timeout = 0
2011-02-27 08:59:02,896 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 08:59:04,709 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-27 08:59:09,802 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-02-27 08:59:09,818 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-02-27 08:59:09,818 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-02-27 08:59:09,833 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-02-27 08:59:09,974 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: X:\web\Film\Films
2011-02-27 08:59:09,974 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: X:\web\Film\Films
2011-02-27 08:59:09,974 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2011-02-27 08:59:10,271 DEBUG [LibraryAdditionsCheckerThread] Found file '16 Blocks.avi', checking if it's already in the Library
2011-02-27 08:59:10,271 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 16 Blocks.avi
2011-02-27 08:59:12,661 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-02-27 08:59:12,802 DEBUG [MediaItemDAOImpl] Media item 16 Blocks.avi already exists in DB
2011-02-27 08:59:12,864 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-02-27 08:59:12,864 DEBUG [LibraryAdditionsCheckerThread] Found file '2 Fast 2 Furious.avi', checking if it's already in the Library
2011-02-27 08:59:12,880 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2 Fast 2 Furious.avi
2011-02-27 08:59:13,036 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-02-27 08:59:13,036 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2011-02-27 08:59:13,052 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2011-02-27 08:59:13,130 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2011-02-27 08:59:13,239 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2011-02-27 08:59:13,255 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2011-02-27 08:59:13,270 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor COVER_IMAGE_IN_FOLDER
2011-02-27 08:59:13,270 DEBUG [MediaItemDAOImpl] Media item 2 Fast 2 Furious.avi already exists in DB
2011-02-27 08:59:13,286 DEBUG [LibraryAdditionsCheckerThread] Found file '2001 A Space Odyssey.avi', checking if it's already in the Library
2011-02-27 08:59:13,286 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2001 A Space Odyssey.avi
2011-02-27 08:59:13,364 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2011-02-27 08:59:13,380 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2011-02-27 08:59:13,411 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor COVER_IMAGE_IN_FOLDER
2011-02-27 08:59:13,473 DEBUG [MediaItemDAOImpl] Media item 2001 A Space Odyssey.avi already exists in DB[
etc... etc... etc....
2011-02-27 09:16:22,033 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Zack and Miri Make a Porno (2008).avi
2011-02-27 09:16:22,252 DEBUG [MediaItemDAOImpl] Media item Zack and Miri Make a Porno (2008).avi already exists in DB
2011-02-27 09:16:22,283 DEBUG [LibraryAdditionsCheckerThread] Found file 'Zohan.avi', checking if it's already in the Library
2011-02-27 09:16:22,283 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Zohan.avi
2011-02-27 09:16:22,440 DEBUG [MediaItemDAOImpl] Media item Zohan.avi already exists in DB
2011-02-27 09:16:22,455 DEBUG [LibraryAdditionsCheckerThread] Found file 'Zoolander.avi', checking if it's already in the Library
2011-02-27 09:16:22,455 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Zoolander.avi
2011-02-27 09:16:22,627 DEBUG [MediaItemDAOImpl] Media item Zoolander.avi already exists in DB
2011-02-27 09:16:22,627 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
Log while requesting a film via AllShare
2011-02-27 09:32:57,222 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /10.1.1.133:19550
2011-02-27 09:32:57,222 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.1.1.133:19550
2011-02-27 09:32:59,222 DEBUG [WebServer] Incoming connection from /10.1.1.133:34027
2011-02-27 09:32:59,222 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 82389917-f0f6-3db1-8111-6fff694a3834 from 10.1.1.133 (headers = [user-agent: SEC_HHP_Galaxy S/1.0,Host: 10.1.1.7:8895,Connection: Keep-Alive])
2011-02-27 09:32:59,222 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:32:59,237 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-02-27 09:33:00,175 DEBUG [WebServer] Incoming connection from /10.1.1.133:37464
2011-02-27 09:33:00,378 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:00,378 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:00,378 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2011-02-27 09:33:00,378 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:00,393 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:00,550 DEBUG [WebServer] Incoming connection from /10.1.1.133:39052
