Serviio 1.5 Windows 7 Sony Bravia 55EX710
johnny2000
Post Sat Feb 07, 2015 11:35 pm
I just installed 1.5, and the problem I am having is, when I paused, forward or backward, then press the play button again, the pictures disappear but there is sound. I tried changing the profile from 2010, 2009, same problem. Anyone have encountered this issue? Thank you.
PS. With Serviio 1.4 either Windows 7 or CentOS 6 I never encountered this issue with my Bravia.
joedel
Post Thu Feb 12, 2015 6:24 am
Re: Serviio 1.5 Windows 7 Sony Bravia 55EX710
Hy!
Same with me here! After Pause, FF oder RW the video stands still or doesn't show at all, but sound's going on fine.
Didn't happen with <1.5 - will try later this day with new ffmpeg binary...
Joedel
EDIT: Win 8.1 64bit runnng
Post Fri Feb 13, 2015 1:39 pm
post detailed log please.
When you revert to 1.4, does it work? It might be caused by TV firmware update.
johnny2000
Post Fri Feb 13, 2015 6:49 pm
I re-installed the 1.4 and the problem went away. Everything works fine with version 1.4.
joedel
Post Fri Feb 13, 2015 10:37 pm
Sorry for late answer...
Updating ffmpeg didn`t work... adding detailed log tomorrow...
Joedel
net802n
Post Sun May 10, 2015 6:06 pm
I have similar problems as johnny2000's post, I tried 1.5.1 and 1.5.2, both have the same problems, and I have to go back to 1.4.2.
irishdrunk
Post Sat May 16, 2015 5:49 am
I'm having same problem with a KDL-52EX700....It started a week ago, thought it was firmware, but that upgraded in January, I don't remember what version of Serviio I was on before, but I hadn't updated in a long time, I think it was 1.3 or 1.4...
Just downloaded newest version and I still get the problem, If i pause, and unpause, i get no video and just audio. Usually the video takes a bit to catch up to audio, but now i get all black, and I have to restart my TV and then restart the file
chofo
Post Thu Aug 06, 2015 7:26 pm
Hi
I signed up solely to bump this thread and find out if anyone has had any luck fixing this!
I have the exact same issue: Bravia KDL40EX403, Serviio 1.5.2, if I try to pause, ff, rw etc, when I resume playing I get a blank screen with sound.
If i revert back to serviio 1.4.x the problem disappears!
Any help would be greatly appreciated!
proft0x
Post Sat Nov 07, 2015 8:18 pm
Sony Bravia KDL-52NX800. Same problem--once you FF/RW/pause a movie, Serviio 1.5.x video freezes permanently (audio still OK). Even restarting service is of no help. Serviio 1.4.1.2 and below has always worked fine. Running Windows Server 2008 R2 with latest Java 8 update 65.
Post Sun Nov 08, 2015 2:37 am
Just an FYI: Serviio no longer uses the Java you have installed on your computer. During setup it installs it's own version, so it no longer matters what version you have.
