Possible Bug - Online Audio
Timotevin10
Post Mon May 11, 2015 11:23 pm
When using Online Audio streams on MediaBrowser, when you go to switch from one stream to another the interface locks up and you have to hit refresh to get going again. It does this both on the Shoutcast plugin and on native online audio streams.
-Details-
Server:
Windows Server 2012 R2
Serviio 1.5.2
Java 8 45
Client:
Windows 8.1 Pro
Chrome Browser and Internet Explorer
Java 8 45
Post Tue May 12, 2015 8:07 pm
Re: Possible Bug - Online Audio
Can you post the streams URLs?
Timotevin10
Post Wed May 13, 2015 11:15 am
0
Post Wed May 13, 2015 3:38 pm
I've tested my Shoutcast plugin with http://www.shoutcast.com/?search=jazz and can confirm it parses correctly and Mediabrowser plays the first selected feed item but when then attempting to select another stream or exit the "PLAYLIST" screen with the upper right X the mediabrowser locks up and must be restarted.
2015-05-11 13:21:14,227 DEBUG [OnlineLibraryManager] Resource http://www.shoutcast.com/?search=jazz not in cache, (re)loading it
2015-05-11 13:21:14,227 DEBUG [WebResourceParser] Parsing web resource 'http://www.shoutcast.com/?search=jazz'
2015-05-11 13:21:14,227 DEBUG [WebResourceParser] Found matching url extractor (Shoutcast) for resource http://www.shoutcast.com/?search=jazz
2015-05-11 13:21:14,227 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting parsing resource: http://www.shoutcast.com/?search=jazz
2015-05-11 13:21:14,228 DEBUG [FeedItemUrlExtractor] Shoutcast: Parsing with Shoutcast V6
2015-05-11 13:21:15,837 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2015-05-11 13:21:16,052 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.10:55862s
2015-05-11 13:21:18,621 DEBUG [SearchManager] Committing search index
2015-05-11 13:21:19,070 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.10:55862s
2015-05-11 13:21:22,069 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.10:55862s
2015-05-11 13:21:25,069 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.10:55862s
2015-05-11 13:21:27,145 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) ABC Lounge - Jazz (4697)
2015-05-11 13:21:27,366 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://listen.radionomy.com/ABC-Lounge, expiresImmediately=false, live=true, ]
2015-05-11 13:21:27,367 DEBUG [WebResourceParser] Added resource item 1: '(128KB) ABC Lounge - Jazz (4697)' (http://listen.radionomy.com/ABC-Lounge)
2015-05-11 13:21:27,367 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) Tropicalisima.fm Instrumental - Smooth Jazz (1302)
2015-05-11 13:21:27,878 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://tropicalisima.org:9000, expiresImmediately=false, live=true, ]
2015-05-11 13:21:27,878 DEBUG [WebResourceParser] Added resource item 2: '(128KB) Tropicalisima.fm Instrumental - Smooth Jazz (1302)' (http://tropicalisima.org:9000)
2015-05-11 13:21:27,878 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) SmoothJazz.com Global Radio - The World's First 24/7 Since 2000 - KJAZ.DB - Smooth Jazz (1080)
2015-05-11 13:21:28,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://173.244.199.249:80, expiresImmediately=false, live=true, ]
2015-05-11 13:21:28,379 DEBUG [WebResourceParser] Added resource item 3: '(128KB) SmoothJazz.com Global Radio - The World's First 24/7 Since 2000 - KJAZ.DB - Smooth Jazz (1080)' (http://173.244.199.249:80)
2015-05-11 13:21:28,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) TheJazzGroove.com - Jazz (799)
2015-05-11 13:21:28,878 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://199.180.72.2:8015, expiresImmediately=false, live=true, ]
2015-05-11 13:21:28,879 DEBUG [WebResourceParser] Added resource item 4: '(128KB) TheJazzGroove.com - Jazz (799)' (http://199.180.72.2:8015)