2011-02-27 09:33:00,675 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:00,675 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:00,690 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 6, sortCriteria =
2011-02-27 09:33:00,690 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:00,690 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:02,034 DEBUG [WebServer] Incoming connection from /10.1.1.133:57366
2011-02-27 09:33:02,300 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:02,300 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:02,300 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 6, sortCriteria =
2011-02-27 09:33:02,300 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:02,300 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:02,487 DEBUG [WebServer] Incoming connection from /10.1.1.133:42315
2011-02-27 09:33:02,690 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:02,690 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:02,690 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 6, count = 6, sortCriteria =
2011-02-27 09:33:02,690 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:02,706 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:03,659 DEBUG [WebServer] Incoming connection from /10.1.1.133:58837
2011-02-27 09:33:03,909 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:03,909 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:03,924 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 6, sortCriteria =
2011-02-27 09:33:03,924 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:03,924 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:04,143 DEBUG [WebServer] Incoming connection from /10.1.1.133:49448
2011-02-27 09:33:04,424 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:04,424 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:04,440 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 6, count = 6, sortCriteria =
2011-02-27 09:33:04,440 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:04,440 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:04,784 DEBUG [WebServer] Incoming connection from /10.1.1.133:37729
2011-02-27 09:33:04,909 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:04,909 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:04,909 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 12, count = 6, sortCriteria =
2011-02-27 09:33:04,909 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:04,924 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:05,065 DEBUG [WebServer] Incoming connection from /10.1.1.133:45906
2011-02-27 09:33:05,205 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:05,205 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:05,205 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 18, count = 6, sortCriteria =
2011-02-27 09:33:05,205 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:05,221 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:05,362 DEBUG [WebServer] Incoming connection from /10.1.1.133:43557
2011-02-27 09:33:05,659 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:05,659 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:05,659 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 24, count = 6, sortCriteria =
2011-02-27 09:33:05,659 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:05,674 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:05,893 DEBUG [WebServer] Incoming connection from /10.1.1.133:53891
2011-02-27 09:33:06,096 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:33:06,096 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:06,377 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 30, count = 6, sortCriteria =
2011-02-27 09:33:06,377 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-27 09:33:06,377 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:33:06,408 DEBUG [WebServer] Incoming connection from /10.1.1.133:35324
2011-02-27 09:33:06,408 DEBUG [ResourceTransportRequestHandler] GET http://10.1.1.7:8895/resource/2801/MEDIA_ITEM/AVI HTTP/1.1, headers = [Accept: */*,Host: 10.1.1.7:8895,Range: bytes=0-5,x-wap-profile: ,User-Agent: Samsung Player User-Agent,Connection: Keep-Alive]]
2011-02-27 09:33:06,408 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:06,408 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.1.1.133, Profile=Generic DLNA profile'
2011-02-27 09:33:06,408 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: For input string: ""
2011-02-27 09:33:06,424 DEBUG [WebServer] Incoming connection from /10.1.1.133:38919
