YouTube
railfrog
Post Mon May 11, 2015 9:58 pm
Re: YouTube
Ok...
Here are some errors in the log file....
2015-05-11 17:09:09,247 WARN [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/v ... ostPopular, waiting for expiry time to try again: Unexpected error while invoking plugin (YouTube): Cannot get property 'videoId' on null object
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (YouTube): Cannot get property 'videoId' on null object
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: java.lang.NullPointerException: Cannot get property 'videoId' on null object
at org.codehaus.groovy.runtime.NullObject.getProperty(NullObject.java:56)
at org.codehaus.groovy.runtime.InvokerHelper.getProperty(InvokerHelper.java:156)
at org.codehaus.groovy.runtime.callsite.NullCallSite.getProperty(NullCallSite.java:44)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java:227)
at YouTube$_extractItems_closure1.doCall(Youtube.groovy:49)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:272)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:877)
at groovy.lang.Closure.call(Closure.java:412)
at groovy.lang.Closure.call(Closure.java:425)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1376)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1348)
at org.codehaus.groovy.runtime.dgm$162.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at YouTube.extractItems(Youtube.groovy:47)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
... 1 more
2015-05-11 22:34:12,568 WARN [PluginCompilerThread] Plugin SeasonVar.groovy failed to compile: startup failed:
C:\Program Files\Serviio\plugins\SeasonVar.groovy: 3: unable to resolve class org.restlet.engine.util.CookieSettingSeries
@ line 3, column 1.
import org.restlet.engine.util.CookieSettingSeries
2015-05-11 22:42:52,724 WARN [PluginCompilerThread] Plugin VevoBeta.groovy failed to compile: startup failed:
C:\Program Files\Serviio\plugins\VevoBeta.groovy: 90: unable to resolve class YouTube
@ line 90, column 16.
return new YouTube().extractUrl(links, requestedQuality)
If any more info is needed, please let me know.
stefana888
Post Mon May 11, 2015 11:36 pm
Re: YouTube
railfrog wrote:Ok...
On YouTube there is a problem with selecting videos. Only selecting playlists work for now. I reported this to the plugin owner (zip).
Other plugin malfunctions (seen as log warnings) are from outdated plugins. Read the threads.
railfrog
Post Tue May 12, 2015 6:00 am
Re: YouTube
Thanks Stefana
I installed the APP list of plug-ins.
Even though I have been using servii0 for a good few years now, this is my first venture in to the "online" part of it.
Would you (or someone) please let me know of a working plug-in to try and what to put in the relevant boxes on the online tab so that I can at least make sure that it works and to save me from going insane.
stefana888
Post Tue May 12, 2015 6:14 am
Re: YouTube
railfrog wrote:Thanks Stefana
Far from all works actually. Reading the threads posts and checking the date is an indication of the status.
stefana888
Post Tue May 12, 2015 8:24 pm
Re: YouTube
The plugin is fixed now and also now takes channel names. See main post.
Intel1
Post Tue May 12, 2015 9:31 pm
Re: YouTube
Hello, to search for videos by name before it was:
http://gdata.youtube.com/feeds/api/videos?v=2&q=zzzzzzz
Now you can, with the new YouTube APIs and the new plugin youtube from 5/12/2015 ?
Thank you.
stefana888
Post Tue May 12, 2015 9:51 pm
Re: YouTube
Intel1 wrote:Hello, to search for videos by name before it was:
Thank you.
The plugin does not support seach by now.
j00j4nt200
Post Tue May 12, 2015 11:44 pm
Re: YouTube
plugin version:Further additions 12/05/2015 (thanks to Stefan Andersson)
https://www.googleapis.com/youtube/v3/c ... ANNEL_NAME
tried:
https://www.googleapis.com/youtube/v3/c ... rnHXYexeEg
yt link:https://www.youtube.com/channel/UCvhI7HuH0NE6hrnHXYexeEg
or
https://www.googleapis.com/youtube/v3/c ... entDickNes
yt link:https://www.youtube.com/user/BeneVolentDickNes/videos
Isn't working on xbox360, am I doing somethin wrong?
stefana888
Post Wed May 13, 2015 2:58 am
Re: YouTube
j00j4nt200 wrote:plugin version:Further additions 12/05/2015 (thanks to Stefan Andersson)
tried:
or
The first link is actually not a username, it is a userid. Try
https://www.googleapis.com/youtube/v3/channels?id=UCvhI7HuH0NE6hrnHXYexeEg
The second link is correct and working.
Cartman316
Post Wed May 13, 2015 7:25 am
Re: YouTube
Thank you Stefana888. Now it works. :)
j00j4nt200
Post Wed May 13, 2015 3:43 pm
Re: YouTube
stefana888 wrote:The second link is correct and working.
Thank you :)
I missed: Changed to WebResourcePlugin 26/04/2015 (thanks to Stefan Andersson)
2 more question pls :)
-If I start watching video, and then exit - ffmpg is still going as process and using significant cpu power - it should stop to?
-Can I with CHANNEL_NAME also easy to add max number of videos to retrieve (6)?
stefana888
Post Wed May 13, 2015 4:07 pm
Re: YouTube
1. ffmpeg runs until the whole video is downloaded.
2. Console sets the max number.
j00j4nt200
Post Wed May 13, 2015 4:49 pm
Re: YouTube
2.
I did tried to set 'Max number of feeds to retrieve' to 10, but after that feed wasn't working at all - only 'unlimited' setting is working.
Also I want 6 not 10 because it's max number on one page on xbox360.
All that was easy to set on v2 - now nothing is easy but hey at least is working :)
stefana888
Post Wed May 13, 2015 5:07 pm
Re: YouTube
j00j4nt200 wrote:2.
10 or any selection should work. You can change plugin code line
from
if (maxItemsToRetrieve == -1) maxItemsToRetrieve = 50
to
maxItemsToRetrieve = 6
j00j4nt200
Post Wed May 13, 2015 11:49 pm
Re: YouTube
Didn't manage to work with changing 'maxItemsToRetrieve', but working with deleting it, and used + "&maxResults=5".
Can I also add 'timeCreated' at the begining of title name of video?
stefana888
Post Thu May 14, 2015 12:19 am
Re: YouTube
j00j4nt200 wrote:Didn't manage to work with changing 'maxItemsToRetrieve', but working with deleting it, and used + "&maxResults=5".
Maybe you did wrong first. You can add time
in title with it.snippet.publishedAt
j00j4nt200
Post Thu May 14, 2015 9:58 pm
Re: YouTube
Great :)
Now, can I trim it from: 'YYYY-MM-DDThh:mm:ss.sZ' to 'YYYY-MM-DD'?
stefana888
Post Fri May 15, 2015 3:38 am
Re: YouTube
j00j4nt200 wrote:Great :)
Start a thread in develop section...
http://stackoverflow.com/questions/11257014/to-get-substring-in-groovy-separated-by-a-character
Intel1
Post Sat May 16, 2015 4:02 pm
Re: YouTube
Hi, this may help the plugin have the option to search?
https://developers.google.com/youtube/v ... earch/list
Thank you.
stefana888
Post Sat May 16, 2015 4:51 pm
Re: YouTube
Intel1 wrote:Hi, this may help the plugin have the option to search?
Thank you.
We know... is this feature really used from API v2?
Return to Available plugins
Users browsing this forum: No registered users and 106 guests