2015-05-11 13:21:28,879 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) 1.FM - BAY SMOOTH JAZZ RADIO - Smooth Jazz (639)
2015-05-11 13:21:29,378 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://185.33.22.15:9010, expiresImmediately=false, live=true, ]
2015-05-11 13:21:29,378 DEBUG [WebResourceParser] Added resource item 5: '(128KB) 1.FM - BAY SMOOTH JAZZ RADIO - Smooth Jazz (639)' (http://185.33.22.15:9010)
2015-05-11 13:21:29,378 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) Smoothjazztampabay.com | WJAZ.DB The World's Groovin Smooth Jazz Destination Since 2004 - Smooth Jazz (616)
2015-05-11 13:21:29,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://192.81.248.192:8132/stream, expiresImmediately=false, live=true, ]
2015-05-11 13:21:29,880 DEBUG [WebResourceParser] Added resource item 6: '(128KB) Smoothjazztampabay.com | WJAZ.DB The World's Groovin Smooth Jazz Destination Since 2004 - Smooth Jazz (616)' (http://192.81.248.192:8132/stream)
2015-05-11 13:21:29,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) 181.fm - The Breeze - Smooth Jazz (592)
2015-05-11 13:21:30,090 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538s
2015-05-11 13:21:30,090 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2015-05-11 13:21:30,381 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://108.61.73.118:8004, expiresImmediately=false, live=true, ]
2015-05-11 13:21:30,382 DEBUG [WebResourceParser] Added resource item 7: '(128KB) 181.fm - The Breeze - Smooth Jazz (592)' (http://108.61.73.118:8004)
2015-05-11 13:21:30,382 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (64KB) 1.FM - ADORE JAZZ RADIO - Vocal Jazz (556)
2015-05-11 13:21:30,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://205.164.35.19:80, expiresImmediately=false, live=true, ]
2015-05-11 13:21:30,881 DEBUG [WebResourceParser] Added resource item 8: '(64KB) 1.FM - ADORE JAZZ RADIO - Vocal Jazz (556)' (http://205.164.35.19:80)
2015-05-11 13:21:30,881 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) ALL SMOOTH JAZZ - Smooth Jazz (479)
2015-05-11 13:21:31,368 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://listen.radionomy.com/all-smooth-jazz, expiresImmediately=false, live=true, ]
2015-05-11 13:21:31,368 DEBUG [WebResourceParser] Added resource item 9: '(128KB) ALL SMOOTH JAZZ - Smooth Jazz (479)' (http://listen.radionomy.com/all-smooth-jazz)
2015-05-11 13:21:31,368 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (64KB) 1.FM - BAY SMOOTH JAZZ RADIO - Jazz (397)
2015-05-11 13:21:31,879 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://185.33.22.22:7082, expiresImmediately=false, live=true, ]
2015-05-11 13:21:31,880 DEBUG [WebResourceParser] Added resource item 10: '(64KB) 1.FM - BAY SMOOTH JAZZ RADIO - Jazz (397)' (http://185.33.22.22:7082)
2015-05-11 13:21:31,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) ABC Jazz - Jazz (364)
2015-05-11 13:21:32,368 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://listen.radionomy.com/ABC-Jazz, expiresImmediately=false, live=true, ]
2015-05-11 13:21:32,368 DEBUG [WebResourceParser] Added resource item 11: '(128KB) ABC Jazz - Jazz (364)' (http://listen.radionomy.com/ABC-Jazz)
2015-05-11 13:21:32,368 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) SwissGroove - The world's No. 1 for jazz, funk, soul, world, latin and nu-grooves - Jazz (360)
2015-05-11 13:21:32,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://5.196.242.209:8100, expiresImmediately=false, live=true, ]
2015-05-11 13:21:32,880 DEBUG [WebResourceParser] Added resource item 12: '(128KB) SwissGroove - The world's No. 1 for jazz, funk, soul, world, latin and nu-grooves - Jazz (360)' (http://5.196.242.209:8100)