2011-02-27 09:33:06,424 DEBUG [ResourceTransportRequestHandler] GET http://10.1.1.7:8895/resource/2801/MEDIA_ITEM/AVI HTTP/1.1, headers = [Accept: */*,Host: 10.1.1.7:8895,Range: bytes=0-,x-wap-profile: ,User-Agent: Samsung Player User-Agent,Connection: Keep-Alive]]
2011-02-27 09:33:06,424 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:06,424 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.1.1.133, Profile=Generic DLNA profile'
2011-02-27 09:33:06,424 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: For input string: ""
2011-02-27 09:33:06,518 DEBUG [WebServer] Incoming connection from /10.1.1.133:57896
2011-02-27 09:33:06,518 DEBUG [ResourceTransportRequestHandler] GET http://10.1.1.7:8895/resource/2801/MEDIA_ITEM/AVI HTTP/1.1, headers = [Accept: */*,Host: 10.1.1.7:8895,Range: bytes=0-5,x-wap-profile: ,User-Agent: Samsung Player User-Agent,Connection: Keep-Alive]]
2011-02-27 09:33:06,518 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:06,518 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.1.1.133, Profile=Generic DLNA profile'
2011-02-27 09:33:06,518 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: For input string: ""
2011-02-27 09:33:07,174 DEBUG [ResourceTransportRequestHandler] HEAD /resource/2801/MEDIA_ITEM/AVI HTTP/1.1, headers = [getcaptioninfo.sec: 1,getcontentfeatures.dlna.org: 1,User-Agent: Dalvik/1.2.0 (Linux; U; Android 2.2.1; GT-I9000 Build/FROYO),Host: 10.1.1.7:8895,Connection: Keep-Alive]]
2011-02-27 09:33:07,174 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:33:07,174 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.1.1.133, Profile=Generic DLNA profile'
2011-02-27 09:33:07,174 DEBUG [ResourceTransportRequestHandler] Request for resource 2801 and type 'MEDIA_ITEM' received
2011-02-27 09:33:07,174 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2801)
2011-02-27 09:33:07,174 DEBUG [VideoDAOImpl] Reading a Video (id = 2801)
2011-02-27 09:33:07,174 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2801, format AVI and profile Generic DLNA profile
2011-02-27 09:33:07,174 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-02-27 09:33:07,174 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-msvideo,Content-Length: 1302314496,Date: Sun, 27 Feb 2011 09:33:07 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVI;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
Log while requesting a film via EyeCon
2011-02-27 09:43:06,124 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:06,218 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 09:43:06,218 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-02-27 09:43:06,234 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 09:43:06,234 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-02-27 09:43:06,234 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.1.1.7:2439
2011-02-27 09:43:06,234 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.189.1, timeout = 0
2011-02-27 09:43:06,249 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:06,249 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 09:43:06,249 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:06,312 DEBUG [RendererSearchSender] Received search response: location: http://10.1.1.133:8888/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-02-27 09:43:06,312 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer b4:07:f9:d0:8c:c3 from address /10.1.1.133:42760
2011-02-27 09:43:06,312 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:06,406 DEBUG [RendererSearchSender] Received search response: location: http://10.1.1.133:8888/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-02-27 09:43:06,406 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer b4:07:f9:d0:8c:c3 from address /10.1.1.133:42760
2011-02-27 09:43:06,453 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:06,453 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:06,609 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:06,624 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:06,656 DEBUG [WebServer] Incoming connection from /10.1.1.133:48375
2011-02-27 09:43:06,656 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 82389917-f0f6-3db1-8111-6fff694a3834 from 10.1.1.133 (headers = [host: 10.1.1.7,User-Agent: Dalvik/1.2.0 (Linux; U; Android 2.2.1; GT-I9000 Build/FROYO),Connection: Keep-Alive])
2011-02-27 09:43:06,656 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:43:06,656 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-02-27 09:43:06,671 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:06,671 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:06,796 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:06,828 DEBUG [WebServer] Incoming connection from /10.1.1.133:39352
