Problems since upgrade to 1.5.2.
bagz
Post Sat May 02, 2015 11:57 am
Hi Guys,
I have recently upgraded to 1.5.2 and have a problem where movies will start and then randomly stop. Sometimes the movie will move onto the next in the queue without intervention. I tried to downgrade to a 1.4 version I had but this did not work very well and I could not add a new media folder.
Can someone please help with this. I have been using this program in my environment for a at least 5 years and am a paid user. I have never had any problems before and am a big advocate for this program. Can you also please supply a download link for the previous version and the best way to downgrade so I can keep using it in the mean time.
Thanks in advance.
Post Tue May 05, 2015 5:29 pm
Re: Problems since upgrade to 1.5.2.
Google for the older version and pick the one you want. If you downgrade, make sure to uninstall it first.