2015-05-11 13:21:32,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) 1.FM - Sax4Ever - Smooth Jazz (347)
2015-05-11 13:21:33,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://185.33.22.21:10148, expiresImmediately=false, live=true, ]
2015-05-11 13:21:33,379 DEBUG [WebResourceParser] Added resource item 13: '(128KB) 1.FM - Sax4Ever - Smooth Jazz (347)' (http://185.33.22.21:10148)
2015-05-11 13:21:33,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (192KB) #MUSIK.LOUNGE - WWW.RAUTEMUSIK.FM - 24H SOUL FUNK DISCO SMOOTHJAZZ SOULFUL HOUSE LOUNGE LATIN MORE! - Jazz (333)
2015-05-11 13:21:33,882 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://193.34.51.94:80, expiresImmediately=false, live=true, ]
2015-05-11 13:21:33,882 DEBUG [WebResourceParser] Added resource item 14: '(192KB) #MUSIK.LOUNGE - WWW.RAUTEMUSIK.FM - 24H SOUL FUNK DISCO SMOOTHJAZZ SOULFUL HOUSE LOUNGE LATIN MORE! - Jazz (333)' (http://193.34.51.94:80)
2015-05-11 13:21:33,882 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) Dinner Jazz Excursion - Jazz (325)
2015-05-11 13:21:34,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://64.78.234.165:8240, expiresImmediately=false, live=true, ]
2015-05-11 13:21:34,379 DEBUG [WebResourceParser] Added resource item 15: '(128KB) Dinner Jazz Excursion - Jazz (325)' (http://64.78.234.165:8240)
2015-05-11 13:21:34,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) 1.FM - ADORE JAZZ RADIO - Vocal Jazz (303)
2015-05-11 13:21:34,879 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://205.164.36.21:80, expiresImmediately=false, live=true, ]
2015-05-11 13:21:34,879 DEBUG [WebResourceParser] Added resource item 16: '(128KB) 1.FM - ADORE JAZZ RADIO - Vocal Jazz (303)' (http://205.164.36.21:80)
2015-05-11 13:21:34,879 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) ABACO LIBROS Y CAFE RADIO - Classic Jazz (276)
2015-05-11 13:21:35,368 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://listen.radionomy.com/-BACO-LIBROS-Y-CAF--RADIO, expiresImmediately=false, live=true, ]
2015-05-11 13:21:35,368 DEBUG [WebResourceParser] Added resource item 17: '(128KB) ABACO LIBROS Y CAFE RADIO - Classic Jazz (276)' (http://listen.radionomy.com/-BACO-LIBROS-Y-CAF--RADIO)
2015-05-11 13:21:35,368 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (32KB) JAZZ.FM91 (CJRT-FM) HD Stream - Jazz (276)
2015-05-11 13:21:35,879 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://209.159.189.54:8002, expiresImmediately=false, live=true, ]
2015-05-11 13:21:35,879 DEBUG [WebResourceParser] Added resource item 18: '(32KB) JAZZ.FM91 (CJRT-FM) HD Stream - Jazz (276)' (http://209.159.189.54:8002)
2015-05-11 13:21:35,880 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (128KB) Jazzradio - Jazz (260)
2015-05-11 13:21:36,379 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://216.230.231.164:9938, expiresImmediately=false, live=true, ]
2015-05-11 13:21:36,380 DEBUG [WebResourceParser] Added resource item 19: '(128KB) Jazzradio - Jazz (260)' (http://216.230.231.164:9938)
2015-05-11 13:21:36,380 DEBUG [FeedItemUrlExtractor] Shoutcast: Starting extraction of url for item: (64KB) SmoothJazz.com Global Radio - The World's First 24/7 Since 2000 - KJAZ.DB - Smooth Jazz (256)
2015-05-11 13:21:36,879 DEBUG [FeedItemUrlExtractor] Shoutcast: Finished extraction of url: ContentURLContainer [fileType=AUDIO, contentUrl=http://173.244.199.250:80, expiresImmediately=false, live=true, ]
2015-05-11 13:21:36,879 DEBUG [WebResourceParser] Added resource item 20: '(64KB) SmoothJazz.com Global Radio - The World's First 24/7 Since 2000 - KJAZ.DB - Smooth Jazz (256)' (http://173.244.199.250:80)