2011-02-27 09:43:06,828 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-02-27 09:43:06,828 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-02-27 09:43:06,952 DEBUG [WebServer] Incoming connection from /10.1.1.133:55957
2011-02-27 09:43:07,046 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ConnectionManager
2011-02-27 09:43:07,046 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=ff89b1ba-a2bb-4177-9ad6-566f3e269da6) for service urn:upnp-org:serviceId:ConnectionManager reporting to http://10.1.1.133:8058/evetSub
2011-02-27 09:43:07,077 DEBUG [WebServer] Incoming connection from /10.1.1.133:55404
2011-02-27 09:43:07,077 DEBUG [EventDispatcher] Sending event notification #0 for subscription ff89b1ba-a2bb-4177-9ad6-566f3e269da6 to endpoint http://10.1.1.133:8058/evetSub
2011-02-27 09:43:07,077 DEBUG [RequestExecutor] Sending HTTP request to 10.1.1.133:8058
2011-02-27 09:43:07,140 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-02-27 09:43:07,156 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-02-27 09:43:07,156 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 10.1.1.133:
2011-02-27 09:43:07,156 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:43:07,156 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:43:07,202 DEBUG [WebServer] Incoming connection from /10.1.1.133:48448
2011-02-27 09:43:07,249 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2011-02-27 09:43:07,249 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=2e4d0f4d-0577-4023-a50a-852186fbbd3f) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://10.1.1.133:8058/evetSub
2011-02-27 09:43:07,343 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-02-27 09:43:07,343 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 10.1.1.133:
2011-02-27 09:43:07,343 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:43:07,359 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:43:07,843 DEBUG [EventDispatcher] Sending event notification #0 for subscription 2e4d0f4d-0577-4023-a50a-852186fbbd3f to endpoint http://10.1.1.133:8058/evetSub
2011-02-27 09:43:07,843 DEBUG [RequestExecutor] Sending HTTP request to 10.1.1.133:8058
2011-02-27 09:43:08,046 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-02-27 09:43:08,093 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 09:43:08,093 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:09,452 DEBUG [RendererSearchSender] Received search response: location: http://10.1.1.133:8888/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-02-27 09:43:09,452 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer b4:07:f9:d0:8c:c3 from address /10.1.1.133:49900
2011-02-27 09:43:09,452 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:09,530 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:09,530 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:09,577 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:09,577 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:09,593 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:09,905 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.189.1, timeout = 0
2011-02-27 09:43:09,905 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:11,718 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-27 09:43:12,233 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-02-27 09:43:12,671 DEBUG [WebServer] Incoming connection from /10.1.1.133:41109
2011-02-27 09:43:12,921 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:43:12,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:43:12,936 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 16, sortCriteria =
2011-02-27 09:43:12,936 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-27 09:43:12,936 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:43:14,545 DEBUG [WebServer] Incoming connection from /10.1.1.133:51880
2011-02-27 09:43:14,889 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:43:14,889 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:43:14,889 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 16, sortCriteria =
2011-02-27 09:43:14,889 DEBUG [VideoDAOImpl] Retrieving number of video initials
2011-02-27 09:43:14,920 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2011-02-27 09:43:14,967 DEBUG [SeriesDAOImpl] Retrieving number of series
