How to create a ".nomedia" File
Wixie
Post Wed May 06, 2015 7:58 pm
How do I create a file with the name ".nomedia" ? Windows does not accept that because there is just the extension but no filename.
snowflake7
Post Wed May 06, 2015 9:36 pm
Re: How to create a ".nomedia" File
1) Open notepad and save a blank text file named .nomedia. Important: be sure to change the "Save as type" option to All files (*.*)
2) Make sure to remove the .txt from the name if Windows added it -- it should just be named .nomedia not .nomedia.txt -- Windows will most often add .txt by default.
If the file icon looks like a text file icon, then you probably need to rename it and remove ".txt" from the name. It should show the "unknown file type" generic looking icon.
2a) Sometimes Windows will hide the file extension too. Then change view options so that extentions are not hidden.
Wixie
Post Thu May 07, 2015 11:35 am
works, thx. But you need notepad. Windows Explorer does not want to create a file with no name, just the extension