2015-05-11 13:21:36,879 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://www.shoutcast.com/?search=jazz' in the cache (online_feeds), returning it
2015-05-11 13:21:36,879 DEBUG [OnlineLibraryManager] Resource http://www.shoutcast.com/?search=jazz will expire in the cache on Mon May 11 19:21:36 EDT 2015
The playback request generates:
2015-05-13 11:32:50,015 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 1000000590001398 and profile Flash player
2015-05-13 11:32:50,015 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file http://listen.radionomy.com/ABC-Lounge: MP3
2015-05-13 11:32:52,026 DEBUG [CDSRetrieveMediaServerResource] GET http://localhost:23424/cds/resource/1000000590001398/MEDIA_ITEM/MP3-0/ORIGINAL?profile=flv_player&authToken=1cf01f5e4f1548e8b1900b0b8a063183 HTTP/1.1, headers = [host: localhost:23424,connection: keep-alive,user-agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/42.0.2311.152 Safari/537.36,x-requested-with: ShockwaveFlash/17.0.0.188,accept: */*,referer: http://localhost:23424/mediabrowser/,accept-encoding: gzip, deflate, sdch,accept-language: en-US,en;q=0.8]
2015-05-13 11:32:52,026 DEBUG [CDSRetrieveMediaServerResource] Creating client with id '127.0.0.1'
2015-05-13 11:32:52,026 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=127.0.0.1, Profile=Flash player'
2015-05-13 11:32:52,026 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000590001398 and type 'MEDIA_ITEM' received
2015-05-13 11:32:52,026 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000590001398 (online)
2015-05-13 11:32:52,026 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 59)
2015-05-13 11:32:52,027 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 59)
2015-05-13 11:32:52,028 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 1000000590001398, format MP3 and profile Flash player
2015-05-13 11:32:52,028 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://listen.radionomy.com/ABC-Lounge
2015-05-13 11:32:52,028 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file http://listen.radionomy.com/ABC-Lounge: MP3
2015-05-13 11:32:52,028 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000590001398 (online)
2015-05-13 11:32:52,028 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 59)
2015-05-13 11:32:52,029 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 59)
2015-05-13 11:32:52,029 DEBUG [AudioDeliveryEngine] Delivering item '1000000590001398' for client 'Identifier=127.0.0.1, Profile=Flash player'
2015-05-13 11:32:52,029 DEBUG [AudioDeliveryEngine] Delivering file 'http://listen.radionomy.com/ABC-Lounge' using transcoding
2015-05-13 11:32:52,029 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=127.0.0.1, Profile=Flash player'
2015-05-13 11:32:52,030 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode audio file: http://listen.radionomy.com/ABC-Lounge
2015-05-13 11:32:52,030 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib\ffdump.bat -analyzeduration 10000000 -threads 8 -i http://listen.radionomy.com/ABC-Lounge -y -threads 8 -b:a 128k -id3v2_version 3 -ac 2 -c:v copy -f mp3 pipe:
2015-05-13 11:32:52,530 DEBUG [StreamBasedTranscodingDeliveryStrategy] Adding client to stream multiplexer: Identifier=127.0.0.1, Profile=Flash player
2015-05-13 11:32:53,530 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=127.0.0.1, Profile=Flash player
2015-05-13 11:32:53,530 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file http://listen.radionomy.com/ABC-Lounge: MP3
2015-05-13 11:32:53,530 DEBUG [GETMethodProcessor] Entity will be consumed till the end
2015-05-13 11:32:53,530 DEBUG [GETMethodProcessor] Stream entity has length: -1
2015-05-13 11:32:54,714 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
Post Thu May 14, 2015 9:42 pm
Return to User experiences