2011-02-27 09:43:14,967 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-27 09:43:14,967 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2011-02-27 09:43:15,014 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2011-02-27 09:43:15,014 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2011-02-27 09:43:15,045 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2011-02-27 09:43:15,108 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2011-02-27 09:43:17,795 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2011-02-27 09:43:17,858 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2011-02-27 09:43:17,951 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-27 09:43:17,951 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:43:21,779 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 09:43:21,779 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:22,326 DEBUG [WebServer] Incoming connection from /10.1.1.133:55743
2011-02-27 09:43:22,435 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ConnectionManager and subscription uuid:ff89b1ba-a2bb-4177-9ad6-566f3e269da6
2011-02-27 09:43:22,435 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ConnectionManager and subscription ff89b1ba-a2bb-4177-9ad6-566f3e269da6
2011-02-27 09:43:22,701 DEBUG [WebServer] Incoming connection from /10.1.1.133:60922
2011-02-27 09:43:22,841 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:2e4d0f4d-0577-4023-a50a-852186fbbd3f
2011-02-27 09:43:22,841 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 2e4d0f4d-0577-4023-a50a-852186fbbd3f
2011-02-27 09:43:23,591 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 09:43:23,591 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:24,201 DEBUG [WebServer] Incoming connection from /10.1.1.133:32966
2011-02-27 09:43:24,341 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.1.1.133:
2011-02-27 09:43:24,341 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.1.1.133
2011-02-27 09:43:24,341 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_LV, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 16, sortCriteria =
2011-02-27 09:43:24,357 DEBUG [VideoDAOImpl] Retrieving list of 10 last viewed videos (from=0, count=16)
2011-02-27 09:43:24,451 DEBUG [SeriesDAOImpl] Reading a Series (id = 7)
2011-02-27 09:43:24,451 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2011-02-27 09:43:24,451 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 430)
2011-02-27 09:43:24,451 DEBUG [MediaItemDAOImpl] Getting file of media item 430
2011-02-27 09:43:24,466 DEBUG [VideoDAOImpl] Reading a Video (id = 430)
2011-02-27 09:43:24,466 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 430 and profile Generic DLNA profile
2011-02-27 09:43:24,466 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18522)
2011-02-27 09:43:24,466 DEBUG [SeriesDAOImpl] Reading a Series (id = 7)
2011-02-27 09:43:24,466 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2011-02-27 09:43:24,466 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 428)
2011-02-27 09:43:24,466 DEBUG [MediaItemDAOImpl] Getting file of media item 428
2011-02-27 09:43:24,466 DEBUG [VideoDAOImpl] Reading a Video (id = 428)
2011-02-27 09:43:24,466 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 428 and profile Generic DLNA profile
2011-02-27 09:43:24,466 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18520)
2011-02-27 09:43:24,466 DEBUG [SeriesDAOImpl] Reading a Series (id = 47)
2011-02-27 09:43:24,466 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15446)
2011-02-27 09:43:24,466 DEBUG [MediaItemDAOImpl] Getting file of media item 15446
2011-02-27 09:43:24,466 DEBUG [VideoDAOImpl] Reading a Video (id = 15446)
2011-02-27 09:43:24,466 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15446 and profile Generic DLNA profile
2011-02-27 09:43:24,466 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 21254)
2011-02-27 09:43:24,482 DEBUG [SeriesDAOImpl] Reading a Series (id = 8)
2011-02-27 09:43:24,482 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2011-02-27 09:43:24,482 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 459)
2011-02-27 09:43:24,482 DEBUG [MediaItemDAOImpl] Getting file of media item 459
2011-02-27 09:43:24,482 DEBUG [VideoDAOImpl] Reading a Video (id = 459)
2011-02-27 09:43:24,482 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 459 and profile Generic DLNA profile
2011-02-27 09:43:24,482 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18551)
2011-02-27 09:43:24,497 DEBUG [SeriesDAOImpl] Reading a Series (id = 47)
2011-02-27 09:43:24,497 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2011-02-27 09:43:24,497 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15388)
2011-02-27 09:43:24,497 DEBUG [MediaItemDAOImpl] Getting file of media item 15388
2011-02-27 09:43:24,497 DEBUG [VideoDAOImpl] Reading a Video (id = 15388)
2011-02-27 09:43:24,497 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15388 and profile Generic DLNA profile
2011-02-27 09:43:24,497 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 21196)
