YouTube
Re: YouTube
Updated the plugin to work as a WebResource plugin. Example URLs in the original post.
Petr
Help translate Serviio
Re: YouTube
Thanks for that.
One question, I normally just use the youtube channels 'upload' category, but it looks like those pages do not have a playlistID. Is it a case of well that sucks, have to add each channels playlist to serviio now?
Re: YouTube
Tarrasque wrote:Thanks for that.
Yes. The only way I know right now to get channel uploads playlist ID is to use the Google API Exlorer for YouTube and request 'channels.list'. Here is a video that covers the subject https://m.youtube.com/watch?v=RjUlmco7v2M
Re: YouTube
For those who want to know, goto
https://developers.google.com/apis-expl ... nnels.list
part = contentDetails
forUsername = (channelusername)
Hit execute, and in the results at bottom of the page, look for "uploads":
Re: YouTube
Thanks All! Works for me. Allows me to keep up with my youtube feeds easily and now with v3 api
Re: YouTube
With the v2 API, it was possible, to set the start-index of the playlist.
This was useful, when one wanted to have more results than 50, because then one could create a second Online resource in serviio, which was beginning at 51.
E.g.: (v2 API)
Can this be done with the new Plugin/API ?
E.g.: (v2 API)
Re: YouTube
MarkusW wrote:With the v2 API, it was possible, to set the start-index of the playlist.
Can this be done with the new Plugin/API?
Attributes:
part=snippet
maxResults={MAX_RESULTS}
(pageToken={TOKEN})
playlistId={PLAYLIST_ID}
Hit 'execute' and look up in the result for 'nextPageToken' value. Use the value as pageToken={TOKEN} for getting a certain page (and new tokens).
Clear enought?
Edit:
Re: YouTube
Thank you.
Could you please make an example for the Channel "NFL" with maximum 20 videos?
Re: YouTube
Cartman316 wrote:Thank you.
Execute (NFL) for the uploads id
https://developers.google.com/apis-explorer/#p/youtube/v3/youtube.channels.list?part=contentDetails&forUsername=NFL
uploads: UUDVYQ4Zhbm3S2dlz7P1GBDg into playlistId
Execute (20) and repeat for all wanted pages
https://developers.google.com/apis-explorer/#p/youtube/v3/youtube.playlistItems.list?part=snippet&maxResults=20&playlistId=UUDVYQ4Zhbm3S2dlz7P1GBDg
nextPageToken: CAUQAA into pageToken
Re: YouTube
Thank you, but im not able to get a valid string.
Could you please post the string with the example (Channel=NFL, number results =20)?
Re: YouTube
Follow the example in this thread post #1 with the uploads playlist id. Note that max items is set in Serviio's console and if you want the first page items then no pagetoken attribute should be added.
Re: YouTube
I'm attempting to follow the posted examples and not having much luck.
I went to the https://developers.google.com/apis-expl ... nnels.list to get the id I needed, then use the URL
in Serviio.
The log shows returned status code '400'
2015-05-08 17:25:02,934 WARN [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/p ... ZrOvume4YA, waiting for expiry time to try again: Error during feed reading. Message: URL 'https://www.googleapis.com/youtube/v3/playlistItems?playlistId=UUOzpgwSVhD9VLZrOvume4YA' returned status code '400'
org.serviio.library.online.metadata.OnlineResourceParseException: Error during feed reading. Message: URL 'https://www.googleapis.com/youtube/v3/playlistItems?playlistId=UUOzpgwSVhD9VLZrOvume4YA' returned status code '400'
at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:108)
Any advice would be appreciated.
Thanks,
Keith
in Serviio.
Thanks,
Keith
Re: YouTube
Okay, after a computer restart, I'm no longer seeing the status code '400' message, but the folder doesn't show up under Online sources on my TV anymore.
Keith
Keith
Re: YouTube
Did you set plugin type as 'Web resource' in console?
Re: YouTube
No I hadn't. That solved it, thanks!
Keith
Keith
Re: YouTube
Hi All
Sorry to be a complete noob at this sort of thing but can someone please tell me where I am going wrong.
I have copied the youtube.groovy in to the plug-in folder on Serviio
I have listed it as a web resource under source type, and copied the following URL in to the the source URL box
https://www.googleapis.com/youtube/v3/v ... ostPopular
display name is YouTube.
The online category is enabled on the presentation tab under the video category.
when I open Serviio on my TV, the online folder is there but it is empty.
I have stopped and restarted Serviio numerous times, hit refresh and still nothing.
My setup:
Serviio is installed on a HP proliant microserver running Windows server 2008 R2
DLNA device is a LG HB405SU BD Player
Both the above go through a GiG switch.
The BD Player is then connected to a TV via HDMI
I have no problem playing movies and music from Serviio, but cannot access anything online.
I have tried different plug-ins ( Vimeo,xVideos) with corresponding source URL's and nothing seems to work.
Please help
My setup:
Please help
Re: YouTube
If getting the plugins from the A.P.P. collection it might not work since many are outdated.
Re: YouTube
stefana888 wrote:If getting the plugins from the A.P.P. collection it might not work since many are outdated.
Thanks for the answer
I used the YouTube plug-in from the beginning of this post
Re: YouTube
Check the logfile what is going on.
Users browsing this forum: No registered users and 100 guests