2011-02-27 09:43:24,513 DEBUG [SeriesDAOImpl] Reading a Series (id = 47)
2011-02-27 09:43:24,513 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2011-02-27 09:43:24,513 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15443)
2011-02-27 09:43:24,513 DEBUG [MediaItemDAOImpl] Getting file of media item 15443
2011-02-27 09:43:24,513 DEBUG [VideoDAOImpl] Reading a Video (id = 15443)
2011-02-27 09:43:24,513 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15443 and profile Generic DLNA profile
2011-02-27 09:43:24,513 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 21251)
2011-02-27 09:43:24,529 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2011-02-27 09:43:24,529 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15384)
2011-02-27 09:43:24,529 DEBUG [MediaItemDAOImpl] Getting file of media item 15384
2011-02-27 09:43:24,529 DEBUG [VideoDAOImpl] Reading a Video (id = 15384)
2011-02-27 09:43:24,529 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15384 and profile Generic DLNA profile
2011-02-27 09:43:24,529 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 21192)
2011-02-27 09:43:24,529 DEBUG [GenreDAOImpl] Reading a Genre (id = 4)
2011-02-27 09:43:24,529 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15321)
2011-02-27 09:43:24,529 DEBUG [MediaItemDAOImpl] Getting file of media item 15321
2011-02-27 09:43:24,544 DEBUG [VideoDAOImpl] Reading a Video (id = 15321)
2011-02-27 09:43:24,544 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15321 and profile Generic DLNA profile
2011-02-27 09:43:24,544 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 21130)
2011-02-27 09:43:24,544 DEBUG [GenreDAOImpl] Reading a Genre (id = 4)
2011-02-27 09:43:24,544 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15325)
2011-02-27 09:43:24,544 DEBUG [MediaItemDAOImpl] Getting file of media item 15325
2011-02-27 09:43:24,544 DEBUG [VideoDAOImpl] Reading a Video (id = 15325)
2011-02-27 09:43:24,544 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15325 and profile Generic DLNA profile
2011-02-27 09:43:24,544 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 21135)
2011-02-27 09:43:24,544 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2011-02-27 09:43:24,544 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 9)
2011-02-27 09:43:24,544 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2011-02-27 09:43:24,544 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2011-02-27 09:43:24,544 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 9 and profile Generic DLNA profile
2011-02-27 09:43:24,544 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18102)
2011-02-27 09:43:24,544 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2011-02-27 09:43:24,576 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2011-02-27 09:43:24,591 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-27 09:43:25,419 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.189.1, timeout = 0
2011-02-27 09:43:25,419 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:27,232 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-27 09:43:30,981 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:31,075 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:31,653 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:31,762 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:32,184 DEBUG [RendererManager] Retrieve device description from http://10.1.1.133:8888/description.xml
2011-02-27 09:43:32,247 WARN  [RendererManager] Error while retrieving renderer description: Cannot parse device description
2011-02-27 09:43:37,340 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (VIA Rhine II Fast Ethernet Adapter - Virtual Machine Network Services Driver) and address 10.1.1.7, timeout = 0
2011-02-27 09:43:37,340 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
2011-02-27 09:43:39,152 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (VMware Virtual Ethernet Adapter for VMnet1) and address 192.168.0.1, timeout = 0
2011-02-27 09:43:39,152 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 82389917-f0f6-3db1-8111-6fff694a3834
Hope this helps.
Mike
mike.clayton999
Post Sun Feb 27, 2011 10:11 am
Re: Transcoding for Android Devices
I Also grabbed these from the Intel UPNP Tools
Don't know if they will be any help.
Mike
Description.xml from AllShare
  <?xml version="1.0" ?>
- <root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:sec="http://www.sec.co.kr/dlna" xmlns:dlna="urn:schemas-dlna-org:device-1-0">
- <specVersion>
  <major>1</major>
  <minor>0</minor>
  </specVersion>
- <device>
  <dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMS-1.50</dlna:X_DLNADOC>
  <dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">M-DMS-1.50</dlna:X_DLNADOC>
  <dlna:X_DLNACAP xmlns:dlna="urn:schemas-dlna-org:device-1-0">av-upload,image-upload,audio-upload</dlna:X_DLNACAP>
  <deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType>
  <friendlyName>Galaxy S</friendlyName>
  <manufacturer>SAMSUNG Electronics</manufacturer>
  <manufacturerURL>http://www.sec.co.kr</manufacturerURL>
  <modelDescription>Provides content through UPnP ContentDirectory service</modelDescription>
  <modelName>SAMSUNG Media Server</modelName>
  <modelNumber>1.0</modelNumber>
  <modelURL>http://www.sec.co.kr</modelURL>
  <UDN>uuid:3e9de1e2-e5f5-3a6c-914e-72b5028e551a</UDN>
- <iconList>
- <icon>
  <mimetype>image/jpeg</mimetype>
  <height>48</height>
  <width>48</width>
  <depth>24</depth>
  <url>/icon/icon.jpeg</url>
  </icon>
- <icon>
  <height>120</height>
  <width>120</width>
  <depth>24</depth>
  <url>/icon/icon2.jpeg</url>
  </icon>
- <icon>
  <mimetype>image/png</mimetype>
  <height>48</height>
  <width>48</width>
  <depth>24</depth>
  <url>/icon/icon.png</url>
  </icon>
- <icon>
  <width>120</width>
  <depth>24</depth>
  <url>/icon/icon2.png</url>
  </icon>
  </iconList>
- <serviceList>
- <service>
  <serviceType>urn:schemas-upnp-org:service:ContentDirectory:1</serviceType>
  <serviceId>urn:upnp-org:serviceId:ContentDirectory</serviceId>
  <SCPDURL>cds.xml</SCPDURL>
  <controlURL>ContentDirectory_control</controlURL>
  <eventSubURL>ContentDirectory_event</eventSubURL>
  </service>
- <service>
  <serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
  <serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
  <SCPDURL>cms.xml</SCPDURL>
  <controlURL>ConnectionManager_control</controlURL>
  <eventSubURL>ConnectionManager_event</eventSubURL>
  </service>
  </serviceList>
  </device>
  </root>
Description.xml from EyeCon
  <?xml version="1.0" encoding="utf-8" ?>
- <root>
- <specVersion>
  <major>1</major>
  <minor>0</minor>
  </specVersion>
  <URLBase>http://10.1.1.133:8888</URLBase>
- <device>
  <deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
  <friendlyName>GT-I9000 (10.1.1.133)</friendlyName>
  <manufacturer>Eyecon Technologies</manufacturer>
  <manufacturerURL>http://www.eyecontec.com</manufacturerURL>
  <modelDescription>EyeconMobileRenderer for GT-I9000 (samsung)</modelDescription>
  <modelName>EyeconMobileRenderer</modelName>
  <modelURL>http://www.eyecontec.com</modelURL>
  <UDN>uuid:B4:07:F9:D0:8C:C3</UDN>
- <serviceList>
- <service>
  <serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
  <serviceId>urn:upnp-orgerviceId:urnchemas-upnp-orgervice:RenderingControl</serviceId>
  <SCPDURL>/RenderingControl/scpd.xml</SCPDURL>
  <controlURL>/RenderingControl/control</controlURL>
  <eventSubURL>/RenderingControl/eventSub</eventSubURL>
  </service>
- <service>
  <serviceId>urn:upnp-orgerviceId:urnchemas-upnp-orgervice:ConnectionManager</serviceId>
  <SCPDURL>/ConnectionManager/scpd.xml</SCPDURL>
  <controlURL>/ConnectionManager/control</controlURL>
  <eventSubURL>/ConnectionManager/eventSub</eventSubURL>
  </service>
- <service>
  <serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
  <serviceId>urn:upnp-orgerviceId:urnchemas-upnp-orgervice:AVTransport</serviceId>
  <SCPDURL>/AVTransport/scpd.xml</SCPDURL>
  <controlURL>/AVTransport/control</controlURL>
  <eventSubURL>/AVTransport/eventSub</eventSubURL>
  </service>
  </serviceList>
- <iconList>
- <icon>
  <mimeType>image/png</mimeType>
  <width>64</width>
  <height>64</height>
  <depth>32</depth>
  <url>android.png</url>
  </icon>
  </iconList>
  </device>
  </root>
Post Sun Feb 27, 2011 1:13 pm
The AllShare error will be fixed in 0.5.1. The other log doesn't include request for a file.
mike.clayton999
Post Sun Mar 13, 2011 8:11 pm
Hi Petr
Just upgrade to Serviio 0.5.1 and have been streaming to my Android Galaxy S (AllShare). Thanks for the upgrade.
Mike ;-):
Post Sun Mar 13, 2011 8:23 pm
mike.clayton999 wrote:Hi Petr
Mike ;-):
what profile were you using ?
mike.clayton999
Post Mon Mar 14, 2011 7:46 am
Just running on Generic DLNA Profile, Audio and Video all synced, streaming smoothly and no errors in the Log now.
Still shows an Unrecognized device in the console but works perfectly.
Mike
Post Mon Mar 14, 2011 9:58 am
mike.clayton999 wrote:Hi,
Mike
ok good so did we get the information to make serviio recognise the device?
if not can you turn on detailed logging ( see my signiture for howto ) delete old log file so we start with a free one and then remove it from the console renderers list and restart serviio and post the log. then maybe we can get a detection for it :) and give it ots own profile based on the generic one.
Users browsing this forum: No registered users and 69 guests
